Question about Saws
Why can;t i get a manuel for craftsman dado blade 720-32708
Want a manuel for craftsman dado blade 720-32708
FixYaSteve
  • 57 Answers
SOURCE: what kind of dado blade can I use on my craftsman
You have a 5/8" diameter arbor. You can use any dado blade that will fit. That said here's a few things to bear in mind.
8" diameter dado stacks are pretty standard for 10" contractor table saws. A dado stack is typically about 13/16" wide at most. It makes sense that the wider your blade is, the more power it takes to cut through the wood.
If you were to use the full width capacity of your Dado stack (13/16") a 10" diameter stack would bog down. A 8" stack has a faster rotation at the cutting edge because of its smaller radius. So, you don't bog down when you're making a wider cut if you use a smaller diameter.
If your machine was really underpowered, you could go down to a 6" stack which would cut your power requirements even more, but limits the depth of cut.
If this post was helpful, please vote. Thanks.
Posted on Jun 14, 2010
  • 22 Answers
SOURCE: bosh 4000 table saw , using dado blades.
no good solution for that problem. dado blades vibrate and cause the knob to turn. possibly a clamp on the knob to keep it in place.
tom
Posted on Dec 13, 2008
  • 548 Answers
SOURCE: Can I use a dado blade on my craftsman tablesaw
yes you can and here is a nice online manual that is free and you can even print out if you like
http://dl.owneriq.net/e/e99c86ed-3ba5-4bb5-a567-3b4fffebfc1f.pdf
it will show you all of the saws usues and attachments including dado
Posted on Sep 25, 2009
Testimonial: "Thanks, I was pleasantly surprised with the promptness of your response. "
  • 7 Answers
SOURCE: I have a craftsman table
Maybe you could try using the outline of the regular insert to cut a new insert out of a piece of polycarbonate (lexan) or ABS plastic. The clips that hold my dado insert barely hold it in place on mine, and I've seen other saws that use plastic.
Posted on Aug 14, 2010
jyackle5
  • 8197 Answers
SOURCE: I have a craftsman model
Don't have all the answers you want, but may be able to help with the dado question. The 137 generally points to Rexon-Tradesman. A brand sold here by Lowe's.
My table saw is 137.248800 which will Not accept an 8" dado blade set.
You may have purchased the 8" dado set. Try the 6" size, if your saw has a 5/8" arbor. My dado set is the Freud (SD206) carbide version. My saw will accept only up to 1/2", maybe 9/16" dado setup.
The cabinet saws typically use the 8" dado set, capable of up to 3/4".
You should also be able to get the parts that you need at Sears.
Posted on Jan 31, 2011
Could I use a 8 Inch DADO 3/4 inch wide blades.
Yes, as long as you have a 10" craftsman skill saw.
Apr 17, 2011 | Craftsman Saws
How do I set the dado width?
Dado blades come in sets with two side blades and a series of center blades to widen the cut. The no of blades put in the center sets the inital cut, and a series of these cuts can widen the cut farther. The poor mans dado can be done by a series of single saw cuts (kerfs) across a measured distance, moving the fence a small amount each time and then taking a chisel and working the waste out of the slot. For a primer on Dados, see: http://www.newwoodworker.com/hottodado.html
Jan 10, 2011 | Craftsman Garden
I bought a craftsman dado blade set but can't find the instructions and I have no idea how to use it. Is it possible to get instructions
Dado blades are used in a variety of saw applications. Commonly tables saws. The manual for your table saw should identify if the saw is capable of using this blade-set Never used dado blades in a saw that is not intended for them as this can result in severe injury to yourself and or damge to the tool. If your are unsure if your saw can accomodate dado blade please post your make and model of saw and someone will try to help you.
Dec 29, 2010 | Craftsman Garden
Need instructions for a sears excalibur dado blade model no. 720-32708 or can i down load it and where
I have this dado blade but I don't understand how to set it. I can turn the dial but I don't understand what keeps it in the selection that I want???
Oct 07, 2010 | Craftsman Garden
I have a craftsman table saw model 113.27870. I need a table insert for a dado blade. I looked on the sears website and it said parts for this saw are no longer available. Will a table insert for a newer...
Aug 02, 2010 | Craftsman 10" Table Saw
What kind of dado blade can I use on my craftsman 10 inch table saw model no. 137.248100/ with stand
Mar 28, 2010 | Craftsman 10" Table Saw
Need dado throat insert for 113
why not just make your own out of 1/4" plywood
trace out the insert but don't cut a slot
install it on the saw with the blade all the way down
turn on the saw and raise the blade to cut out the insert
Dec 11, 2009 | Hardware & Accessories
Can I use a dado blade on my craftsman tablesaw model 137. 248830 if so what kind/size?
Sep 25, 2009 | Craftsman Saws
Dado blade installation
Yes. normally an eight inch stack dado set is used on a 10 inch saw. You will also have to purchase or fabricate a special throat plate (non-metallic) to accomodate the extra thickness of the dado set.
The number of blades used, and therefore the thickness, varies depending upon the task at hand.
Make sure to use the factory supplied nut and washer to capture and tighten the dado set securely on the arbor.
Be very cautious in the use of dados. Do not raise the set higher than 1/4" or so until you are familiar with the use of a dado set. Try to avoid so-called "wobble" dado sets. They are IMHO more prone to dangerous kickbacks and harder to adjust than a stack dado set with dado shims.
Mar 21, 2009 | Delta TS200LS Shopmaster 10 Inch Portable...
Saws Logo
316 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
