Question about Apple eMac Desktop
Hi  i have a desktop emac 1.25 GHz 80gb and every so often  i get what i think must be a graphics problem where i get verry thin lines in all directions across the screen  its verry hard to explain but the screen freezez when i get this problem hope you can help !! thanks
  • 115 Answers
Graphic card appears to be broken, you may have to change it (very cheap)
Posted on Feb 04, 2009
My Apple eMac G4 M9425LL/A Desktop does not fill up the desktop. How can I maximize the desktop
Hi Buchi
Do you mean you get a small desktop inside the screen surround by blank space or black?
If so then I think you are reaching the end of the eMac's life.
These machines have been very good overall. Some had the dreaded capacitor problem , but Apple fixed that on affected machines by replacing the motherboard.
I have of late though seen a few eMacs with display problems. I have one here now with a very pink display - as a computer it works fine, but the display (or display electronics) is giving up.
Unfortunately it is probably not cost-effective to try to repair these machines.
One thing you can do though is connect up an external monitor.
See if you can borrow one and plug it into the video out port (the socket right at the end of the line of connectors on the side of the eMac) You'll need a suitable adaptor though.
`If that display is fine then the problem is with the tube itself, but if the problem is still there, then then the issue is probably the video board - again not worth repairing.
let us know what happens.
Nov 19, 2013 | Apple eMac Desktop
My emac will freeze frequently, sometimes images become fragmented before freezing, other times when I start up the desktop is empty and I have to re-start to see the icons, and another weird thing happens...
You may need to update your Emac RAM and video card because this can be the cause why you have this slow and strange apperance your screen..
Hope that helps.......
Aug 04, 2008 | Computers & Internet
Manual for emac 1 ghz power pc
Best place is eBay for parts but you can find all sorts of manuals with Google.
Feb 12, 2012 | Apple eMac G4 Desktop
I am looking for thin client with ambeded processer with 4 GB Ram please tell me about thin client configaration
Hi DB_minse. Check out the Devon IT line of thin clients here: http://www.devonit.com/hardware - I believe the TC5c units can come as 4GB ram- and as far as I know they are a very good brand!
Feb 14, 2011 | WYSE R90L Thin Client AMD Sempron 150 GHz ...
I have an eMac and would wireless USB adapter to work
It depends on which eMac you have. The 1/1.25 Ghz and the 1.42 ghz models have USB 2.0 so either adapter will work. The slower speed eMacs only had USB 1.1 and will not work for those types of adapters. The 700/800Mhz models will use the original AirPort card while the rest of the eMacs use the Airport Extreme cards.
Dec 30, 2009 | Apple eMac G4 Desktop
My emac is verry slow
Hmm can be any number of things - how many programs do you run at the same time? Do you have lots of dahboard applications running? Is your hard disk severely fragmented? When is it verry slow?
Jul 05, 2009 | Adobe Computers & Internet
MAC G4 won't boot - Blue screen appears
Hi Sorry to hear you are having troubles,You will need a firewire 400 cableOK, first thing you must do is reboot the eMac in TARGET mode, this means it will be recognized as an external disk. To get the eMac in TARGET mode, you must be sure the eMac is turned OFF and has a functioning keyboard connected.Power on the eMac and very very rapidly press the ( T ) key on the keyboard, be sure the caps lock button is not pressed. If all goes well, you will see the firewire logo appear larger than life on the screen.( If you are unable to get into TARGET mode, it is highly probable that the mother board of the internal hard drive is damaged and preventing the eMac from entering TARGET mode, sorry, that's the end of the line..)Once you enter TARGET mode on the eMac, connect the firewire cable to your G4 PowerBook, you can do this either while it is running or when it is off and then turn it on.
You should see the volume of your eMac internal hard drive appear on the PowerBook desktop...sometimes you need to open Disk Utilities and repair or mount the drive manually.If this all works well, copy the required files directly to your PowerBook...After that, power off both machines, disconnect them and reboot the eMac using a CD or DVD to reformat and reinstall a new system.
Mar 30, 2009 | Apple eMac G4 Desktop
Hp monitor blinking blue light
sounds like you graphics card is loose or you have a loose connection check graphics card and cabling.
May 22, 2008 | Apple eMac G4 M9425LL/A Desktop
Apple eMac Desktop Logo
53 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
