Question about Uniden DECT 6.0 Cordless Phone ID
Dext model# 1484-3 continues to fail registration to handsets.. Base reads
Tried to hold END and #, in order to re register the handsets.. Seemed to work fine until placing the handset in the base to register. Continuously failed.
SOURCE: Uniden DCT648 register phone problem
On the Base Station select HS Registration then on the Handset hold # for 2 sec
Posted on Apr 13, 2008
SOURCE: Tru 9496
SOLUTION:
1. First, remove the battery cover on your unregistered TCX905 and look under the battery to confirm that you indeed purchased a TCX905 because some Uniden handsets were packaged as 905's but were not.
2. Take the fully charged unregistered 905 to the base unit TRU9496.
3. On the TRU 9496 base unit press "Menu" then select "Registration" and press OK
4. You should get the message "press the # key on the remote handset".
5. Depress the "#" key on the unregistered 905 and it should register.
Posted on Sep 29, 2008
  • 3 Answers
SOURCE: tru9466 base and tru9465-2 handset
Same manual as lethean provided on a similar post but Page 24 if the previously used Base is Unavailable and your phone shows "Deregistration" in the Menu.
Base Unavailable (Handset Only)
To clear the base registration data in the handset, please follow these steps:
Press and hold [] and [#] for more than 5 seconds. Select the BASE UNAVAILABLE submenu.
BASE UNAVAILABLE appears. Move the cursor to select YES, and then press the OK soft key.
ARE YOU SURE? appears. Move the cursor to select YES. Press the OK soft key.
Posted on Nov 01, 2008
  • 5 Answers
SOURCE: How to clear all registrations from the base
One has to completely deregister all handset by pressing end and # keys together till complete de registration is shown on handset screen. if the de registration is not done as above stated method the hand set will not register will show connecting on hand set screen.
Posted on Nov 07, 2008
  • 98 Answers
SOURCE: Handset Fails to Register
It is quite possible that you'll need to go into the menu settings on your base-unit and reset the unit or restore factory default, whichever option it gives you. Also, look in the menu on the phone to see if there is an option to reset the handset also. After resetting the unit and/or handsets, try to register the handsets again, one at a time. If that still does not fix the problem, you may have handsets that are not compatible with your system, or your system may not be able to support that many phones. However, if you have the right handsets, and your system can host that many handsets, then I'm confident that resetting the unit and re-registering your handsets should fix your problem.
Hope this helps! Have a nice day!
Posted on Nov 23, 2008
DS6321 out of range, no power at base
This sounds like a registration problem, the handset(s)
and the base have lost identification with each other.
I. To address this, first de-register the handset(s) ---
do this procedure for each handset:
0. Start by taking off the battery compartment cover....
1. press [menu]
2. scroll up/down to "Settings"
3. enter * 7 8 9 0 #
4. scroll down to "next page", press [select]
5. scroll down to "Register Clear?", press [select]
6. display asks "Confirm?" or "Register Clear??", press [select]
7. display reads "Ok" and chirps, press [ off ]
8. UNPLUG THE HANDSET BATTERY (why the cover was off)
9. Wait ~30 seconds, re-connect the battery & replace the cover
10. display reads "Not Registered" ===============================
II. To register the handset to the base:
1. press [Find Handset] on the base and hold for
~4 sec until the "In Use" lamp lights.
2. press # on the handset and set the handset into
the handset cradle on the base
3. within 30 seconds or so, the handset will either
chirp and display "Handset Registered", then
"Handset #1" or it will say "Registration Failed".
NOTE: the battery must be well charged prior to the
registration process, a weak battery may cause a
"Registration Failed". Charge the battery for a few
hours and try the registration ( II ) again.
NOTE: the base can only handle 5 handsets and will
increment the number of each handset registered
until "Handset #5" has appeared, even if some of
the handsets are lost/not in use. Trying to register
more than 5 handsets will result in "Registration Failed."
III. To clear the base of all handset registrations and
be able to start registering again at Handset #1:
1. press [Find Handset] on the base and hold past ~4 sec when the "In Use" lamp lights, at
about 10 secs the "In Use" lamp will begin to
blink.
2. release the [Find Handset] button momentarily,
then briefly press it again. After a moment,
all handsets that were registered to the base
(if any) will display "Not Registered" and be
ready for fresh registration
3. for multiple handsets, return to II. above and
register each handset in turn.
Good luck !!
May 02, 2016 | Vtech Lands Phones
3 of my 5 phones say "No Line"?
This sounds like a registration problem, the errant
handset(s) and the base have lost identification
with each other.
NOTE: the CS6429 works a maximum of 5
handsets, so you have a "fully populated system".
You will have to clear each handset ( I ) then clear
the base of all registrations ( II ) before re-registering
each handset ( III ).
( I ). First de-register each handset ---
1. press [menu]
press [select]
(this is why the cover was off)
replace the cover
( II.) To clear the base of all handset registrations
blink. 2. release the [Find Handset] button momentarily,
ready for fresh registration ===============================
( III.) To register each handset to the base:
"Handset #x" or it will say "Registration Failed".
few hours and try the registration ( III ) again.
Good luck !!
Apr 16, 2016 | Vtech Accessory Handset with Caller ID for...
Why does screen indicate "searching"?
The handset cannot communicate with its base.
When the handset cannot establish its secure (encrypted) radio
link with the base it is 'paired with' or 'registered' to, it will first
say "Connecting....", then it will display "Out of Range or No
Power at Base", then it settles at the infamous "Searching..."
display.
Although rare, the registration between base and handset can
become corrupted and lost so that we must de-register and
then re-register the pair.
First, ensure that power is 'on' at the base (a more common cause)
and the cradle will charge the handset, etc.
Second, be sure the handset battery is well charged as a weak battery will interfere with the registration process.
Then try the following ( 'works for the D1680, D1481, and similar):
To deregister the handset:
1. Press and hold the [END] and [ # ] keys at the same time,
after a few seconds the display will say
"System Reset, Deregister Handset"
press [SELECT]
scroll to "Base Unavailable"
press [SELECT] (chirps) press [END]
display reads "Place in base..."
Next, to re-register the handset:
2. Set the handset into the base cradle and wait,
after ~30 seconds the handset should display
"Handset #" and be good to go...
or it will display "Registration Failed"
Mar 20, 2016 | Uniden DECT 6.0 Cordless Phone
Have a replacement handset, base is cs6729-2 handset is cs6729-3 how do i set up new handset to see base?
This sounds like a registration problem, the new
handset must be de-registered from its original
base and then registered to your base.
NOTE: the CS6729 handles a maximum of 5
handsets. If you have a handset displaying
"Handset #5" then you have a 'fully populated system'
even if you actually have only one or two handsets.
You will need to clear each handset ( I ) then clear
each handset ( III ) up to the maximum of five.
( I ). First, to de-register a handset ---
1. press [menu]
press [select]
replace the cover
( if needed, else skip ahead to ( III ). )
Good luck !!
Oct 29, 2015 | Vtech Lands Phones
Hand set says connecting even before it is reset with new base.
This sounds like a registration problem, each 'old'
base and then registered to the 'new' base.
NOTE: the CS6229 handles a maximum of 5
1. press [menu]
press [select]
replace the cover
Good luck !!
Jul 23, 2015 | Vtech Lands Phones
I have a vetch mod# CS6114 I checked the base unit and it gets power to charge phone but I can't get a dial tone. I even hooked up to another line and still won't work.
handset must be de-registered from wherever
it thinks it is and then registered to your base.
( I ). First, to de-register a cs6114 handset ---
1. press [menu]
4. scroll from "Test Base" to "Test Handset", press [select]
press [select]
replace the cover
( III.) To register the cs6114 handset to the base:
NOTE 2: Some cs6114 bases do not have the "In Use"
lamp indicator. To register the handset simply park it
displaying "Not Registered" in the base cradle and wait
for the registration to occur. Pressing # as above may
be required, maybe not.
Good luck !!
Feb 12, 2015 | Vtech DECT 6.0 Cordless Phone with Digital...
Vtech cs6649 will not register more than one handset
The errant handsets must be de-registered from their
original base and then registered to your base.
NOTE: the CS6649 handles a maximum of only five
In that case, you can clear each handset ( I ) then clear
1. press [menu]
press [select]
replace the cover
Good luck !!
Jan 09, 2015 | Vtech Lands Phones
My phone displays out of range how to correct
This sounds like a registration problem. Try
de-registering the handset(s) and re-registering
to your base.
NOTE: the CS6429 handles a maximum of 5
1. press [menu]
press [select]
replace the cover
Good luck !!
Oct 02, 2014 | Vtech Accessory Handset with Caller ID for...
Vtech cordless handset CS6209 will not connect with CS6229-2 base
Yes. The'old' handset must be de-registered from its
1. press [menu]
press [select]
replace the cover
Good luck !! --
Jun 08, 2013 | Vtech Lands Phones
My Uniden 1560-3 has out of range on all handsets but one. I only have a dial tone on one handset. Please advise how I can correct this problem
Reset the hand sets that are out of range by doing the following:
1) Press and hold END and # for at least five seconds.
2) Move the cursor to select Base Unavailable and then press Menu/Select.
3) Select the base which you want to de-register from, and then press Menu/Select. Base Unavailable appears.
4) Move the cursor to select Yes, and then press Menu/Select. You hear a confirmation tone,
(For DCX150 handsets)
5) Place the handset in the base cradle for about thirty seconds. Handset Registering will appear in the LCD.
6) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
If the display shows Registration failed, repeat the process again.
(For DCX200 or DCX300 handsets)
5)Disconnect the base AC adapter. Then press and hold find while you reconnect the adapter. Keep holding
find until the charge LED starts to blink.
6)When charged, registered handsets display a handset ID number. Handsets that have not been registered display:
7) On the handset, press and hold # until the handset beeps and displays Handset Registering.
8) When the handset has registered to the base, the LCD will display Registration complete then show the handset
ID number.
User Manual Available Here
Jun 16, 2011 | Uniden Cordless Phone
Uniden DECT 6.0 Cordless Phone ID Logo
100 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
