Question about HP PhotoSmart Office Equipment & Supplies
Change region codess on printer hp 3070A
Change the region on this printer
5 Suggested Answers
  • 12 Answers
SOURCE: change region codess on printer hp c3180
Hi ,
Let me fist inform you that the question you asked for is related to "regionalization" of the printers . It is very particular to HP printers.
You can just regionalize your printer thrice in the enitre printer lifetime - not more than that. And the codes you are referring to - they are not there somewhere - they have to be logged in by the back end team who decode the "10-tap test" to re-enter the codes for regionalization so that the printer becomes compatible in the region you are using it in.
The cartridges even change in every country to make the printer work - let me state you how.....as per www.hp.com
HP Photosmart C3100 All-in-One series This product uses regionalized ink supplies, so the inkjet print cartridges for the product depends on where you are in the world. If you do not know which pen regionalization zone you are in, click here to view the Regionalization Country-to-Zone Mapping Table . Once you know the zone, you can identify the cartridges used in this product. Cartridge Description Zone 1 Zone 2 Zone 3 Zone 4 black inkjet print cartridge HP 92 HP 336 HP 132 HP 850 tri-color inkjet print cartridge HP 93 HP 342 HP 136 HP 854 black inkjet print cartridge Not availaible HP 338 HP 131 Not available tri-color inkjet print cartridge HP 95* HP 343 HP 135 HP 855 photo inkjet print cartridge HP 99 HP 348 HP 138 HP 858 *The HP 95 is not compatible with printers sold only in North America; instead, use the HP 93 Tri-color cartridge. Refer to the link to understand how the world is divided into 4 zones - http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00586&cc=us&lc=en&dlc=en&product=1146331#zone_mapping And you can beleive into what i say as I work for HP printers....! the best i would suggest is to call up Technical / Customer Care centre and tell them you need to reset....they will assist you for 10-tap test and ask you to send them the 10-tap test and the Proof of Purchase of the region cartridges.....and then wait for the back end team to call you within the next 48 hours.
Posted on Apr 09, 2008
I have moved to Switzerland recently. Have called support spent over 10 hours on the phone, lost the counts of call. Put on hold several times, been told, there's no such thing as region code. They actually told me I should buy a new printer that's compatible with my region (and this was not a joke).
I am pretty much frustrated with HP. If you find a solution or a legal way to compalin about HP let me know.
I am at the point - after 15 years buying HP products to throw all the 3 printers I have away and buy new ones that do not have this stupid region coding. By the way I have found a way, if you buy refill kits then I can continue using my printers... so much for HP ide of buying original supplies...
Posted on Feb 13, 2010
drifterK
  • 4924 Answers
SOURCE: How do I change region
all you can change is the language and this will not change the tip of cartridges that it uses...try to refil the original ones..and after that to reset the counter for them if it do not sees them ...or ..order the same ones from ebay ..if they are not available in Australia ...cause if it is made for certain tip of cartridges it will work only with them ..
another thing that you can do is to adapt to work with a Ciss unit ..like in this link ..
this is an external feeding unit that adapts in the cartridges area..and are refillable and last much more..and with a better percentage for use..
http://www.inksystem.com/all-in-one-ciss/hp/All-in-one-HP-Photosmart-C7283-with-CISSe.html
here some models of cartridges on ebay ..
the european model..
http://cgi.ebay.com/HP363-Compatible-Ink-Cartridges-HP-Photosmart-C7283-/260577355348?pt=UK_CamerasPhoto_Printing_PrinterInkCatridges_JN
here the 177 Im not sure if it is the same with the European ..but I know that the European one is not 02 and not fits the American 02 model..
http://shop.ebay.com/i.html?_kw=177&_kw=cartridges&_kw=Hp
Posted on Aug 22, 2010
Hp deskjet 3070A says. Out of ink. But this is not true
Pretend to replace all the ink cartridges all over again, with all on, then go into the Control Pannel, Hardware, Devices & printers and make sure you don't have to run any maitenance services (ink-head allignment, roller cleaning,ect.)or verify via properties that you have replaced the cartredges.
Aug 21, 2012 | HP Computers & Internet
I have a Dell Dim 2400 and no connection with HP Deskjet 3070A.
Charles, has this combination worked previously, have you been able to print from your Dell Dimension 2400 to your HP Deskjet 3070A successfully?
If the answer to the above is Yes, then if you believe that the printer is still working correctly and you can test this with a different computer able to print to it, you should consider uninstalling and re-installing the HP software and device drivers for this printer.
If you have not printed to this printer successfully previously, have you tested the printer with a different computer and proven it is still working fine?
If the printer works fine to a different computer then providing you are using the same USB cable to connect to your Dell 2400, the problem needs to be narrowed down further.
Check that you can plus other USB devices into the port on the Dell used for the HP printer - if these work, then your USB port is good - if not, try another port if you have one.
If your USB hardware is good, then again you are left with the need to uninstall and re-install the HP software and device drivers - it may be worth trying to download the latest version of such software if available. HP tend to update their All-in-One software on a regular basis.
Dec 30, 2011 | Dell Dimension 2400 (24006YYVP31) PC...
Photosmart 3210 bought Dubai need to change region Spain
Hello Friend
You can change region settings of your hp 3210 printer by changing your language preferences.Just select the language of your region and it will be fine.
Thanks,
Viju
Apr 03, 2010 | HP Office Equipment & Supplies
Change Regional Settings in HP PhotoSmart Printer
Hi Harshal,
I bought HP Photosmart printer from USA and took it to India but I am getting incompatible error message.
Please can you let me know how to 10 tap test.
Jul 08, 2008 | HP Photosmart 2575 All-In-One Printer,...
Change region codess on printer hp c3180
Hi ,
Apr 09, 2008 | HP Deskjet 6940 InkJet Printer
I have just moved from the US to Shanghai with my HP C7280 printer. Bought some new cartridges from the HP dealer in Shanghai after our US supply ran out. Got the 'Incorrect Ink Cartridge' message on the printer after installing them, which the dealer probably knew I would get and didn't tell me, which I'm assuming is what you got.
My experience was to use the 'Chat' function on the HP.com web site in the Support area. The good news is that they solved my problem, the bad news is that it took 1 1/2 hours and is the most convoluted process I've experienced in years. There is a little 'voodoo' going on the background......... after having me find several values, including cartridge serial number values (no not the cartridge number on the cartridge), reset values, and others I can't remember, he said he had to go 'calculate' and he then came back with 5 four digit numbers I had to enter after going to Windows Control Panel -->Printers and after getting my printer selected and the Preferences screen displayed, clicking on the HP logo while holding the CRTL key down (I kid you not).
Sooooooo, I believe the only solution is to use HP Support and to also write letters complaining about how really, really, really stupid this process is. And being the conspiracy theorist that I can be, HP probably was seeing lost revenue from people buying cartridges that are cheaper in parts of the world and shipping them to where HP is, ahem, making a killing and padding their profits.......
Good Luck
Mar 24, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP US region code for HP PSC 1610 All-in-One Hi,I bought my HP PSC 1610 All-in-One in Germany and now have moved back to the US. As it is regionalized to Europe region code, I need to change it to US...
The control panel display shows the wrong language
Solution
Usually, you set the language and country/region when you first set
up the HP All-in-One. However, you can change these settings at any time by
using the following procedure:
1. Press Setup until Preferences appears, and then press OK.
2. Press until Set Language & Country/Region appears, and then press OK.
You are prompted with a list of languages. You can scroll through the list of
languages by pressing or .
3. Press OK on the appropriate language.
4. When prompted, press OK to select Yes or Cancel to select No.
You are prompted with a list of countries/regions for the selected language.
5. Press to select the appropriate country/region, and then press OK.
6. When prompted, press to select Yes or No, and then press OK.
You can confirm the language and country/region by printing a Self-Test Report,
as follows:
1. Press Setup until Print Report appears, and then press OK.
2. Press until Self-Test Report appears, and then press OK
Nov 16, 2007 | HP PSC 1610 All-In-One InkJet Printer
98 people viewed this question
Seeker5211
Seeker5211
