Question about Janome Sewist 625e
Thread/material jam in Janome Sewist 625
Learning to sew. So far I have tested the machine multiple times on a scrap of lightweight cotton/poly weave. It will sew forward just fine....I see a little of the top thread on the bottom, which I understand must be a tension issue. The primary problem is reverse....I am so frustrated. If you put the machine in reverse as in the beginning of a seam, it hangs up, creates a ball of thread in the bobbin case under the thread plate and sometimes sucks the material in with it. Of course, with the thread jammed that way the machine stops. I have cleaned it out (twice), rethreaded three times in a meticulous fashion with the manual in view (which isn't all that in depth or helpful), and I'm about to replace the needle and adjust the tension in some fashion, but I really don't know what I'm doing. Some guidance would be appreciated. Somehow I thought this would be a little easier and I'm beginning to get intimidated.
    Problem Solver:
  • 12 Answers
When you are doing reverse at the beginning of a seam, make sure you are holding on to the two thread tales. They get pulled in and cause the problem you are describing. I hold them in my right hand off to the side until my seam is well established. Good luck
Posted on Jan 09, 2009
Problem with thread getting caught under bobbin holder
have you applied any lubricant to the bobbin holder the one that holds the bobbin? I would suggest using your manual and lube your machine. sounds to me like your mechanism is sticking.
Jun 08, 2015 | Janome Sewist 625e
How to controle loose stich
Check he tension on thread and on the bobbin. If you can see THE KNOT ON THE FACE OF MATERIAL then try loosening thread tension on top or tighten bobbin tension so stitch meets in the middle. May take a couple of tries to get it straight.
Mar 07, 2014 | Janome Sewist 525S Mechanical Sewing...
My bobbing thread keeps jamming
Make sure you are putting the bobbin in right side up. Some times it will do this if your needle size is incorrect to the fabric weight.
Jan 13, 2013 | Janome Sewist 500 Sewing Machine
Adjusting tension on overlocker
overlockers and sergers are annoying in that every time you change materials and threads they must be re-tensioned.
Get a scrap piece of material. Thread your machine correctly according to the instructions in your manual. If no manual most sergers are threaded, upper looper, lower looper then needles from right to left. Make sure you thread with the presser foot UP.
You want to balance the stitches Begin by adjusting the looper dials, you want them to meet right at the cut edge. Then adjust your needles. Keep doing test seams until you have them balanced. If you are a novice... try threading with each thread point having it's own color. That will help you identify which thread is giving you fits.
Have fun.
Oct 15, 2012 | Janome MyLock 634D Mechanical Sewing...
My brand new Janome Sewist 500 is making noise - it's clunking as I sew. I'm sewing two layers of cotton twill, stitch A, length 2, tension 5. Help!
have you checked to see if the bobbin is in the bobbin case correctly
is it still under warrenty? you might want to take back to the place you bought it from & let them check it
Mar 09, 2012 | Janome Sewist 500 Sewing Machine
I have a ramie, cotton, poly, spandex blend of material. It is pretty stretchy. I can't find the right tension combination on my Necchi royal series machine. How do I know if it ist the machine or the...
I would try using some tear away stabilizer under your material and stretching as I sew . If, you do not have interfacing try using some good old fashioned gift tissue paper. Make sure that you are using good thread, Sulky or Guterman, cheap thread is terribly linty and causes build up in your machine.
Oct 31, 2010 | Necchi 6030 Mechanical Sewing Machine
The bobin thread is not feeding smoothly. The thread on the bottom of the material is bunching up. I have adjusted the tension in every which way that I can but the problem persists.
you might check & see if the thread has come off the thread take up lever
take the bobbin out of the case & then put it back in
also check the needle it could have a burr on it or be bent or blunt
Oct 26, 2010 | Janome Sewist 525S Mechanical Sewing...
Cotton keeps getting knotted from the bobbin
upper tension is wrong or upper threading is wrong (problem is always on the other side of the bunched thread)
Jul 07, 2009 | Janome Sewing Machines
Janome Sewist 625e Logo
411 people viewed this question
Top Janome Sewing Machines Experts
Bargain Box
Bargain Box
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
