Question about Frigidaire Refrigerators
Frs26r4cbo refrigerator side freezing all contents
4 Suggested Answers
SOURCE: Side-by-side freezing on refrigertor side bottom drawer.
For $20 I'll would gladly tell how you how I did it.
Posted on Nov 20, 2008
rpbuice
  • 161 Answers
SOURCE: Refrigerator side is freezing contents
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
If your settings are right then the cold control switch is the problem
Posted on Dec 16, 2008
  • 363 Answers
SOURCE: Maytag sidebyside refrigerator, refrigerator side
I WOULD INCREASE THE TEMPERATURE SETTINGS TO A HIGHER SETTING. Oh ABOUT THREE OR FOUR DEGREES SHOULD BE ENOUGH
Posted on Jul 19, 2009
Vegetables freezing in crisper drawer
This is an issue with the convection system in the refrigerator, while the cold air trapped withing the crisper drawer remains and the temperature of the moisture in the area drops below the freezing point, the water content acts as a cover and thereafter enables the vegetables to freeze. A slight rearrangement of the utensils within the refrigerator solved the problem
Jan 21, 2011 | GE GSS22SGM Side by Side Refrigerator
Refrigerator is too cold and freezes contents after a while/
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Nov 15, 2010 | Frigidaire Professional Series PHS68EJSB...
Freezer door handle is loose
Usually those handles push directly up to come off the pegs. You really have to "lean in" to push the handle against the door and then try to slide it up. Once you get it off, you can tighten the studs (or whatever hook/clip thingy they came up with) and slide it back on.
Feb 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
Food on the top shelf and in the bottom drawer keeps freezing
I'd check the temp control and up the temp abit instead maybe you have it all the way down low at the lowest setting, that will cause the contents to freeze.
Feb 03, 2010 | Viking 42 in Built In Professional...
Jul 19, 2009 | Maytag MCD2257HE Side by Side Refrigerator
New Samsung Refrigerator
it looks like you have a crook thermostat. turn the knob counterclockwise and listen if it clicks if not its defective.
May 05, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
Vegetable & Meat Tray Freezing on refrigerator
you have the freezer set too low. set it at -02 degrees and then turn up the adjustment for the meat tray and the humidity up on the vegetables. let me know if this helps.
Jan 08, 2009 | Kenmore Refrigerators
Freezing in refrig and freezer.
call the tech back... the control board may be fauilty or install incorrectly.. the water leak is from a pluged drain hose or your ice maker leaking not from a control board...
Aug 16, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
24 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
