Question about Whirlpool WTW4800XQ Washer
18 month old whirlpool wtw4800xq washer. Fill light is blinking and nothing happens when start button is pressed or held down. Any ideas what could be the issue? Unit has been unplugged and off for 24
When you press the start button nothing happens, no click, no lid lock. Fill light just keeps blinking. Tried to hold start button down to cancel. Nothing happens.
SOURCE: Whirlpool GU2548 green light flashing, nothing working
I have had the same problem with my the same dishwasher. The manual says that "the dishwasher has malfunctioned. Call service to check heater element". I called service and they are saying that replacing the heater element and possibly the electronic panel may be required. Total cost (part + labor) = $350-400!! I am very very upset with Whirlpool right now.
Posted on Oct 09, 2007
jsrock516
  • 5911 Answers
SOURCE: ''Control Lock'' won't ''unlock''
Press and hold the "End of Cycle Signal" button to lock or unlock the control panel. The instructions should be printed directly below this button. I hope this helps you.
Posted on Nov 14, 2008
  • 26 Answers
SOURCE: Control lock light will not go off.
Do you have any error codes?
Does water remain in the washer after the final spin?
If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
Is the door locked and the Add A Garment light on?
If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
Is the door locked and the Add A Garment light off?
If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
If Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Posted on Dec 19, 2008
SOURCE: Whirlpool 9400 Front Loader Washer Control Button Locked
There it was, the directions printed right there on the front of the washer. So simple, who would have looked?? Thanks for you help. mine is the GHW9300P
Posted on Feb 12, 2009
SOURCE: Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Posted on Sep 24, 2009
Model WTW4800XQ Whirlpool top load washer will not fill. Only hums when on button is pushed. what is the problem?
Does it do it on hot and cold water. Check the water filters where the hose screws on to the washer.
Oct 06, 2014 | Whirlpool WTW4800XQ Top Load Washer...
Whirlpool WTW4800XQ Washer The drum has sunk way down . It is only a year and a half old is there a way to fix it myself?
take the back off of washer and see what broke or came loose. then u will know if its something u can fix
Apr 06, 2014 | Whirlpool WTW4800XQ Washer
My washer won't start - :control lock" light is blinking but when I start the washer nothing happens help!
press and hold the end of cycle button for 15 seconds and that should unlock the control panel
Oct 16, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Have a Kenmore Elite HE3T washer. Put appropriate detergent, fabric softener in, selected NORMAL cycle, spin speed, etc. Just sits there. Pressed START button several times. Nothing. Little cycle lights...
I own a 18-year-old Kenmore front-load washer so I'm not sure this will apply, but here goes... My washer requires me to press and HOLD the start button for a few seconds before it will start. At that point the door will lock and the washer goes through its startup phase. I think that is a "safety feature' to keep from accidentally bumping the button and starting the washer. See if that help. Good luck!
Nov 22, 2017 | Kenmore HE3T Washer
Won't turn on - press the start button and nothing. hold it down and it will light up, however water will not start nor does the cycle start. Unplugged it and replugged back in, tripped the circuit and...
Husband came home from work - looked at what was happening. It appears service is needed due to circuit board issue; technician will be at house this am.
Sep 16, 2009 | GE Profile WPRE6100G Top Load Washer
Service light is on my whirlpool washing machine and won't allow the wash to start, can I override this as it's only 18 months old?
The main motor in the whirlpool front loaders has brushes. These will wear out eventually. Does the drum try and turn when a load is started? If not the motor deserves a check. 18 months sounds short but possible. Mine took 4 years to wear down.
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jun 11, 2007 | Whirlpool 24 in. GU2548XTP Built-in...
Whirlpool WTW4800XQ Washer Logo
Dan Webster
Dan Webster
Sal De
