The saw is a 41, as standard it ran a 15" bar and chain, in the UK it ran a .325 pitch, however in the US, it ran a 3/8 pitch chain, as you should change the sprocket if fitting a new chain, i would put it on .325 if it is not already, the sprocket is part no. 530069342, the 15" chain is 501840664, and the guide bar is 508926164 these are .325 pitch 050 gauge and 64 drive links, this combination will cut much faster than the 3/8 low profile combination.
Check out master parts, they have remington chainsaw parts, you'll need the model number of your unit ( usually 8 digits long). 800.446.1446 or www.masterparts.net. I hope this helps you!
Here is a link to instructions for EL-8 series saws ... http://www.desatech.com/pdf/115499-01_EL8_Series_Chain_Saw_Tension_Adjustment.pdf. For series LNT-2, LNT-3,EL-1, and EL-7 according to the manufacturer... "WARNING: The cutting edges on the chain are sharp. Protective gloves should be used when touching the chain. Unplug the chain saw from the power supply. Allow chain to cool. Loosen the guide bar nuts until they are finger tight. Ensure the adjusting block is in the adjustment hole in the guide bar. Turn the chain tensioning screw clockwise to increase tension. Turn the chain tensioning screw counterclockwise to decrease tension. Check for proper chain adjustment by pulling down on the chain at the bottom center of the guide bar. You should see no more than a ⅛ inch gap between the chain cutting links and the guide bar. The guide (or drive) links should not come out of the guide bar grooves. The chain should rotate freely around the guide bar. If it does not, chain tension should be decreased. When the chain is properly adjusted, tighten the guide bar nuts securely." On the M series if your chain keeps slipping off your sprocket... The Sprocket cover tab (located on the round part of the sprocket cover) isn’t inserted into the saw body tab slot. I hope this helps you!
The el-7 is the series number, so I would need the model off the unit and I can give you the part number. You also call call 800-446-1446 or go online to www.masterparts.net with your model number and purchase your part from them.They should be able to help you. I hope this helps...
