Question about Fujitsu AMILO D-8820 Notebook
Upgragding Ram on my D7800 and D8820
How much Ram can go in to My D7800 and D8820
  • 10,515 Answers
In D7800 - 4Gb
In D8820 - 2Gb
Thnks.
Posted on Jan 05, 2009
How do I Reassemble Fujitsu siemens Amilo D7800 laptop pc
It is similar with any notebook reassemble. Yo can use any youtube video or go to Repair Manuals for Every Thing iFixit and do the same. You must ensure that all must unfolds slowly. If something was hindering look good did you remove all the screws and cables.
Oct 10, 2014 | Fujitsu Computers & Internet
My system doesnt see the ram i installed,(512x2) its perfectly compatible,still it only sees 448 MB out of 1024.i updated bios and everything.is it coz i am using the on-board graphics adapter?help me out...
It looks like your computer is seeing only one 512Mb RAM module. Your computer uses shared RAM - 448Mb RAM is available for the computer and 64Mb is reserved for video RAM (448 + 64 = 512Mb) of RAM.
One of the RAM modules may be faulty. To determine which RAM module is faulty, remove both RAM modules and insert one RAM module at a time to determine the faulty RAM module.
If both RAM modules are OK then -
Some computers do not like mixed RAM modules from different manufacturers. Try using the RAM modules with the same make and type/speed.
Jun 14, 2011 | Computers & Internet
I have bought a 2x2 gig ram upgrade from 1 gig for my computer. I have an msi p965 motherboard where should I plug th two ram modules into. I have a choice of two orange or two green inputs? what are your...
put the largest ram closest to CPU central processing unit make sure that the ram are of the same brand/type some motherboards only accept a certain brand/type
Nov 09, 2010 | MSI P965 Platinum (7238010) Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
Ram problem?
Most likely your system has UMA video (Unified Memory Architecture) which means that system RAM is used for Video. Many systems dynamically allocate RAM resources to the Video, thus you get the varying amounts of RAM accessible indicated. This is a normal function and system is working as designed.
Oct 03, 2009 | Computers & Internet
Cant install driver for ati on amilo d7800 missing exe/dll
Download the drivers again from Display - ATI MOBILITY RADEON (M6P)
Click I accept conditions on the download page to enable the download.
Mar 13, 2009 | Fujitsu AMILO PC Laptops
Upgrading My D7800 And D8820
In D7800 - 4GB
In D8200- 2GB
Thks.
Jan 05, 2009 | Fujitsu AMILO D-8820 Notebook
Pentium 4 comptability with SD Ram
If you know what mother board you have you could check what RAM it can use.
All RAM is installed in the same way, but different types of RAM are keyed differently. That basically means that one type of RAM (for example SD RAM) will simply not fit into another type of RAM slot (for example a DDR RAM slot).
To install ram on a PC
Please note - do NOT touch the connector side of the RAM, handle it only by holding the side or top edge
1. check that you have the right type of RAM. do this by lining up the RAM above the RAM slot and making sure that the RAM is the same length as the RAM slot AND ALSO that the RAM's key (the little hole or notch in the RAM) lines up with the key in the RAM slot. Note there might be more than one key
2. open both clips of the RAM slot by pushing them down and out from the center of the RAM slot
3. gently insert the RAM into the RAM slot
4. check again that the RAM and the RAM slot's key's line up, if they do, firmly press down on the RAM on both corners until both clips automatically click shut on the RAM
That's it! :-)
-Magnon
May 13, 2008 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
Fujitsu AMILO D-8820 Notebook Logo
138 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
