Question about ESP B Series B155 Electric Bass Guitar
Bass Guitar Wiring Diagrams for esp LTD 4 string
3 Suggested Answers
Kree8iv
  • 192 Answers
SOURCE: Not getting enough distortion(esp ltd ax-260)
It's not your pickups. It would be nearly impossible to loosen a wire inside of your guitar by having even heavier than your amp head drop on it. It is most likely your volume pot. The post, if hit hard enough, can virtually distroy your pots. Another possibility could be your jack, al though considering where it's located on your guitar, it would be very hard to damage it by having something drop onto it.
There is little else that could be the problem. Hopefully you didn't damage your guitar too badly. If the guitar was in front of me, it would be a relatively easy diagnosis.
Fortunately, volume and tone pots are inexpensive, and if you're handy with a soldering iron (or you have a friend that is) it is an easy install with four to six solder points, depending on your configuration. I don't want to assume it's a stock setup, but when you take off the rear electronics cover, you will immediately see what configuration you have.
If you have possibly damaged the pickup bobbins (assuming you have the stock humbuckers in your guitar), you would be able to see the damage, It would either look damaged,or work correctly. As you know bobbuns are simply wound wire, and that's not easy to damage. Plus your strings provide a minimal amount of protection, unless your amp head slammed it very hard. Start by replacing the volume pot. Cheapest parts first. There is no way to test the pot with anything like a potentiometer, because there is virtually no voltage that passes through the pot. Additionally, unless you have active pickups, your pickups cannot be either. If you do have to replace your electronics, you can find a large variety and even upgrade your parts by searching eBay. The good thing is that you havce a guitar, and guitar parts are abundant, relatively cheap, and most people change out electronics just to achieve a different sound.
If you are so inclined, most good guitar shops will diagnose your problem for cheap and apply the cost of the diagnosis to the cost of the repair. Good luck, and I hope I have given you some information to work with.
Thank you for using FixYa
Posted on Jul 19, 2009
KeithOB
  • 59 Answers
SOURCE: how to change strings on
http://www.youtube.com/watch?v=A_q2wleWRvw
heres 1 of many youtube videos that explain the way to change strings on a floyd rose. first try might give you a lil trouble but you'll get the hang of it. Good luck!
Posted on Sep 01, 2011
How do I rewire the pots on my LTD AX-141 4 String bass guitar. Someone has messed up the wiring thank you
There are two sites I go to for most of my guitar/amp needs. Youtube and the second is StewMac.com and look in the Trade Secrets and How to section. It may not be the exact guitar/bass but it's a real good jumping off point.
I just opened a youtube site and searched "how to rewire a bass guitar" and received 8690 how-to videos.
Good luck on this project.
Jan 31, 2018 | Bass Music
How do I rewire the eq and volume pots in an ESP LTD 6 string bass?
This website has tons of wiring diagrhams, and if you look down the righthand side of the page, you'll see a link where they will design and schematic you like-
http://www.guitarelectronics.com/category/wiring_resources_guitar_wiring_diagrams/
Mar 01, 2015 | ESP LTD B-206SM 6-String Bass
My boy has an esp ltd ax 150 bass which has broken E strings at the bridge since new almost 1 a week the bridge was modified by a Luthier which worked for a small amount of time then the problem came
You friends bass has a burr on the saddle. take a small fine file and go along the pacth of the string...Go over the saddle and slowly file lightly..This should get rid of your problem...take it to a service center if you arent comfortable doing this
Apr 08, 2013 | ESP AX-414 LTD 4-String Electric Bass...
We need to change battery
The battery should be located in the control cavity of the guitar. It is in the back of the bass. Usually 4 screws holding it on. Inside your 9v battery will be located. Good luck
Feb 22, 2013 | ESP LTD Surveyor-414 Electric Bass Guitar
How to change strings on an esp ltd alexi 200 guitar
Aug 31, 2011 | ESP Ltd Alexi 200 Electric Guitar
Hey my ax260 strings rattle alot mainly the bass strings? and every time i touch the coil tap knob a ugly sound comes from the amp its not even a year old yet and never been knocked over or droped could...
Strings "rattling" is usually guitar setup. This has to do with string height and POSSIBLY the neck truss rod. For the latter, have a guitar shop set it up for you. Hum from touching a knob is likely a broken ground wire in the cavity of the guitar. Also view videos on YouTube search "Guitar setup"
Apr 27, 2011 | ESP Ltd EX-50 Electric Guitar
Wiring for a dean edge 4 string with one soap bar pickup
You might find it at http://www.mediawebsource.com/guitar/pickup.htm If you can figure out what brand the pickup is you could check the manufacturers site. http://www.guitarelectronics.com/category/wiringresources/ has original factory wiring diagrams for guitar and bass for various pickup manufacturers. Hope this helps.
Jul 10, 2009 | Dean Edge 4 Bass Guitar
ESP B Series B155 Electric Bass Guitar Logo
264 people viewed this question
Top ESP Music Experts
Arora Singh
Arora Singh
Michial Gueffroy
Are you an ESP Music Expert? Answer questions, earn points and help others
