Question about Sharp Office Equipment & Supplies
Fax is received is very dark and almost unreadable
Hi When I send a fax on my Sharp Fax / Phone (FO-155), the receiver gets a very dark, hard to read copy. Should it simply be a matter of cleaning the print metal strip? The machine is probably about 10 yrs old.Thanks Guy
  • guyrguyr Jan 05, 2009
    Thanks FW for your quick response. Tried to print a copy as you suggested and it was very dark in parts so good news is we know the problem is the scanning imager, bad news is I'll need to get a new fax!
    Thanks for saving me from wasting any more time.
    Regards
    Guy
What is the maximum life of FAX Machine model no. FO 1530 form surcharging date.
Posted on Jul 03, 2013
    Scholar:
  • 97 Answers
You can try using the menu to lighten the fax, but if all received faxes are dark, you may be experiencing a weak scan light. try making a copy instead of fax (which essentially is a fax printed to yourself) if also dark, its certainly your scanning imager that's failing. If that's the case I would recommend replacing the entire machine. Parts are expensive, and its a difficult to service part yourself. Also you may find that toner costs alone may pay for the replacement machine over this unit.
-Good Luck!
-FW
Posted on Jan 05, 2009
Fax machine not working Sharp FO-155
We need to have more info on what do you mean not working.
Is it dead, no power, is n ot sending/receiving/ no dial tone.?
Apr 14, 2008 | Office Equipment & Supplies
Sharp FO-2081 clear memory full
enter simulation mode using # * c * after you are in run test command 66-10
Apr 08, 2014 | Sharp FO-2081 Copier
Sharp FO-4700 Fax Not Received Even Though OK Fax Confirm Given
It's gone forever, once your machine received a EOT (end of transmission signal), your fax machine thinks it was received OK and clears it from memory.
Oct 28, 2009 | Sharp FO 5700 Plain Paper Laser Fax
Need operation manual for Sharp FO-1460. Can
Turn your fax off then back on. If the problem persist try a memory clear. Press function 9 * 8 # 7 then press start , then keep pressing your # key until you see memory clear then press start. You will lose #'s that are stored. If the problem still persist try another phone line(analog line). This problem will not be in your owners manual, but if you still need one I would do a google search.
May 17, 2009 | Sharp FO 1460 Plain Paper Thermal transfer...
Receivers complain that the fax is light/unreadable
More than likely (since the problem is with sending and copying only) the mirrors inside the fax machine need cleaning. However, depending on what type of fax machine this is, this could be a pretty involved job. If you are pretty comfortable with taking covers off, you might try it, but if its a pretty expensive fax machine, I would call a professional.
hope this helps!!!
chad
Oct 08, 2008 | Sharp UX 510 Plain Paper Thermal transfer...
Sharp fax machine
I keep getting a "Line Error" canot send or receive a fax. I have a SHARP UXB700
May 12, 2008 | Sharp FO 3150 Plain Paper Laser Fax
Problem with Sharp FO-1460
What happens when you make a copy?
If that is blank, you have a bad scanner.
Jan 09, 2008 | Sharp FO 1460 Plain Paper Thermal transfer...
Sharp FO-4450 errors when sending to Brother Intellifax 475-0E
Tell me more. What model Brother? Did you call them and make sure the Brother is set to auto receive?
Aug 09, 2007 | Sharp FO 4450 Laser Fax
226 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
