NSM City II Carriage stops on left and doesn nothing!
At one time the jukebox would play going to the left side of 45 but not right and when I received it and the needle had been removed from the right side. I replace both needles and when I turned the unit on it goes to the left and stops and does nothing! I also would like to purchase a service manual for this unit. I believe one of the two limit swithches has been replaced and was thinking the wiring may be mixed up. Thanks in advance for the support.
SOURCE: "Clear carriage jam" persistent error...
I got the error message about clearing the carriage and no matter how many times I turned it off, unpluged, turned in on again, checked for paper jams, etc, the printer could not get reset. But after much trial en error, the following procedure did the trick: Unplug the power cord and open the door. To the right side, you'll see the ink tray. Carefully pull it to the center and unistall the ink cartriges. Close the door, plug in the power cord and turn the printer on. It should ask you to install the left ink cartrige first. Do it and close the door again. Then it'll ask you to install the right cartrige. Do it as well and turn the printer off again. Turn it back on, let it initialized, and your printer should be ready to work again. I hope this work for you as it did for me. Good luck.
Posted on Apr 10, 2007
McIndia
  • 131 Answers
SOURCE: Canon S900
Category : Printer does not respond, or operate Description : The print head holder does not move to the center
Close the front cover, and check the power lamp indication status (blinking or lighting). List of power lamp indications Blinks in green After lighting in green, blinks in orange 2 or more times Lights in orange Blinks alternately in green and orange, 1 time each this is the option i got on the canon website for printer head not moving to the center. but the light indication given does not match with these options.
It is better for you to go to the above link and see what options suite your problem and follow the instruction given by the manufacturer.
the link is :http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=bj&country=IN.
select your model (i990) then step by step troubleshooting. follow the online instructions.
Posted on Jan 08, 2008
  • 57 Answers
I understand that you are receiving Carriage jam error.
Please follow the below given instructions to get the issue resolved.
Here is the web document:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00309142&cc=us&lc=en&dlc=en&product=90809&dlc=en&lang=en
Just copy and paste the entire link into the Internet browser's address bar and press enter.
Please remove the All-in-One Printer from the Power Surge Protector and plug it directly into a wall Power outlet, as the surge protector may not provide enough power to printer.
Let us power cycle your All-in-one to remove any static electricity in your All-in-one.
Please perform the step given below to power cycle the unit after removing the print cartridges from the printer:
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the USB cable from the computer.
2. Wait 30 seconds.
3. Plug in the power only
4. Repeat steps 2-3 two more times.
5. On the third time after plugging the unit into power, reconnect the USB cable from the all-in-one to your computer.
Please try installing the below patch and check for the result:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=oj-14037-3&lc=en&cc=us&dlc=en&product=90809&os=228&lang=en
If the issue persists, try resetting the All-in-one to factory defaults by following the below given instructions:
Note:
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models, Fax logs, Fax headers, Fax speed dial information.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
This should resolve the issue.
Regards,
Lawrence
Posted on Feb 08, 2008
dg9dotorg
  • 151 Answers
SOURCE: paper jam in carriage
There is a latch at the back of your printer that opens so you can remove paper jams from the back. You can start there and then slowly peel away the rest of the paper that jammed...
Posted on Mar 10, 2008
antiochpc
  • 1314 Answers
SOURCE: Fuser Assembly damaged by user trying to remove paper jam.
This is one of those that is not quite so easy. I have uploaded the service manual for you. You may download it here.
Thanks and please take a moment to rate this solution as fixya as I have taken the time to upload the manual for you. Good luck!
Posted on Feb 14, 2009
Nsm jukeboxes manual
you need the service programme possible gripper problem
Jul 09, 2014 | Wurlitzer Jukebox CD Player
NSM Digital Thunder CD Jukebox speakers on right side do not have sound
make sure speaker wires are all pluged in. if that dont wort check the speaker wire it my be broke in between speaker and player, try new wire
Jul 16, 2012 | Audio Players & Recorders
My nsm jukebox has error#73 . What is that? why wont it play?
malfunction of left side magazine check alignment and grip function
Oct 07, 2011 | Wurlitzer Jukebox CD Player
NSM Grand Performer II is not playing CD's on one side.
you need the service manual email me philhemmings@hotmail.com i can send it on a disc with manuals
Feb 01, 2010 | Wurlitzer Jukebox CD Player
NSM Grand Performer II Jukebox error code 31
Hi
This is a problem with the memory. Contact nsm music and ask for the IC5 battery, £35. " 2 minute job, open the jukebox, immiediatly in front of you on the main board, look for IC5, The battery is directly under the writing. A black battery about 2" in length. Replace that power up and your done. A jukebox repair will charge you some riddiculous price for this. hope this helps cheers dandares
Jan 17, 2010 | Wurlitzer Jukebox CD Player
Jukebox error
error 61 on the nsm is a cd read error nothing to do with the amp, clean laser lens with a cotton bud and spit not spirits etc just saliva, then make a blank selection and see if the laser emits red beam, if not then the laser is faulty, check connections etc, if it picks up the disc but does not spin it its the decoder at fault, places like act marketing london, jukebox showroom, capital coin, herondata sales or anyone operator within the amusement industry will gladly sell you an exchange unit, or just try the coinslot industy magazine online or order via wh smiths
Mar 04, 2008 | Audio Players & Recorders
k24674
jasbo
jasbo
