Question about Admiral AAV7000A
Admiral makes rattling noise during spin
My admiral washing machine just began making a rattling noise during the spin cycle. The only other thing I have noticed, is lately within the past two weeks on at least two separate occasions the washer finished the cycle, but was left full of water. I had to switch it back to spin to drain and spin in order to dry the clothes. Any ideas of what could be going on here? Thank you.
  • happilyevera Jan 05, 2009
    We have checked and believe you are correct that it is the pump sleeve. The pump sleeve has come out and is touching the bottom of the machine (grinding a circle around it). How do we replace that or repair it? Thanks
  • 530 Answers
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Posted on Jan 05, 2009
  • erica graber Jan 05, 2009
    very simple you can remove the front panel by getting a putty knife locating the top of the cabinet useing a flash light you will see 2 clips pop the clip[ and pull out. or it could have 2 screws at the bottom of the front panel remove those and and pull up and off. or if the pump is in the back pull the unit out and there is a little door that you can open with i believe 5/16 socket. remove the back panel and you will see the pump. you can replace it this way. it's very simple just remove the hoses and the bolts. then install the new one
My admiral washer does not work on wash cycle. It will rinse and spin on any cycle but wash
hi Marilyn.
this is what i have found but not sure if this will help you out,if not go to the link at the bottom and see if it helps you out.
Step 1
Make sure the washer's cord is plugged in to a functioning outlet if the Admiral washer won't fill with water. Check your circuit breaker to make sure the power is on and reset it if necessary. Reset the dial and start the washer again. Turn both of the washer's faucets on to full power. Untangle any inlet hoses to remove clogs. If this doesn't work, your hose filter screens could be clogged. Disconnect the hoses from the washer and clean the screens of any residue.
Step 2
Close the washer's lid completely if the Admiral washer will not agitate. The washer will not start if the lid is open. Restart the washer by setting the control dial to the desired cycle. Momentary pauses during cycles can be expected. You may need to wait a minute or two to see if the washer starts. Check the circuit breaker to make sure the washer is getting power. Reset the circuit breaker if necessary.
Step 3
Check and reset the circuit breaker as above if the Admiral washer will not spin or drain. Untangle any of the washer's hoses to allow water into the machine. Check your drains for clogs that may be preventing water to move into the washing machine. Close the lid and restart the washer. The washer will not start if the lid is not completely closed. If there are excessive soap bubbles in the washer, the washer may have locked up because of this. Wash the load again without adding detergent.
Step 4
Rearrange the laundry so it is evenly distributed if the Admiral washer stops or if laundry is still wet at the end of a cycle. Untangle any laundry from the center post in the wash tub. Select the correct water level for the amount of laundry. Select a normal spin cycle for jeans, towels or other heavy loads. Close the lid and start the washer.
Step 5
Check the hoses to make sure they are tightly connected to the Admiral washer if it leaks water. If they are loose, tighten them with a screwdriver. Make sure the drain hose is secured to the drainage area. Avoid putting too much laundry in your machine or soaking laundry for over 30 minutes.
Step 6
Make sure the Admiral washer is on a level plane if it is excessively noisy. If it is not on even ground, move the washer so that it is level. Remember that some washer noise is normal. Thin floors can cause the washer to vibrate and move about and the noise level may rise and fall depending on the speed of the cycle.
admiral washer does not work on wash cycle Google Search
Nov 25, 2017 | Washing Machines
Model ATW 44775x00. Why does it become unbalance during spin cycle?
The tub balance could have been upset when the machine was moved to storage.
Oct 20, 2015 | Admiral Washing Machines
Admiral washer leaking water from bottom
What is the model number of the unit?
Nov 24, 2012 | Admiral Washing Machines
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Admiral AAV70000AWW washer makes a terrible screeching noise during the spin cycle
You more than likely have a bad drive belt. It is worn due to use. Replace.
Nov 02, 2009 | Admiral AAV7000A
My Washing machine makes weird noises
hi,
There might be the problem with bearing of rotor mechanism or some garbage so please clean it .
Thanks
Aug 12, 2009 | Admiral AAV7000A
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
Dec 29, 2008 | Admiral AW22 Top Load Washer
Admiral washing machine AAV7000AWW won't stop filling or agitate?
It is either the inlet velve or the cycle programmer faulty
May 24, 2008 | Admiral AAV7000A
Washer Clicking/Ticking Noise
Washer is four years old. It makes a loud noise when agitating and now the drum is jammed. What can I do to fix it?
Thanks,
Apr 15, 2008 | Washing Machines
Admiral AAV7000A Logo
604 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
