Question about Pulsar Ladies Watch
Battery white stag watch - Pulsar Ladies Watch
2 Suggested Answers
SOURCE: removing links to shorten watch
I just removed links from one of the white stag watches today. The answer is in the link below.
http://www.watchmaterial.com/How_to_size_a_watch_band.asp
Friction pins are used to hold the links together. I used a jeweler's screwdriver and a small hammer to tap them out in the direction of the arrow. I put them back in the same way.
Posted on Apr 19, 2009
Do Coifman watches work by battery or are the solar powered
Do you see a itibiti tiny solar panel in the face of the watch? If not like all watches it uses a tiny button battery
Jun 07, 2016 | Watches
How do I change the battery on fossil motorcycle clock?
You will need a very small (watch or glasses) Philips head screwdriver, and a SR626SW (or know as a 377) watch battery.
Remove screw 1 to remove the motorcycle back cover.
Remove the other 2 screws to take off the clock backing.
Remove the white plastic ring by pulling directly up.
Remove the battery.
Put the new battery in.
Press the white plastic ring back on.
Reassemble the clock backing with the two screws.
Reassemble the back of the motorcycle with screw 1.
May 24, 2012 | Watches
My nooka watch constantly blinks and makes beep sounds. how do i stop this? and why it is beeping?
Hi there! A Nooka watch flashes and beeps when the battery is almost at its end. The battery required is a CR2016. You should be able to get the battery replaced at any local watch repair or jeweler!
-Nooka
Sep 10, 2011 | Nooka ZOT V - White Face - White Strap...
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How do I change the battery/ies for the watch? The red light still functions, but the timepiece does not.
    I took a clip watch to the Mall today and had the battery replaced at the Dakota Kiosk. It cost $10. They used a tiny knife to pry off the back. I was trying to use a screwdriver and that didn't work.
    Sep 09, 2010 | Dakota Angler II 3864-9 Pendant Watch
    Hello i changed the battery on my dakota angler II and the only thing that works is the red light, no time analog and or digita, none of the buttons do anything except the red one for the light.
    Did you change the battery yourself? Did you have instructions? The reason I ask is only because some watches/etc have more the one battery for various functions. Sometimes there are more batteries underneatch the battery you replaced.
    I would call the manufacturer and ask them if you have the number.
    Jul 22, 2010 | Dakota Angler II 3864-9 Pendant Watch
    Removing links to shorten watch for a ladies Wallmart watch brand is white stag #Ws50880w
    Dec 28, 2008 | Pulsar Ladies Watch
    Watches Logo
    Top Pulsar Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Pulsar Watch Expert? Answer questions, earn points and help others
