Question about Tanita BC-533 InnerScan Body Comp Scale
Tanita TBF-551 error code 88888 - Tanita BC-533 InnerScan Body Comp Scale
4 Suggested Answers
SOURCE: measurement is in kilograms instead of pounds
check if there is a tiny whole in the back you could probably poke it with a needle
Posted on Jan 03, 2009
fitnessbalan
  • 59 Answers
SOURCE: Getting error E 11 on unit.
ok here is what I found: •E - 11 is displayed when there is a loose connection between the control box and the weighing platform.•Confirm that none of connections between the scale and control box are loose or unplugged.•There may be excessive vibration which will disturb the measurement process.
you can dowload the manual here http://www.tanita.com/en/tbf-300a/184-catId.520093719.html. If those solutions do not work i reccomend contacting the manufacturer here http://www.tanita.com/en/contact-us/ as the unit may be under a warranty.
Posted on Apr 02, 2009
SOURCE: tanita innerscan stopped working. New batteries
Maria,
sorry no, i don't have a sltn. however i recently experienced the same issue w/ my tanita innerscan. i've just notified Tanita's customer service... have you had any progress?
Posted on Jan 10, 2010
I have a TANITA TBF-515 haven't used for a long time. Just put in batteries and getting an ERROR message on screen. How do I fix this?
This is not a camera, it appears to be some other kind of domestic electronic equipment
Mar 06, 2017 | Cameras
I had to change the batteries and now it only reads in "kg" how do i change that on the model 2204?
Since your problem started with a battery change, I am going to assume that method 1 is most likely going to fix your problem...Good luck!
Method 1
Press the Set and Up Arrow buttons at the same time. Release the buttons, the display will flash. Press the Arrow button to cycle through each weight mode until just the mode that you require is displayed. Then press Set. The display screen will flash to confirm your selection and store in memory.
Note: If weight mode is set to pounds or stone-pounds, the height programming mode will be automatically set to feet and inches. Similarly, if kilograms is selected, height will be automatically set to centimeters.
Method 2
Body Fat Monitor/Scales: BF-542, TBF-551, TBF-521, TBF-531, BF-681, BF-682, BF-679, BF-680, BF-578, all Ironman products, and all InnerScan products.
Select the preferred weight mode by using switch on the back of the measuring platform.
Jan 12, 2011 | Tanita 2204 Body Fat Scale
Tanita innerscan stopped working. New batteries installed but will not switch on. There is no display except on the guest button which comes up with "88888" when pressed. Any ideas - thanks
Maria,
Dec 30, 2009 | Tanita BC-533 InnerScan Body Comp Scale
Apr 01, 2009 | Tanita TBF 310 High Capacity Pro Body...
Somehow my tanita ultimate scale has been switched from pounds to stones. How can I get it back to pounds?
Q: Why does "st-lb" or "kg" appear when taking a measurement?
A: The unit's "Weight Mode" has been set to measure your weight in units of stone-pounds (st-lb) or kilograms (kg). Tanita's Body Fat Monitors and the UltimateScales can measure weight in three different modes: lb (pounds), kg (kilograms) or st-lb (British stone-pounds). To change the setting, first find out which model you have (it should be written just above or below the display screen of the unit).
Method 1
Body Fat Monitor/Scales: TBF-611, TBF-612, TBF-621, TBF-622, BF-541, TBF-560, TBF-572. UltimateScales: 2000, 2001, 2001T. BF-662, BF-555, BF-556, BF-558, BF-559, BF-625, BF-626.
Method 2
Mar 15, 2009 | Health & Beauty
Scales show weight in kg. How to get them to show lbs.
Mar 13, 2009 | Tanita 2204 Body Fat Scale
Measurement is in kilograms instead of pounds
Jan 01, 2009 | Tanita Health & Beauty
I have a tanita tbf-612 scale and the measurement changed to metric instead of pounds when the batteries died. How can I change it back as I don't see anything on the back to re-set the scale.
Jan 01, 2009 | Health & Beauty
Problem in the software
dear, its a internal software problem of scale, contact company for re writting the program of scale mother-eeprom.
Nov 18, 2008 | Tanita Health & Beauty
Tanita BC-533 InnerScan Body Comp Scale Logo
168 people viewed this question
Top Tanita Health & Beauty Experts
dkmun
Level 1 Expert
Tre Elkins
Ankit Chandel
Ankit Chandel
Are you a Tanita Health and Beauty Expert? Answer questions, earn points and help others
