Question about Jasco Computers & Internet
I bought a GE Wireles Keyboard and Mouse Model 98552 which was my first wireless keyboard and mouse for my desktop. After about 4 months the Wireless mouse quit working. I tried everything recommende
There is a single USB transciever for both the mouse and keyboard. The mouse still lights up when you turn it on. The mouse has an on/off switch and a "connect" button and runs on 2 AA's. The keyboard has none of the on/off or connect buttons but it also runs on 2 AA's. If any good comes out of this, it would be that the printing on the keyboard "keys" should be manufactured with a more durable ink or protective coating, and the instruction manual which is very minimal should have some reccomendations on how to possibly fix the mouse if you know the "transciever" is working because the keyboard still works. For anyone who considers buying this combo set, the bottom of both the keyboard and mouse are labeled "98552" "Rev.K1". So its possible that later revisions have these issues fixed.
5 Suggested Answers
JoshOHoward
  • 63 Answers
SOURCE: wireless keyboard stopped connecting to receiver
Im sorry but you are going to have to phone and tell the device manager the problem again otherwise get a refund and go with the wired keyboards!
Hope this helps - JoshHoward
Posted on Feb 02, 2008
SOURCE: keyboard not responding
Solution. My wireles keyboard stopped working except for the F-Lock key, the Media key and the sleep key. It wasn't batteries, even though I tried, communication was there because the above keys were working. Remove the batteries from your keyboard and let it sit for about 10 minutes. Press the red connect button a few times and other various keys every few minutes during that time. This may be the whole "capacitor discharge" trick, but I tired that with someone elses instructions and my keyboard did not work after 2 minutes of key pressing. I think it just needed more time to clear out the secure settings. Good luck, I was about to trash this keyboard until I tried again
Posted on Jun 26, 2008
thydzik
  • 86 Answers
SOURCE: Replaced Microsoft Wireless Optical Mouse 2000 doesn't work
I would have suggested opening up your old mouse and cleaning the right click button first.
Generally, wireless devices have a connect button that finds the frequencies of the devices. On the receiver press this button, then press the button on the bottom of your new mouse. the receivers lights will stop flashing once connected.
Posted on Jul 21, 2009
joeguest2
  • 2080 Answers
SOURCE: my ge wireless mouse 98552 won't hold a
Assuming the batteries in the mouse and keyboard are fully charged, next make sure all your cables are inserted correctly.
Check that the data cables leading from the base unit to the computer are securely inserted into the proper connectors at the rear of the case.
Next make sure the power cord for the base unit is plugged into a live power outlet and that the other end is securely plugged into the back of the base unit. Often times this plug will come out halfway and so will look plugged in but will cause intermittent problems.
Next make sure your mouse is not too far away from the base unit when you try to use it. Normally 8 or 10 feet is the maximum distance these units will function properly at. Also make sure there are no obstructions between the mouse and the base unit. You can also clean any dust or debris from the small LED bulb on the underside of the mouse with a dry QTip to ensure that is not the problem.
Now depress the CONNECT button on the base unit, then while the light is flashing depress the small CONNECT button on the bottom of the mouse.
Now try using the mouse.
If the unit still does not function after that, then leave them plugged in and RESTART your computer.
Repeat the CONNECT procedure for the mouse after your computer restarts if necessary.
You may have to do the connect procedure 3 or 4 times before it connects properly so just keep trying the connect process until it works. Make sure you have the mouse right right beside the receiver when you do the connect procedure. Also make sure you use a mouse pad under the mouse, some surfaces do not work well with certain mice. Also make sure there are no other wireless mice in the same room when you do this. Also make sure you don't have a regular mouse plugged into the computer at the same time. Try switching the receiver to a different USB port on your computer just in case the one you are currently using is faulty.
Please comment back here to this page if you have any questions, or just require further general assistance and I will respond as soon as I see it.
Thank you very much and good luck.
Joe.
Posted on May 06, 2011
I cant get my logitch wireless keyboard to work
Do as I did. Get a 5 dollar wired keyboard and put the Logitech wireles keyboard in the garbage can where it belongs. I can't start describing the many problems I had with it. The mouse went the same way weeks earlier.
Jul 25, 2010 | Logitech Wireless Access Duo Optical...
I have Model 1058 Mouse bought 12/09. Computer crashed (motherboard) and had to get new one. Can't find installation disk for mouse. Can you help?
change the mouse battery and there is a button named connect on mouse keep pressing the connect button for 3-4 minuts and keep mouse near wireless device which is connected to the computer in USB port then restart your computer and mouse will work fine.
Mar 30, 2010 | Microsoft Wireless Laser Desktop 4000...
My mouse won't pick-up my icons !!!
go the bios setup and re enable mouse setting
Mar 26, 2010 | Labtec Wireless Desktop Keyboard/Mouse...
I cant find the conect button on my wireles logitech mouse so I can canect it to my computer how do I conect my wireless mouse
Basically, that kind of mouse has a USB connector. You PC contains about 6 USB port so that would surely fit in.
Mar 09, 2010 | Logitech Wireless Access Duo Optical...
I can't make double letters
well thats not good.same thing with my little brothers kboard.the letters O & L r stuck 2 gether though...
Jan 25, 2009 | Labtec Wireless Desktop Keyboard/Mouse...
Logitech wireless mouse and keyboard
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Hope this helps. Bud
Sep 26, 2008 | Logitech Cordless Desktop MX 3000...
Computers & Internet Logo
50 people viewed this question
Top Jasco Computers & Internet Experts
David Payne
David Payne
Are you a Jasco Computer and Internet Expert? Answer questions, earn points and help others
