Question about Garden
No spark,john deere z225 - Garden
  • 109 Answers
SOURCE: my 2007 john deere eztrak z225 wont crank even
If i understand you right the little square piece is the solenoid, and it should be replaced if it is making a buzzing noise
Posted on Apr 26, 2009
  • 9 Answers
SOURCE: john deere mod 345 no spark
first find the wire that is grounded to mower to ignition
and check that it is isolated if mounted on some plastic and disconnect it
if it runs to start switch check wire for cuts also
most common problem is the coil located under the top plate held on by 4 /5 screws on sides.
remove top and follow plug wire back to coil
you can clean the curved edges of coil that are against motor {magneto} with sand paper and clean mag
remove plug and lay threads securely agains frame and check for spark {hold by wedging not by hand as you can get a jolt!}
Posted on Aug 20, 2009
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
  • 14 Answers
SOURCE: John deere Z225 riding mower
measure with a valt meter and see what your voltage is at the battery . now measure what you have for volts at the soleoid. then check to see if you are getting 12 volts to the single peg on your soleoid, usually a whitwe wire. If your not getting voltage to this wire you probably have a safety switch problem. If you are getting voltage here check to make sure you are getting voltage at the starter motor. If your getting voltage there you may have a bad ground at the starter motor or the whole motor may need to be grounded to the frame.
Posted on Sep 12, 2011
  • 6468 Answers
SOURCE: I have a john deere 140. I'm not getting any spark
check the points and condensor
Posted on Apr 16, 2012
I need a wiring diagram for a John Deere Z225
Here is the link for john deere z225 zero turn wiring diagram
I hope this helps you.
https://images.search.yahoo.com/yhs/search;_ylt=AwrTccx4EqNVkAQAphwnnIlQ;_ylu=X3oDMTEzbHNxNnYwBGNvbG8DZ3ExBHBvcwMxBHZ0aWQDRkZVSUMwXzEEc2VjA3Nj?p=Wiring+Diagram+For+a+John+Deere+Z225+Zero&fr=yhs-mozilla-002&hspart=mozilla&hsimp=yhs-002
Jul 13, 2015 | John Deere EZtrak Z225 Zero-Turn Riding...
I have a John Deere Z225 zero turn engine cranks but will not fire spark plug wet with fuel
as plug wet, either flooded, or not sparking, remove plug connect top lead and touch plug to metal, see if it sparks when turned over, if it does, with a good spark, flooding, check choke, if weak spark, check adjustment of points.
Jul 29, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
Un able to turn off z225 mower using key switch
You need to replace the key and key chamber as your one may be faulty
Jul 22, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
John deere z225
Either timing is off or you may have turn key off with engine hot and running in high speed. Always return engine to idle for at least 30-45 seconds before turning engine off.
Jul 19, 2014 | John Deere EZtrak Z225 Zero-Turn Riding...
I need a wiring Diagram for a John Deere Z225 Mower.
Call john deere customer support they will supply it to you
Jan 11, 2014 | John Deere Riding Lawn Mower. EZtrak Z225...
Manual for a z225 john deere zero turn
my z225 right rear wheel feeling like it locking up about every 20 feet
Oct 03, 2012 | John Deere EZtrak Z225 Zero-Turn Riding...
Free online John Deere Z225 repair manual
You can find your manual on amazon... take a look here Amazon com John Deere Z225 manual. I hope this was helpful. cheers
Jul 08, 2012 | Garden
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
