Question about GE (PSS26MSRSS) Side by Side Refrigerator
What size is my GE GSS25WGMC BB refrigerator - GE (PSS26MSRSS) Side by Side Refrigerator
2 Suggested Answers
woodchuck789
  • 4066 Answers
SOURCE: GE GSS25LGMF BB refrigerator freezing everything.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Posted on Jul 01, 2009
Where is the filter on a ge GSS25JEMD-BB?
did ya look behind the kick panel at the bottow sometimes its down there.
Dec 02, 2013 | Refrigerators
GE GSS25WTGA BB
This could be a dozen different things causing this. Do you see ice build up on the back wall? Your freezer coil could be icing over and blocking fan air flow. This can be due to a bad fan, low freon.....
Oct 12, 2013 | GE Refrigerators
Manual TFG27PFXB BB
I NEED A USER GUIDE FOR GE REFRIGERATOR TFG27PFXB BB MODEL
Feb 11, 2013 | GE GSS25QGPBB / GSS25QGPCC / GSS25QGPWW...
GE GSS25WGMC freezer ices up at top. Fan motor makes loud noise as it ices up between defrost cycles. Door gasket (screw in type) was replaced and problem a little better but not cured. I'm told...
Try replacing your defrost timer it may not be working proper also if it has the coiled heaters behind the insulation make sure they are coming on as well they do burn out.Check heaters voltage and continuity first then defrost timer. If no heated defrost its defrost timer
Apr 05, 2012 | GE Refrigerators
GE GSS25WGMC door open alarm beeps and both doors are OK and seal properly
check to make sure in fridge and freezer there are switches when the door make contact with it it shuts off the lights-check by hand by holding the swiches down and see if the interior lights go off, if not then you have a bad switch..if they go off then the control where the door alarm is located needs to be replaced
Oct 01, 2011 | Refrigerators
Have GE GSS25WGMC WW. Water dispenser dripping water at a constant pace. What could be the problem, is is something we can handle or should we get a repair person? What would be the cost expected?
There are only two reason that I know of. They are air bubles in the water line or the water control valve on the rear of your refrigerator is defective on the dispenser side allowing water to bypass the valve while shut. I will be right back with part numbers, Sea Breeze
Feb 18, 2010 | GE Refrigerators
My GE modle ess25xgmc bb is frosting up i changed
OK, This does not happen much on that model. This time I want you to work with me on the solution and test a couple test points on the motherboard. If you are comfortable with this let me know. It will require a voltage meter and an OHM meter. Let me know, Sea Breeze
Feb 16, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge profile refrigerator bottom drawer freezer... computer panel in back makes a loud clicking sound
Just common noise for GE refrigerators. As long as it does its job ur in good shape. Lack of adequate insulation to block out noise is one of GE's weaknesses. BB
Dec 15, 2009 | GE Refrigerators
Model TFX27PFSM BB sise by side refrigerator has de Defrost warning on the diagnostic system but nothing seems wrong with the refrigerator. What could the problem be???? GE Serial # LL209010 purshased in...
If your model is the TFX27PFSM BB I only see a simple defrost timer. But not to say that you possibly have a bad thermistor that came on some models. Part number 305273 This is an alert so I would keep a close eye on freezer and refrigerator temperatures. The defrost thermostat may be defective and the light is warning you of a problem coming. Let me now if I can help you more, Thanks Sea Breeze
Jul 11, 2009 | GE Refrigerators
Drips at water dispenser GE PSC23MGSA BB
If it's a constant drip then you need a new water valve.
Jan 03, 2009 | GE Profile Energy Star PSC25MGS Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
130 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
