1. red warning lite on check print cart. 2 Error up on "copies. 3have printed test page for 2. 4 have attempted to reset by turning off. 5 cannot find solution in troubleshooting
  • ron_pola Jan 05, 2009
    carried out as per instructions problem still exists
  • 66 Answers
The ink cartridge is not getting good contact. If its a new cartridge the the glue that holds the tape on the bottom some times a little piece will still be on there.the printer should have a prim mode. Make modol would help. PS That will make all the Errors
Posted on Jan 16, 2009
  • 685 Answers
Ok what kind of printer do u have? and have you tried to unplug it and plug it back in this also resets it
    Master:
  • 416 Answers
This is the link for HP support page
for HP Officejet J3600 (just an example)
You need to type your model and follow the troubleshooting guide
Good Luck
http://h10025.www1.hp.com/ewfrf/wc/document?docname=buu02180&lc=en&dlc=en&cc=us&lang=en&rule=8485&product=3441011
Posted on Jan 05, 2009
    Genius:
  • 2,035 Answers
Please mention the model number of the printer :
Try to clean the cartridge :
Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
And check if the error lights are blinking on the printer..
Good luck...
  • Anand Kumar
    Anand Kumar Jan 06, 2009
    Then try to change the cart in the printer and then check if your getting the same error....Did the printer had paper jam before the lights started blinking ....
  • 10,515 Answers
The red light usually signifies that either an ink cartridge is empty, no paper loaded, or there is a paper jam. You can view the manuals here: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=29081&prodoid=37368464
Thanks.
  • taran_2005
    taran_2005 Jan 05, 2009
    U may also check this mnaul bcoz the solution wld be the same even for Hp printer..
    Take Cre.
The HP Photosmart c3180 prints a color test sheet every time I turn it on even if only to scan a document. How do I prevent it from doing this?
1. Turn on the HP all-in-one.
2. Disconnect the USB cable from the all-in-one.
3. Press the sequence of front panel buttons below to initiate the print cartridge alignment process. The button-press sequence must be completed within ten seconds. It might take several tries to complete the sequence within ten seconds.
a. Press and hold Cancel.
b. While holding Cancel, press On.
c. When the Check Paper and Check Print Cartridge lights begin to blink simultaneously, release both buttons.
d. Press Cancel again.
e. Press Copies.
f. Press Paper Type.
g. Press Color Start Copy.
h. The alignment page will begin printing. If the alignment page does not print, repeat the button-press sequence in this step.
4. Once the alignment page is printed, place the page face down on the scanner glass and press Scan. The alignment is complete when the On light stops blinking. 5. Reconnect the USB cable.
Mar 15, 2010 | HP Photosmart C3180 All-In-One InkJet...
How to reset ink levels from HP J4580 printer refilled 901 wont show ink level comes up as empty
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jan 10, 2010 | HP OfficeJet J4580 All-In-One Laser...
Error 1203, will not print only gives error 1203, no test will print
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Jul 20, 2009 | Dell 944 All-In-One InkJet Printer
Error 1203
hi..
error 1203 means either or both cartridges have short circuited and needs replacement..
You will need to perform the following steps to find out which cartridge is defective:
1. With the printer turned ON, open the front cover and remove both cartridges from the printer.
2. Power the printer OFF and unplug the power cable for 30 seconds. Plug the power cable back in and turn ON the printer.
3. If the error message is now cleared from the printer, please perform the "Self-Test" by following the steps below:
1. Make sure the printer is in “Copy Mode.”
2. Press the “Menu” button once.
3. The screen will display “Copy Menu: Copies”.
4. Press the left arrow button once. The screen will display “Copy Menu: Tools”.
5. Press the check button once. The screen with read “Tools: Maintenance”.
6. Press the check button once. The screen with read “Maintenance: Ink Levels”.
7. Press the right arrow button until the screen reads “Maintenance: Print Test Page”.
8. Press the check button once. This will start the Self-Test. Once the page has printed, the printer will stop. The test is not continuous.
If the printer has detected a "Cartridge Missing" error, then please follow the steps given below:
1. Turn the power OFF.
2. Open the front cover.
3. Turn the power back ON. The print cartridge carrier should move to the install position located in the middle of the printer. If it does not, close and reopen the cover:
4. Reseat both cartridges in the printer and check for the error.
5. If the error still displays, then remove the color print cartridge.
6. Close the cover.
7. If there is no error indicated by flashing lights, the color cartridge has short-circuited.
8. However, if you continue to get an error, repeat steps 1-3, and then go to step 9.
9. Remove the black print cartridge and reinsert the color cartridge.
10. If there is no error indicated by flashing lights, the black cartridge has short-circuited.
11. If you continue to receive an error in both cartridge scenarios, both print cartridges have short-circuited.
Apr 23, 2009 | Lexmark X5470 All-In-One InkJet Printer
HP 3845 Inkjet won't print color under OSX
Try this test:
Let's say you want to print this present page (of fixya.com from Firefox or another web-browser), try File/Print and see if you have the tab Advanced to change to the color cartridge.
Oct 29, 2008 | HP Deskjet 3845 InkJet Printer
Changed all 3 colors and black---Red not printing
Print is brown: mingles yellow with bk and cyan and red.
Did you use generic ink? You have to use a set of original brother ink carts: dinsert the original carts. press menu then start b/w copy then fourtimes arrow-up. when machine is in maintenance mode press 7 then 6 then 4 then start b/w copy. machine will initiate the carts and do some power cleaning. whnen finished press 7 then 6 then 3 then start b/w copy. machine does a power purge. leave maintenance by pressing 9 then 9. Do run a test print. If you cant see any mag. do the power purge two days later. If your not lucky then (you cant see ANY mag squares on test print) the head is defective and needs replacemnt.
Mar 16, 2008 | Brother MFC 420CN All-In-One InkJet...
2 red lights flashing??????????
when two red lights flash, come to a complete stop at the intersection..ok..now for a solution.
unplug printer from wall and computer..
wait 5 min.
plug into wall only
try the test page again..
check back here next..before plugging into computer, please..
check your computer's warranty here FREE
Feb 27, 2008 | Epson Stylus C84 InkJet Printer
Hp 1200 business inkjet help
I have a solution that is very similar to that printed above.
I have tested it on five installations on the computers on my home network and an HP Business Inkjet 1100, and the PCs running Win XP SP3.
Step 1) If you are setting up the printer from the HP CD, decline the question where it asks if you want to print a test page, (this will avaoid the first print job before re-setting the dates).
Step 2) Reset your clock back to a year prior to the year when your cartidge expired.
Step 3) Print a test page, or two. Or a few pages from any application.
Step 4) Reset your clock back to the current year.
The printer now prints fine. Since I performed the sequence above I have been printing with the "expired" cartridges for a few weeks. I have printed on about 15 occasions over the past few weeks, amounting to about 50 pages. No problems so far. I don't know how long this solution lasts or whether I will have to go through it again.
I have gone through a few different "solutions", including a Registry hack that didn't work, but this simple solution above has worked every time on five different installations.
I did not need to turn the printer on/off, and did not need to re-boot the computers.
However, if I sent a print job to the printer before performing the sequence described above, and the printer gave an "expired cartridges" error, then I would need to turn the printer on/off to clear the error, and flush the print queue.
Jan 28, 2008 | HP Inkjet 1200dn Printer
Printing and copying almost blank pages
Ussally drum/toner would fix, will not be fuser, I would suspect Hi voltage board or laser unit, In australia these machines carry a 2 year return to base warranty.
Try reseting the drum counter, this also resets Bias voltage, might be your problem. open front cover with power on and press set, arrow to change drom and select yes.
Otherwise it would be a high voltage board problem, possibility alsoexist that it could be laser unit
Check status page for "71" errors, menu * 2 8 6 4 very very fast, machine will beep "maintence displays" then 77 to print out status page, 99 to return to normal.
Nov 26, 2007 | Brother MFC-8440 All-In-One Laser Printer
Print Problem error after 1/3 to 1/2 prints
This is not for changing carts, it's for the anti-curl function. You need to attach your printer to a computer, load the driver, try a test print from the computer, and check to see if the printer is reporting an Anti-curl motor error
Oct 14, 2007 | Alps MD 5000 Thermal Printer
14 people viewed this question
k24674
