Cant connect to network. another computer connects.
SOURCE: Wireless network connection on IBM Thinkpad
Ok when looking at your question i became very currious as to the answer myself so i did a litttle research and i think maybe the info on this page here: http://www.eggheadcafe.com/software/aspnet/33307589/certificate-required-to-c.aspx
could be of some use to you . even though the link describes a diferent network adapter the information there is about the same exact error on a router of the same type
I hope this information helps ... if it does not then let me know and i will find some more answers since i used to have the exact same laptop that you have now R40
SOURCE: Wireless question - Thinkpad R51
Just go to the network connections and disable the wireless whenever u dont need wireless..... and check the ethernet drivers are installed or not..from device manager
U can download new version drivers from ibm site..
thanks
mohan
SOURCE: computer says IBM wireless adapters (802.11 or bluetooth) not ins
Hello Kangarootrib,
Since you bought the ThinkPad second hand and the software installation disc did not come with it, you should go to the IBM ThinkPad manufacturer's web site. Once there, look for your specific model and search for the proper drivers and download and install them on your current computer. Drivers are basically small bits of code that tell the operating system how to communicate with hardware devices, which when you purchase products new come with a CD that contains these instructions for your computer to be able to communicate with the device. Hope this helps and please let us know if you need further assistance.
P.S. If you would not mind, could you please rate my help as I would really appreciate it. Thank you
SOURCE: IBM Thinkpad will not turn on wireless connection
1st go to MY COMPUTER, RH CLICK-PROPERTIES,HARDWARE TAB, DEVICE MANAGER,NETWORK DEVICES. CLICK ON THE + TO OPEN THE INSTALLED
NETWORK CARDS. YOU SHOULD MOST LIKELY HAVE 2 LISTINGS 1- YOUR ETHERNET PORT
2-YOUR WIFI CARD. THERE SHOULD NOT BE AN EXCLAMATION POINT OR A QUESTION MARK, EITHER INDICATING A PROBLEM. IF YOU DO HAVE EITHER LOOK AT THE DRIVERS 1ST AND THE ACTUAL HARDWARE 2ND. IF BY CHANCE YOU DONT SEE YOUR WIFI CARD
THEN TRY REMOVING IT AND REINSTALLING IT. TURN ON YOU COMPUTER AND SEE IF
XP RECONIZES IT "NEW HARDWARE FOUND". YOU HAVE TO SUPPLY A DRIVER FOR IT AS
WELL. GOOD LUCK
SOURCE: IBM THINKPAD T43. I can find the switch for my ibm thinkpad T43
Are you sure you have a wire card installed? If so, then try this:
Note:
If the card has a exclamation mark over a yellow background, then this
is an indication that the card is experiencing a problem. Go to Driver
download step 5.
It is possible to disable the transmitter of the wireless card without Device Manager showing any problems.
Note: Follow the instructions provided to enable wireless card.
If you double-click the previously mentioned system tray icon, the
configuration utility of the wireless card will appear. This utility
will be able to show the status of the wireless card, showing what
channel the card is using and what signal strength is being received.
It may be difficult to maintain a connection if signal strength is low
due to either interference or distance. For example, interference can
be caused by 2.4GHz cordless phones, other Access Points in the area,
and physical structures such as load bearing walls or metal partitions.
Note:
The utility can be used to configure the wireless card settings, but if
using Windows XP Zero Configuration or Access Connections, you will
need to use those programs to actually configure the wireless card as
they will overwrite the setting of the utility.
