Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Random knocking noise
Sounds like someon hammering for 5-10 seconds. this happens about 3 times per day.
also notice light frost on ice
  • a1anuit Jan 06, 2009
    noise does not actually seem to originate at compressor ... however fridge continues to function so I will leave it at that for now. thanks
  • 198 Answers
There is a broken spring on the internal mount for the compressor. The only fix for this is a new compressor. If you can put up with the noise leave it alone. Expensive to replace compressor
Posted on Jan 05, 2009
How do I stop the loud knocking noises coming from my refridgerator?
Pull the fridge away from the wall and inspect the compressor. Your description sounds like the compressor is hitting something. It is rubber mounted and usually can be pushed away from whatever it is hitting.You do not want to jamb something to stop the noise, as the compressor needs to move freely. Many compressors shake during start up and shutdown, and this is considered normal. Abnormal if the compressor hits something during this movement.
Feb 05, 2012 | Kenmore Refrigerators
I noticed an unusual high pitch sound which I traced back to the refrigerator. I then noticed that the front panel lights were flickering on and off and so was the external ice maker lid. I turned the...
Hi and welcome to FixYa, I am Kelly. First off the high pitched sound you heard was most likely ice build up on the evaporator so th evaporator fan blades were striking the ice. Now as for your shutting of the unit and staring right back up..... You need to wait 15 - 20 minutes of OFF time when ever there is a power interruption. What is happening now is that the compressor can not restart because the coolant pressures are to high. That 15 - 20 mins of off time will afford that pressure stabilization time.
What you really need to do is remove the freezer contents and place a fan blowing into the freezer compartment to manually defrost the freezer evaporator. (about 2 hours of floor fan time) This should get rid of the high pitched noise. Then.... restart the unit. It should restart.
I suspect that you have an automatic defrost problem is why you had the noise. The manual defrost will only get you 2 - 3 days of normal operation again before it once again starts the icing routine. I want to get this off now to get you started on the manual defrost. I will respond with a 2nd post about the defrost problem.
Your to do list...
1. unplug the unit.
2. Manual defrost with floor fan (2 hours of fan and water mess)
3. Restart the unit
4. Watch for next post about defrost.
Thanks for choosing FixYa.
Kelly
Dec 09, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Amana ARB8057CSR Bottom Freezer Refrigerator, Intermittent Quick Loud Noises Appliance history: Purch. 12/03. Replaced PTC relay 12/08. Water filter last replaced 3/10 (2-person household). Problem:...
No-one posted a solution. I contacted the original solution poster who was very helpful.I hope this helps someone else better understand their refrigerator problem and get on the right track. Staffgage.
Tweezb wrote:
"you are right that cleaning under your refrig wont get rid of a "compressor knocking" sound. what it might do is to lower the amount of heat from the condenser coils and thus cause less pressure and stress on the compressor making it run easier and less likely to bang or knock when shutting off.
if your coils were very plugged with lint and you have cleaned them, that will help but it wont "fix" the problem.
inside the compressor is a motor and a pump, the motor is supported by 3 springs and they can stretch or break causing the motor to hit one side of the black outer can and cause the noise.
that may be too technical, but its not something that can be repaired without replacing the compressor, at a cost of 700-800 bucks. most would not pay this as its not worth putting that amount of money into an older refrig."
"think that you are hearing either a freon related sound or even just the sounds of the unit going thru defrost.
how often do you hear the noise? just maybe once a day or is it everytime the unit shuts off?
either way i would rule out the ice maker and water system as when the "shut off arm" is up then it is off and wont make any noise, or ice.
keep the i/m arm up and then listen for the next day or two and try to narrow down when it makes the noise and frequency you hear it and then get back to me.
it may not even be a problem, just normal operating sounds that cant be changed."
Oct 20, 2010 | Refrigerators
Load knocking noise
these high efficiency compressors make noise when they are in defrost..you will sometimes hear water running, or tapping noise or even a popping noise. if it happens when its off in defrost.. it will only happen three or four times per day as this is the defrost frequency and nothing can be done without securing the heat exchanger to the suction line ..sometimes these come loose...
May 20, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchenaid refrigerator / freezer knocking noise
Hmmm. Makes sure it is not the fan inside the freezer. The compressor is not capable of loud noise since it is sealed and sits on rubber mount. The knocking might be due to the fan blade hitting ice build up. You should not see any frost in a freezer. If there is frost, you can defrost completely then set the fridge to a lower setting.
Feb 11, 2010 | KitchenAid (KSRD22FKST) Side by Side...
Knocking sound caused by the flame sputtering.
I have heard of noises coming from the inducer fan as it start to build up with condensation but the noise coming from the flame is new to me. Gas pressure or a cracked heat exchanger could cause the flames to float around out of the manifold but that is about all I can think of
Jan 07, 2010 | Goodman GMS90703BXA Heater
2006 start up problems
sounds like fuel air tank vent blocked.
Jul 10, 2009 | 2006 GMC Canyon
Brand new french door maytag refrigerator makes a loud knocking sound off and on all day. Is that normal ?
im sorry to tell you, but the sound is probobly normal.
fridges these days make some weird noises.
they started making noises when they changed the gas to R34a.
you may be able to get a noise ruduction kit for your model. they are not too fun to install
May 31, 2009 | Maytag MFD2560HES Bottom Freezer French...
Ice cubes made by ice maker become large fused chunks over time.
Ice cubes will deteriorate over time if not used. They shrink due to defrosting of the freezer and will become stale.
Once the ice bin is full, turn the ice maker off until you use the cubes and or dump the cubes every 3 or 4 days and start over.
Mar 03, 2009 | GE Refrigerators
Knocking/banging sound on compressor start up
Check the compressor mounts. They are usually springs mounted with rubber. If they are two loose the compessor wil hit some other metal part when starting up. Shakle it and see what it is hitting. Ajust accordingly.
Dec 27, 2008 | Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
