Question about HP Officejet J5780 All-In-One InkJet Printer
Can I wirelessly network my HP Officejet J5780 printer?
I tried to connect it to my network, and it does not work. Is there a compatible print server available? Or, can I get an adaptor that will connect the USB port to the ethernet?
Thanks.
Patrick
  • patrickq Jan 05, 2009
    Thanks. I am trying to use my printer wirelessly with my laptop, which is the only computer I have. Is this possible? How can I choose the correct print server, if I go that route? Thanks.
What you are saying will not work . The J5780 only connects with a USB. It does not have a J45 connection. So to play with the "built in network server" would do nothing. You would have to have some way to convert the USB to a J45 so he could hook it to his Wireless Router. His only alternative is to hook it to another computer that is used as a Wireless Slave that is shared or to get a print server. Hower, Belkin does make a wireless USB Hub that converts 5 USB's to J45 and can be hooked to you Wireless Router. It also has a built in Print Server. You can take this device and instead of hooking it J45 to the Router you can hook it to a linksys Bridge and now the USB HUB from Belkin becomes completely wireless. And has a Print server to boot! The model number are Belkin "Network USB Hub" and the Linksys WET54G.
Since the Hub connects to the USB devices and then converts them to a J45, to link to a network you can hook it to the llinksys device and convert it to a wireless network usb hub. It also has a print server built in.
It works. I own the same printer all in one and if you search on the internet you can pick up both devices on the cheap.
Posted on Jan 16, 2009
    Scholar:
  • 97 Answers
First, since this has a built in network server, you should try to get it going. My reasoning is if you cant get the built -in server to work you will really have problems with a third party device.
So I would first visit www.hp.com go to drivers and downloads and get the applicable software and retry the installation.
Now if you are looking for a simpler route, connect the printer to a PC via USB. then right-click on the printer in "printers" in the control panel. you should see the Sharing option. do this, enable sharing and give it a name.
Now from the networked PC you wish to also use, go to add printer wizard in control panel. Choose the Networked option and let windows browse for the printer. If found select it and it should self install. Of course this method requires the Host computer to remain on for printing to occur.
And finally if all else fails you CAN get network print servers. They are a bit testy in some cases and should only be used when no other option is available.
Good Luck!
-FW
Posted on Jan 05, 2009
Use STARTECH usb b to usb a adapter with the STARTECH compact usb to fast ethernet adapter, and then your ehternet cable to router. seems very simple to me with no extra hardware to install or get in the way. all these items can be found on ecost.com for the lowest prices i've ever seen. part #"s 2515029 and 47115788 respectively. you can even get ethernet cables and a whole lot of other stuff on there. nothing but happy with ecost.com.
Posted on Feb 05, 2010
Can I wirelessly network my hp pec 1350 with a belkin wireless g all in one print server
The Belkin Wireless G All-In-One Print Server lets you easily add an all-in-one printer to your wireless or wired network. It features 802.11g technology that makes sending print jobs faster than ever, and includes a memory buffer that handles your graphic jobs effortlessly. The Print Server is so easy to install that you'll be printing in minutes. Simply connect your Print Server to your Belkin Wireless Router and run the Belkin Easy Installation CD. Next, attach your USB printer to the Print Server and load yourprinter drivers onto your computer. You are now free to print, scan, fax and readcard media* wirelessly from around the home or office. The Print Server also works flawlessly with wired networks through its integrated Ethernet port. Compatible with most USB, network-ready printers, the Wireless G All-In-One Print Server from Belkin delivers even your most data-intensive print jobs with maximum speed and reliability.
*If your all-in-one device has a card-reader slot.
Instructions:http://www.belkin.com/pyramid/documents/external/F1UP0002_EN_QIG.pdf
Nov 21, 2012 | HP Psc 1350 All In One Printer Scanner...
Hello I would like to buy a compatible print server for my hp officejet 4255 all in one, because I want to share it among several pc-desktops connected to a router in wi-fi. Netgear says they do not...
What you want is the HP 2101NW
Unfortunately, this product has been discontinued by HP themselves, but you may be able to find a store that has old stock, or find one on EBAY.
The easier solution is to share it across the network from a workstation that is always on, or make a print server workstation out of an old PC or laptop that will do nothing but share the printer across the network.
You can buy an older PC to use for this function cheaper in many cases than buying a standalone print server. I did this myself for ages using a laptop I picked up for $50. The laptop wasn't good for much more than a print server, but as a print server it worked flawlessly. The laptop would wirelessly connect to the network and was USB wired to the printer, which it shared across the network.
NOTE: you will be limited to PRINT ONLY under these situations.
If I recall correctly, the only way to have full functionality is with the 2101NW which as I said is now discontinued, but was an amazing product in it's day!
Jun 24, 2011 | HP OfficeJet 4255 All-In-One InkJet...
I have a WIFI and I heard that I can connect my HP OFFICEJET 5610 ALL IN ONE into wireless using my WIFI connection. Please assist me. Thanks a lot, Toha ****
hi tohafaniwang
the HP OFFICEJET 5610 doesn't have an internal wireless adaptor therefore you would not be able to connect it wirelessly to your wifi network. Although there is an option to get a wireless LAN routher/printserver wherein you would connect the printer to the wifi print server/router using the usb 2.0 cable. using this you would be able to setup that all that connects to your wifi network would be able to print to your printer.
Hope this helps
janc30
Feb 08, 2011 | HP Officejet 5610 All-In-One InkJet...
HP J5780 - Using scanner with print server
no, print server is just that, print server is only good for printing. I don't know if there are a device you can use for all-in -one office machine. I am looking for one myself.
May 29, 2009 | HP Officejet J5780 All-In-One InkJet...
HP Officejet Pro L7580 Wireless Connection
YOUR PRINTER IS NOT A WIRELESS PRINTER IT CAN BE USED USING AN ETHERNET CABLE TO THE PRINTER FROM THE ROUTER
STEPS
SETUP>>NETWORK>>RESTORE NETWORK DEFAULTS
SETUP>>NETWORK >>WIRELESS RADIO>>ON
CONNECT THE ETHERNET CABLE FROM THE ROUTER TO THE BACK OF THE PRINTER.
SETUP>>NETWORK >>PRINT NETWORK CONFIGURATION PAGE
INSTALL THE PRINTER
SELECT WIRED CONNECTION
AND INSTALL
IT WILL PRINT.
OR IF YOU WANNA USE AS WIRELESS YOU CAN USE WPUK (WIRELESS PRINTING UPGRADE KIT)
FROM HP.COM HOPE IT FIXYA
Apr 25, 2009 | HP Officejet Pro L7580 All-In-One InkJet...
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
yes. this printer can be use for wirelss connection, so it can be use with wired jetdirect. however, you are going to need the web jetadmin from hp in order to reconfigure the IP address for the jetdirect.
you can download a copy form HP.com
Jan 13, 2009 | HP Officejet J5780 All-In-One InkJet...
Documents not printing
Hi How to check the print server is in the wireless network or not!! Check under the Router Setup page Router's ip address... Check if you are able to ping the Print Server Ip address....Since it the router will assign a ip address from DHCP range.. If you are able to ping the router's ip address and the print server ip address then the print server is in the Wireless LAN... Try the following steps. 1. Go to run and type "cmd" press enter 2. type ipconfig. 3. Check the range of ip address...if its 192.168.0.XX 4. Try pinging that ip address.. 5. If able to ping the router and print server.. Then the wireless network is fine... Somehow some of the printer's don't work with some of the print servers.. Check if D-link does support the printer or not!!!! for this particular model of the router...
May 30, 2007 | D-Link DP 301U (DP-301U) Print Server
HP Officejet J5780 All-In-One InkJet Printer Logo
3,684 people viewed this question
Ben Johnson
