Question about SanDisk Sansa Clip MP3 Player
Sansa clip mp3 player wont charge
I have a sansa clip mp3 player and the only way to charge it is on my computer, but now it wont charge anymore, what can i do?
  • 36 Answers
Try to charge it on another computer to determine if it's your computer. If the other computer works, then the problem is with your computer. (If your computer has multiple USB ports, you could also try another one.)
If the other computer does not work, then the problem is likey your cable. If you have another friend with the same device, borrow their cable and try it. If it works, then you need a new cable. If it doesn't work, then your Clip has issues. You could try doing a complete reset on it by sliding the power button up and holding it for 15 seconds (as described in the manual at http://www.sansa.com/sites/default/files/downloads/CLIP_UM_0608_ENG.pdf).
Posted on Jan 05, 2009
Sansas clip won't turn on
my sansa sandisk mp3 will not turn on the battery is fully charged it was working for at lease 10 minutes but it not working anymore.
Jan 13, 2011 | SanDisk Sansa Clip MP3 Player
My sansa clip will not charge on certain computers says it detects a problem and wont charge
try installing the drivers for that device by the cd that u must have been provided for that device
Apr 08, 2010 | SanDisk Sansa Clip MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip 4GB MP3 Player
go to control panel and click on portable media devices note:will not work on windows xp even if you downgrade to classic using a disk
Feb 07, 2009 | SanDisk Sansa Clip MP3 Player
It wont turn on!
If you were charging it with your USB cord, you have to keep the computer turned on the whole time it's charging, otherwise, it will be losing it's charge.
Feb 04, 2009 | SanDisk Sansa Clip MP3 Player
I was charging my sansa mp3 player and now it does not work!!!!!!
the problem is when the computer freezes it sometimes can wipe the hard drive and can damage the mp3 player for good thus freezing it from turning it on and clearing the memory and thats it
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
My computer wont recognize my mp3
I know this is only part of the solution:
- turn off your sansa clip
- put the slide button on hold
- press the centered button while connecting the sansa clip to your pc
the sansa clip will now be visible as a removable disk under 'my computer' :-)
I don't yet know how to proceed from here on
Sep 20, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip Mp3 Player
format it
by connecting to computer
Jun 11, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip 2gb
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
May 28, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
109 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
