Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer Baffle Coming Loose
One of the internal baffles on the dryer is very loose. It appears that fasteners may be coming off. It looks like the top of the dryer has hinges and should rotate up, but how do you get the top to come up so that I can look at the baffle. The baffle is currently at the top of the dryer in it's rotation and if I can just figure out out to get the top up I should be able to see what is coming loose.
Mike
  • Vernon Ward Jan 05, 2009
    I should also mention it is a Maytag MDE5500AYW model.
    Thanks.
    Mike
  • Maytag Master
  • 3,463 Answers
See if there are 2 screws located at the bottom front of dryer,unscrew anft panel up untilthe clips that are at the top disengage, disconnect door switch and any other connections , taking note of the connections.
W
Posted on Jan 05, 2009
  • Barry Coates
    Barry Coates Jan 05, 2009
    don't know what happened there, but as I was saying, take note of connections,Remove front panel.You will see 2 screws inside the cabinet just below the cabinet top,remove each screw and lift top.
    This will now give you access to the drum baffles.
    On other models, there are 2 spring clips located just beneath the cabinet top,they are located towards each side edge . Use a putty knife and slide under the cabinet top to disengage clips..
    Lift top up and fix baffles.
    There is another model that requires a different way to access the baffles.
    Proceed as follows.
    If it has a wrap around door, open the door and remove 4 screws you will find on the inside There are clips holding the front panel to the dryer. In order to disengage them, and release front panel,the top corners of the front panel each have to be rolled outwards.
    With the clips disengaged,tilt the front panel forward, and lift it up to remove it.
    You can now remove the door and top cover. ,lift the door of it's hinges,and jiggle it out of its slots.
    Plz rate my solution.
    Thanks.
Kenmore elite steam dryer replacing a baffle
Remove the top and you will be able to see the side of the drum- rotate it until you expose the screws to the loose baffle.(tighten them all while you are in there) Drum Baffle WPW10112972
Jul 09, 2016 | Kenmore Dryers
We have a neptune front dryer and a baffle came loose inside the drum. How do we repair it
an easy way of reinstalling the baffle is remove the top cover or rather flip the cover upward this will show you the dryer drum in which u can spin the drum to the proper spot where u can retighten the screws that hold the baffle on hope this helps
Jun 25, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Need to repair loose Baffle on Maytag Electric Dryer MDE7675AYW
On this model you will see 4 phillips screws in the recessed area when the door is open. 2 on each side. Take the 2 on the right out and then the 2 holding the hinges to the cabinet. Remove the door and then pull the front panel off by pulling toward you. Then you will see 2 screws holding the top down. 1 on each side near the top. Remove these and the top will lift back resting against the wall. From here you can get to the baffles. Good luck and thanks, Rick
Feb 28, 2010 | Dryers
BAFFLE INSIDE THE DRUM IS LOOSE. HOW DO I TAKE FRONT OF CABINET OFF SO THAT I CAN GET TO OUTSIDE OF DRUM TO TIGHTEN SCREWS HOLDING BAFFLE?
Open the front door where you load the machine.
Look towards the top where the door normaly closes, there ususualy two screws that you can unscrew there.
Once loose the top pannel should come off, which allowes you to remove the front panel with 2 screws as well.
Nov 14, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Baffle loose (Can see hole when moving baffle)
Hi there :)
The baffles are held in by 2 quarter inch screws per baffle. The only way to get to them is by taking off the top lid of the dryer.
Good luck.
Aug 05, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
HOW DO I TIGHTENED UP A LOOSE BAFFLE IN MY GAS DRYER
if you have the model with the lint filter on top,remove the 2 lint filter screws,pull the top toward you and up and your in-mike
Jun 01, 2009 | Kenmore Dryers
Maytag MDE5500AYW Dryer
ALL service is perfromed from the FRONT. Shock Hazard Warning! Open the dryer door aand remove the screws that hold the door hinges, remove the door, and on the opposite side that have just 2 screws where the door would attach if it was converted to the oppsite opening direction, and remove the front panel. Remove the front bulkhead,(the internal drum opening panel), by removing the 4-5/16" screws that hold it to the outer side panels. Reach back to the rear of the motor and release the tension on the idler and drum belt. Remove the belt and lift drum slightly upward and remove from the unit. You should then observe 2 rollers about 3" in diameter positioned at about 5 and 7 o'clock. The roller at the 5 o'clock position is most likely bound up or not free-rolling. TRU-ARC spring clips,(you may need to purchase), retain the rollers on the shaft and need to be carefully removed and saved for reaasembly. Inspect roller at 7 o'clock for free operation. Purchase what you need and reassemble.
Hope this helps!
May 24, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer
the top cover is fastened by spring like tabs on the machine rear. the front edge of the top merely clips to the front panel. the top needs to be removed to gain access to the bolts that hold the front panel on. these are inside the top corners of the machine. once these are out, the front cover should just pull up to remove. there may be a light connection and the door switch wires here too. then you can get to the screws that hold the baffles in place.
Dec 27, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
281 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
