Question about Frigidaire Affinity ATF7000E Front Load Washer
Affinity Frigidaire washer 134766000
Wont spin
SOURCE: Frigidaire Affinity Washer beeps & won't spin
The drain filter is clogged. I had the same problem. There is a filter inside the "drain boot" (black) that comes from the drum to the drain pump. Mine was completely clogged with money, lint, etc..
Posted on Oct 19, 2008
localwonder
  • 6784 Answers
SOURCE: my frigidaire affinity wont start
Yes, the original issue was the control from the beginning. the control is damaged and it cannot register the latch at this point. this is necessary and , it will fix the issue.
Posted on May 29, 2009
hh0405
  • 77 Answers
SOURCE: Frigidaire Affinity washer: Straining water pump? Humming.
more than likely the pump is clogged if you pull the the washer out away from the wall and then lean it back to get under it there is a hole to access the under side you can reach through to the pump then disconnect the large hose that goes from the tub to pump reach down inside of this hose remove the cup that has debris in it and clear it out remove the debris and reassemble the washer
Posted on Apr 03, 2010
SOURCE: ltf6000es1 frigidaire affinity won't spin belt
How do you test the door lock Switch?
Posted on Apr 27, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a frigidaire affinity front loader washer
There is an auxiliary switch in the door lock and switch assembly that is activated at the end of the wash cycle for the machine to advance to the spin cycle. This is a safety feature to prevent the door from opening during the spin cycle and the machine will not spin unless the switch is activated. The machine works except advancing to the spin cycle and this signifies that the auxiliary switch cannot be activated and the door lock and switch assembly is faulty. Replaced the door lock and switch assembly (part #131763202) to address the issue.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then pull it away from the front panel.
Take the door lock and switch assembly out of the machine. Disconnect the electrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Posted on Jul 13, 2010
Why my frigidaire affinity wont spin
Good Afternoon Iliana, thank you for allowing me to assist you!
If your washer does not spin, often it is because your washer cannot properly drain and dispose of the water and detergent solution. Does your washer make a humming noise? If so, the drainage hose/pump may be clogged and needs to be cleaned. If not, your washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Dec 14, 2013 | Frigidaire Affinity ATF7000E Front Load...
My frigidaire affinity wont start
May 29, 2009 | Frigidaire Affinity ATF7000E Front Load...
My washer wont spin
Your symptoms that indicates a broken motor coupler. If your washer will drain and fill but has not agitation action or spinning action that would indicate a broken motor coupler. The motor coupler links the drive motor to the transmission.
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
Won't spin.
wont spin because the unit is not drainning water...wont spin with water in it must drain first...check drain hose for kink,,,check waste pipe for blockage...and than check pump...onthejob
Dec 15, 2008 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Affinity ATF7000E Front Load Washer Logo
474 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
