Question about Bissell 6594 PowerForce Bagless Upright Vacuum
Vacuum hose has little suction.
The vacuum itself seems to work fine. But the vacuum hose seems to have very little suction and barely picks up anything. I cleaned all the filters that were removable and the problem still persists. Help.
  • 1 more comment
  • Anonymous Feb 22, 2009
    my bissell 3537 doesn't **** up duct theres spinning
  • Anonymous Mar 14, 2014
    Little to no suction
  • Anonymous Mar 15, 2014
    No suction - the hoses, filters etc have all been cleaned.
  • 107 Answers
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Posted on Jan 05, 2009
  • 281 Answers
Take the dirt cup out and at the bottom the filter is inside,twist the bottom so it comes off,twist the top of the black plate and it will come off.take the foam off and clean with water then take a brush and in up and down strokes clean the filter while running water over it,it is water friendly.lay the foam between paper towels and dry.up inside where the dirt cup goes there is another filter reach up twist and pull down.that should just have fins on it,clean that to and wipe dry.put the dirt cup back in without the filters and see if you have suction .i'm sure you will.let the paper filter dry before putting it back in.i hope i was some help to you.please leave feedback
Posted on May 04, 2009
Eureka Optima Lightweight suction weak on bare floor, hose only works when dial is turn to floor?
I think it is normal. My favorite setting is the dial is turned to bare floor. If you set your vacuum to hose, then you need to adjust the height (do not set the dial to the bare floor).
Feb 21, 2014 | Eureka Vacuums
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
Apr 08, 2010 | Lindhaus Diamante 300 Upright Vacuum
Vacuum not picking up dirt
The neck in your power head is likely clogged. Disconnect from the wand and look inside. Also check the wand.Since you have suction on the bare floor the hose is likely not blocked.
Sep 11, 2009 | Kenmore 22512 Bagged Canister Vacuum
Vacuum doesn't work on bare floors!
does it have a bare floor setting that shuts off the beater bar? if the brush is revolving it will scatter dirt instead of picking it up
Aug 23, 2009 | Dirt Devil Reaction Twin Cyclone Upright...
Durt Devil upright 12 amp Vision Vacuum Cleaner
If there no blockages in the hoses, then the next thing to check would be any filters in the vacuum. When these get clogged, you will experience this problem.
Dave
May 13, 2009 | Vacuums
Rainbow vacuum-water not spinning
Remove hose and turn on the unit with nothing on the intake - see if it helps - feel the suction with hand.
a) If it works fine without the hose - look for a clog in the hose, wand or the nozzle
b) If the suction is weak even without the hose:
Clean the separator,
If this is e-series or E2 Rainbow - remove HEPA and try vacuuming without it (sometimes it is too dirty so stops good airflow). New HEPAs HERE.
If this is SE Rainbow - remove exhaust cap and if there is a sponge - take it out
Still no luck - It has to be serviced
Good Luck,
Rocky
Feb 15, 2009 | Rainbow 75th Anniversary Canister Vacuum
At the top of your wand, do you have a plastic swivel that cover a hole in the wand? This is for when you are cleaning curtains, and if that is open, or cracked you will loose suction there... also check your hose for cracks, or breaks. If it were in the shop I would put a gauge on it... normal suction is about 80-95 inches of water lift at the end of the hose. Once you have check each section of the hose, and wand, check the housing for cracks, a missing gasket (Very Good Reason For Lack Of Suction) As to your Filter, how long have you used that one filter, you can clean them for a while, but once a paper filter gets full of FINE dust you won't get it all out, you will have to replace the filter itself at that point. I hope this was helpful.
Jan 19, 2009 | Kenmore 22512 Bagged Canister Vacuum
Poor suction
Check the inlet down by the brush roll, make sure it is open, if it is then the hose itself must have a clog. If the hose comes off, drop something like a marble in one end and see it it comes out the other end, if it doesn't then you have a clog.
Jan 10, 2008 | Dirt Devil M1100009 Reaction Soft Touch...
Dyson DC07 hose has no suction
Just resolved the same problem...couldn't find a blockage anywhere, but pulled handle out of hose and extended hose as far as possible upward. Aha! There was blockage in the hose at the very bottom where the flexible hose meets the rigid part.. There is a lever which releases the entry to the bottom of the hose. A pencil, lots of coins, a crumpled receipt and general dirt were stuck. Easy to clean and now it works like new again.
Nov 08, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Bissell 6594 PowerForce Bagless Upright Vacuum Logo
417 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
