Question about Toshiba NB205-N310/BN Netbook
Problem with Toshiba NB250. It was getting slower and slower in spite of my running all kinds of programs on it to clean it up and defragment it, etc. Then a few days ago it started not wanting to let us in with the password, though it was intermittent. And finally yesterday it just went black. Nothing. I can start it up if I plug it in, but not with the battery power. Is this an indication of a battery problem only or might there be some other serious problem I am overlooking. Any Ideas?
kikoksky
  • 119 Answers
SOURCE: laptop boots up intermittently or screen freezes
basing on the information you have given here are the possible solutions:
remove any external device connected to your system (printer, external hard drive and others) if removing this does not work and still gets a blank screen with blinking cursor try to go to safe mode with networking. if successful try to download the driver for your video adapter.
when you try to start the computer , do get anything on the screen like a logo? when does the blank screen occurs, is it during the turning ON of the computer or during the windows xp logo appears on the screen?
a blank screen could be caused by the following: defective video adapter, corrupted video driver, defective memory, unknown device causing the issue like the hard drive, optical drive or other peripheral installed inside the computer.
try also using an external monitor
Posted on Jun 13, 2008
  • 17 Answers
SOURCE: screen stays black on startup of toshiba satellite L300
have you tried either switching between external and internal monitor usally Fn + F5 on toshiba or try plugging a monitor into the back and see if it displays.
if you get a display on the external monitor then its probably a screen or inverter fault if you donot get a display to an external screen then it is likley t be the graphics on the board itself.
hope this helps
Posted on Feb 22, 2009
Nate Dawg
  • 14 Answers
SOURCE: Toshiba Satellite a215-s7437 will not boot at all - black screen
It sounds like two possible things. One thing may be that your screen is not working anymore. Can you get a monitor and plug it into your port located on the side of your laptop? If your screen pops up on the monitor this tells us your screen is either in need of replacement or a connection may be loose.
If that is not the case......
Another thing is your hard drive may not be initiating. If you feel confident enough I would open the back where the hard drive is located and make sure the hard drive is not loose. Does it give you any beeping sounds when you turn it on? Can you count the number of beeps? This will tell you what the problem is on boot up. Also, is it a black screen with a cursor blinking?
Posted on Mar 14, 2009
benwabnick
  • 2404 Answers
SOURCE: Toshiba Satellite P205D-S7438 won't boot
You did everything that I would have done honestly, with the dvd drive not opening up and the fan not coming on, that would tell me the motherboard isn't regulating the voltage properly since neither is operating.
Either the CPU or the motherboard is bad at this point but I'm leaning toward the motherboard since a bad CPU would not cause a dvd drive not to open but a bad motherboard would especially if its not regulating the voltage properly cause of bad components on the motherboard. See if you can get the motherboard replaced if your machine is under warranty. If not then try to go thru Ebay since places there are less expensive.
Posted on Jun 02, 2009
male_28_cam
  • 1555 Answers
SOURCE: Toshiba Satellite a205 Battery Will Not Charge
You did what all should not have been done. your battery works as a buffer between high surge of electricity which comes through electrical supply i.e. it protects your smps from burning up. From your current position it seems your smps fuse has blown. If they have given one or else your smps itself has gone. I'll tell you for your future usage of battery. Whenever you get any electronic equipment with chargable battery you should never switch it on unless and untill you have charged it for continuous 24 hours. Never try to run such equipment directly through dc or ac power. Hope your fuse has gone its not costly.
Posted on Jun 19, 2009
TOSHIBA LAPTOP NB250 DRIVERS
You can download any orall the Windows device drivers for your model laptop from the Toshiba WEB sitefrom their download page. Make sure you enter the model of your laptop so youcan get the correct drivers. Please click on this link: - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp http://blitware.com/adpages/driverfetch/manufacturer/?manufacturer=Toshiba&gclid=CMOVxNCBx6ACFSgnawodoHNGbA
May 18, 2011 | Toshiba Computers & Internet
I need to rreboot my toshiba nb250 netbook but dont kjnow where to start.
Do you have a boot disk for it?
should be:
Toshiba Toshiba NB250 Windows 7 Driver Recovery CD Restore Disk
if not you'll need to one from the mfr.
Once you have that, you just put it in the drive and let it run.
Warning: you may need to reinstall win7 first.
Mar 16, 2011 | Computers & Internet
The laptop so slow loding
Run System In Safe Mode: To identify the root cause of theproblem, first of all restart your system, press and hold F8 key. Do thefollowing once you are on the desktop. 1. Right click on Computer.
2. Select Manage.
3. Click on Event Viewer in computer management.
4. Double click on Application.
5. Check for the errors.
6. Similarly double click on System and check for the errors.
7. Search for the solution to this problem. Now you are able to easily diagnosewhy Windows laptop starts up very slow. b> Limit your Startup list: A long list of programs in startupcan adversely affect the performance of your PC. There are some programsrunning in the background without knowledge of user that causes Windows laptopto start slower. To solve the problem, follow the steps given below. 1. Click on Start button.
2. Type "msconfig" in search option.
3. Double click on the file.
4. Click on Startup.
5. Uncheck all unwanted programs.
6. Close system configuration utility.
7. You are done. b> Uninstall unwanted program: Sometimes Windows laptop starts upvery slow due to unwanted programs hogging your memory. To fix this problem,below are some steps. 1. Click on Start button on thetaskbar.
2. Go to Control Panel.
3. Double click on Add or Remove Programs.
4. In the list of programs, select the program that you no longer needed.
5. Click on Remove button.
6. Repeat step 4 for all unwanted programs.
7. You are done. b> Scan System for Viruses: Windows laptop may start slower due to any virus onyour computer. To solve this problem you should scan your system with somepowerful antivirus program. b> Run Disk Clean Up: Running disk clean up utility isalso helpful to resolve slow Windows start up. To run disk clean up utility,here are the steps given: 1. Click on Start button.
2. Go to All Programs.
3. Click on Accessories.
4. Now click on System tools.
5. Click on Disk clean up. b> Defrag hard disk: 1. Click on Start button.
2. Go to Command Prompt.
3. Type "chkdsk" and press Enter. b> Defrag Registry: You mayuse some safe program such as McAfee secured RegInOut to fix registry relatedissues.
Feb 26, 2011 | Fujitsu Computers & Internet
We understand that your problem is: My desktop runs really loud and there is plenty of memory space available but it runs very slow. Its not consistent in the way it runs for example sometimes if I...
Format the Operating system and start fresh
Some useless programs or virus's may be slowing down your system
a reset will enable you to regain full speed of your pc again.
And don't forget even with loads of memory the CPU may be lacking to run most of today's programs all at once.
Sep 19, 2010 | Dell Dimension 4700 PC Desktop
I have a dell dimension 2400 which is getting slower and slower and slower. Have done disk clean up, defragged, etc. Plenty space unused on hard disk. Anti virus etc all up to date. Do you have any ideas?
I run into this type of complaint very often, and it's almost always caused by viruses or spyware. I would recommend that you download two free clean-up tools that are very widely used and trused.
MalwareBytes AntiMalware (MBAM)
http://www.malwarebytes.org/mbam.php (download free version)
Super AntiSpyware Free Edition
http://superantispyware.com/ (download free edition)
Install both programs using their default settings, run their respective updates from inside the program, and then run the full scans on both. You can run both scans at the same time, they'll both take a long time to run. Expect the scans to take an hour or more depending on how slow your computer is.
When the scans are finished, you'll get a list of "infected items". Follow the instructions for cleaning and deleting them, then reboot your computer. Once it comes back up, you may want to run both scans again just for good measure. If it comes up clean the second time, you should be all better for a while.
Sep 03, 2010 | Dell Dimension 2400 PC Desktop
My Toshiba Satellite R15-S822 has been working slower and slower
Hello.
There are 2 Windows XP software utilities that will help speedup your system.
Go to and select: Start - Programs - Accessories - System Tools - Disk Cleanup and run Disk Cleanup.
Then, select:
Start - Programs - Accessories - System Tools - Disk Defrag and run Disk Defrag to speed up your system.
Also, you may have malware or spyware. Download, install and run: Malwarebytes (from Malwarebytes.com) and Spybot (from Spybot.com).
Hope this helps.
Nov 19, 2009 | Toshiba Satellite R15-S822 Tablet PC
Each day my computer seems to run slower and slower.
Run the commands in your Accessories and also don't forget you need to Defrag and run an Anti-Virus software. The proper programs are under Start>All Programs>System Tools>Disk Cleanup and Defrag. When the housekeeping is done, if your computer is still running slow then the best thing you can do is upgrade the amount of RAM. That will make a noticeable difference.
Please rate this solution.
Jan 09, 2009 | Compaq Presario V5005us Notebook
COMPUTER RUNS VERY SLOW
cn i hav the specs of your pc, and your hard drive free space, and your OS,,
pc's performance and stability depends on your memory, programs that you run, video card and processor,, you might want to check also your free space, try defraging it and disk clean up its a big help
Sep 09, 2008 | HP Computers & Internet
Overclocking!!
If this a Notebook/laptop, please do not try overclocking, it may damage CPU/other components..
Jun 25, 2008 | Toshiba Satellite A45-S250 Notebook
Toshiba NB205-N310/BN Netbook Logo
18 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
