Question about Acer Computers & Internet
Acer AT-3222 est-il numerique ou analogique
TV
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: raccordement fil d'antenne sur circuit il est coupe et je ne sais ou le souder
Step 1:
google translated
antenna wire connection on the circuit is cut and I do not know where the weld
you might need to solder it
You attach wires to printed circuit boards (PCB) in a process called soldering. You heat the wire and PCB pad, melting the solder wire and allowing it to flow onto the wire and pad. The solder wire used is typically a lead-tin alloy although in some special cases, silver is used. Soldering a wire to a printed circuit board may be part of making, repairing or modifying the board or connecting it to another device.
Clean the pad on the circuit board where the wire will be attached. Gently rub the eraser on the pad until it is clean and shiny. Strip about 1/4 inch of insulation from the wire. Tin the end of the soldering iron by melting a small amount of solder onto the iron tip. Heat the wire end with the soldering iron for a few seconds and briefly touch the solder wire to the bare wire, just long enough to melt the solder, and let it flow into the stranded wires. This is called tinning the wire. Tinning the wire is not necessary with solid or single strand wire. Insert the wire end through the hole in the circuit board pad from the top or component side of the board. Bend the end of the wire slightly to prevent the wire from falling out while soldering but do not let the wire end touch any other component lead or another pad on the circuit board. Apply the soldering iron tip to the wire end and solder pad at the same for a few seconds until the solder used to tin the wire end melts. Apply just enough new solder to make a dome-shaped puddle on the pad that covers the hole and the wire. Remove the iron from the pad but do not move the board for a minute. Cool the new soldered joint and do not move the board until the solder hardens. Clip the wire end off with the wire cutters. The wire is permanently attached to the printed circuit board.
Soldering Guide http://www.kpsec.freeuk.com/solder.htm
b> b> b> How to Solder to a Circuit Board: Skill Set (with Video)
http://www.popularmechanics.com/cars/news/4213423
Posted on Mar 14, 2013
Mon tapis roulant sportcraft tx390 ,a commencer a sentir le brule 3 jour apret que jais du ajuste mon tapis car il avais tendense a bouge sur la droite et frote donc jais fait un ajustement et cest...
bonjour, quand je fais partir mon tapis roulant il fonctionne pendant quelques seconde, ensuite le chiffre ( 3 ) s`affiche dans le coin gauche et il cesse de fonctionner, pourriez-vous m`aider? Merci
Apr 12, 2012 | Cars & Trucks
Samsung SpinPoint SV4084H 40.8 GB Hard Drive le moteur ne tourne plus faut-il changer la carte controleur? Ou en trouver une ? Merci d'avance
Bonjour leboudeur
Je crois que c' est plutot le disque dur qui a lache . Essaye de le tester sur une autre machine ou , si possible , de tester les deux , la carte et le disque .
Si le disque est mort , il est encore possible de recuperer les donnees avec un logiciel adequat comme Recuva : http://download.cnet.com/Recuva/3000-2242_4-10753287.html ( gratuit )
ou encore Tenor Share : http://www.any-data-recovery.com/product/index.htm ( payant ) .
Good luck !
fanaudi .
Sep 19, 2011 | Samsung SpinPoint SV4084H 40.8 GB Hard...
J'ai un appareil photo numerique canon powershot s300 digital elph et il ne s'allume pas il a ya un ecran noir ou il est ecrit " changer la batrie" dois-je acheter une autre baterie ?? de plus, je n'ai pas...
Pardonnez mon français, j'utilise Google. Oui, c'est mai-être temps d'acheter une nouvelle batterie. Batteries rechargeables ne sont pas faits pour durer éternellement. Ils devraient être remplacés tous les deux ans. Si votre batterie est plus vieux, alors il est temps. Heureusement, le NB-1LH batterie est disponible à partir de sources génériques de ces journées, et est relativement bon marché si vous recherchez.
Oct 31, 2009 | Canon PowerShot S300 / IXUS 300 Digital...
(HELP WANTED) allo jai un petit probleme de IBM 2.6ghz thinkcentre ,dvd rom,3 hard drive de 60g ,512 ddr 3200 . Le probleme est que mon screen s' etaind apres un lap de temps , mon cpu fan arrete...
sons si le cpu cooler ne fait pas son travail, plus de chauffage et dur arrêté.
mieux supprimer radiateur et une nouvelle pâte thermique
ou qui a le mal ou pas les pilotes de système de mémoire
essayez d'utiliser 1 bâton de ram
Aug 06, 2009 | Computers & Internet
J'ai achet?© un t?©l?©scope et il n'a pas de manuel pour le montage
do I return the appliance to the store or you're going to upload it . I would like to view the manual on the internet, is it possible
puis-je retourner l'appareil au magasin ou vous allez le télécharger . Je voudrais consulter le manuel sur l'Internet , est-il possible
Jan 03, 2009 | Tasco Galaxsee 45-060675 Telescope
Mon appareil canon ne marche plus!
Salut
Desole, mais mon francais est tres mal... Votre objectif a été endommagé dans la baisse et doit être réparé ou remplacé.
J'espere que ceci aide.
Thomas
Sep 19, 2008 | Canon PowerShot A550 Digital Camera
Panne sur mon camescope dcr trv285e
Les message est indique qu'Il est possible que les capteur bobine il se defectue. Il doivent changer a complet un system chargement de cassette en Anglais est { LS chassis assemly } Il vous faul un Technicien forme par Sony ou chez Sony meme pour la reparer et ca depend ou etes vous dans quel pays Je ne sais pas combien ca va couter dans votre pays. Si vous etes en AUSTRALIE ca coute a peu pres entre $250 a $350 Australie dollars
J' espere que cela vont vous done quelque idee
Bone change
PS: Est ce que vous essaye un autre cassette quelque fois de cassette devient lourd en tournant alors il se montre de meme message
N' hesite pas de me contacter si vous avez besoin plus d' info come service manuel ou schematic pour la reparer vousmeme ou quelque chose d' autre
Sep 02, 2008 | Sony DCR-TRV285E Digital-8 Digital...
UNLOCK SAGEM MY W-8
imei unlock 332052-35-125357-0 3927257920 332052-35-129377-0 3362230830332016-35-146513-0 1558898480 332052-35-126828-0 4011806542332052-35-126963-0 0079539739 332049-35-321828-0 1503515261332052-35-126971-0 3852379919 332049-35-236282-0 1395096725332052-35-127534-0 0810548649 332049-35-176328-0 0947921989332052-35-128668-0 3830409997 332052-35-176099-0 0948020856332026-35-148914-0 0270060834 332052-35-174998-0 0445933997 Tout d'abord il faut rentrer dans le menu hotline3 du portable. - Pour ce faire, tapez *#06# afin de connaitre l'imei. - Enlevez les six premiers chiffres et le dernier. Il vous en reste donc huit qui doivent commencer par 35 ou 82. Procédez de préférence sur un tél sans carte sim. - Tapez * + les huits chiffres puis OK. Le menu hotline2 est activé. - Ensuite entrez dans le menu normal du tél puis tapez *. allez dans RAM, tapez l'adresse 112, validez, appuyez sur C, tapez 2 en nombre d'octets et validez. Apparait alors à l'écran : adr:112 puis 8967. Appuyez sur modifier ou C, tapez 7698 et validez. Voilà, le menu hotline3 est actif. Ce menu permet de lire et d'écrire dans tous les champs EEPROM (menu normal puis * puis 3, prom) sans câble. - Avant tout, allez dans le menu PROM, lecture/écriture, tapez 231 en champ et validez. Il y a 0 ou 00. Ce champ est le compteur de mauvais codes simlock tapés sur le gsm. Donc si vous en avez rentré le compteur doit être supérieur à 0! Mettez ce champ à 9 ou F s'il n'y a qu'un seul chiffre ou à 99 si y a deux chiffres. Ainsi le compteur est bloqué mais le temporisateur est désactivé, vous pouvez donc taper autant de simlock faux sans aucune incidence. - Maintenant allez dans PROM, tapez 0 en champ. Vous obtenez une série de lettres et chiffres que vous inscrivez soigneusement sur une feuille. Vous faites "annuler" et encore lecture/écriture mais cette fois çi avec le champ 251 et vous notez son contenu. Sortez du menu PROM pour allez dans RAM mais cette fois çi à l'adresse 219 avec 6 octets. Notez aussi le contenu. - Lancez le soft SAGEMSLCK, quand il vous demende de taper "I UNDERSTAND" vous le faites en majuscules obligatoirement. Il vous demande ensuite le choix "par câble" ou "manuel". Tapez "m" (en minuscules obligatoirement) manuel. Le soft demande ensuite de taper les contenus des trois champs eeprom et ram précedents et lorsque vous validez il vous donne le code simlock à dix chiffres.... Et votre phone est débloqué !!!Ca ne marche pas sur certains modeles. C'est peut etre dû a la version du soft qui est peut etre trop récente.Tenez moi au courant. Pour les Sagem 9500 et autres ??? des ptites indications au cas où les manips. seraient pas clairs :"il est difficile de deviner où il faut rentrer le code de deblocage une fois obtenu. Et c'est pas indiqué chez toi qu'il faut faire * apres Menu, etensuite qu'il faut rentrer dans la rubrique Sim lock."
Oct 24, 2007 | Lands Phones
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
