Question about KitchenAid Dishwashers
My kitchenaid model KUDSO2FRSS 4 control panel lights up heat is generated inside the cabinet but the water pump doesnt start
aborcass
  • 2651 Answers
SOURCE: Hidden control panel not accessible on dishwasher
no thats correct installeation of machine, its meant to be a "hidden" control. simply open the door, choose your options, press start and close door.
Posted on Feb 28, 2008
SOURCE: KUDS25SHWH1 Kitchenaid Dishwasher Control Panel Only CANCEL light on
I bought a control board for $127.00 figuring that was the problem but it wasn't. I called an appliance guy who came out and said its the touchpad that needs to be replaced. I ordered the touchpad ($325) since I already have to much invested in this dishwasher. I paid $1200 for it 8 years ago and its really a great dishwasher. My appliance confirmed that if it was the fuse-ling that you would not have any lights on.
Posted on Sep 03, 2008
SOURCE: My Whirlpool Quiet Partner 111
Disconnect your circuit breaker for 20 minutes and then reset. It should reset your dishwasher.
Posted on Jan 28, 2009
  • 12 Answers
SOURCE: Kitchenaid Dishwasher Control Panel lights - some don't light up
The problem is the control panel. You may have to shut the power off for a few seconds to reset the control board, then check to see if it works. If not, the control board has a break in the wiring or the keypad is no good.
Posted on May 13, 2009
  • 37 Answers
SOURCE: kitchenaid dishwasher, control panel is not
I don't know your technical ability, but there is a fuse located next to the control board inside the console, this is a good place to start. Kitchen Aid is good about putting tech sheets on the back of the kickplate and it should have wiring and diagnostic info there. Just be sure to put the sheets back so the next service tech to work on it will have them :)
Posted on Sep 01, 2009
Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
Aug 11, 2015 | KitchenAid Dishwashers
Have a Miele G1220SC dishwasher. It recently developed a strange problem: when switching it on ALL program lights come on and the machine starts taking water. after a while it stops taking water and starts...
follow this steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Jul 30, 2013 | Miele Dishwashers
I have a Fisher&Paykal DD6031 drawer dishwasher. Stopped running mid cycle. Lights flashing on drawer front green,red,yellow,red green,red,yellow . I don't know what that code means. On the inside Heavy...
follow this steps and fix it. GOD BLESS YOU
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Samsung DMT - 400 delicate light blinking
please follow this steps and fix it. God bless you
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 09, 2013 | Dishwashers
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Dishwasher Siemens /se64m359gb tap light comes on in red on main display,what does this mean?
Heating Element
Check Fault Codes
Drain Pump
Touchpad
Jul 08, 2013 | Dishwashers
Hi, I have a Kitchenaid KUDI01TJWH0 dishwasher that failed. Any of the front control buttons like Heavy-Normal-RinseOnly or even the HiTemp-EnergySaver .... when you press any of these, the corresponding...
Hi Your Problem is Probably The Control Panel. Not The Electronic Control. The Plastic Piece Across the Top of the D/W, Which Tells the Control What to do But You Must Realize These Parts Can Be Very Expensive. John H. Been in this Business 35 Yrs
Sep 29, 2010 | KitchenAid Dishwashers
Replacing the coupler so machine spins
Cabinet Removal
1. Remove the two small phillips screws on the front-lower portion of the control panel or in the rear corners.
2. Flip the whole control panel from the bottom, towards the back , so it is resting against the machine.
3. Remove the plastic tube at the water level sensor on the control panel.
4. Now go ahead and disconnect the spin switch wires from the panel.
5. Take off the big clips, one on each side, with a big screw driver at the top of the cabinet.
6. Slide the whole cabinet forward, by grabbing each side and pulling with your hands. I see you have the whole cabinet put to the side already.
Sep 01, 2009 | Whirlpool Washing Machines
I need to replace the pump on Kitchenaid clothes dryer
Removing the cabinet. UNPLUG the washer. There are two screws holding the control panel to the cabinet. Most models the screw are in front but, some models have the screws in back. They are on each end. Now raise the control panel up and let it rest on the hinges. Unplug the lid switch harness and locate the clips on each side (bronze in color) and release them.
Now the cabinet will lift off the frame and you can set it aside.
I hope this helps. Please let me knwo if I can assist you further.
Vic
Jun 19, 2009 | KitchenAid KAWS850L Top Load Washer
Whirlpool LSQ9500LQ0 will not drain water
Access to the inside on this washer will require taking off the whole cabinet.
1. Remove two screws on the back side and on each end of the control panel.
2. The whole control panel will then pull forward then flip it back out of your way.
3. There are a group of wires coming from the control panel going down to a single plug, unplug them from the main cabinet.
4. Remove the two large brass colored clips on each side.
5. You can now remove the whole cabinet.
The water pump is in front and secured only by two clips top and bottom.
Dec 26, 2008 | Washing Machines
Dishwashers Logo
74 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
