Question about Acer V173 b Monitor
Screen Stays white, mac turns on monitor but stays white no picture
5 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: turned on monitor and screen stays white no
If all you see is white glow on the screen, it can be caused by: The ribbon cable between the logic board and the LCD may have come lose or dirty contacts, or there is no 5vdc feeding the LCD panel, or blown fuse on the LCD panel controller board. See pictures here: http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Posted on Mar 28, 2010
budmrtn
  • 11361 Answers
It sounds like the T-CON board (part of the LCD panel assembly) is not getting 5vdc. Check the power supply and logic bd caps. Check fuse on the T-CON BOARD.
See LCD panel pictures and bad caps:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=acer&megnev2=al1716&kategoria=monitor&kat2=schematics
Posted on May 17, 2010
budmrtn
  • 11361 Answers
SOURCE: I have a Acer V193W Computer Monitor. When I turn
The LCD panel is not getting the 5/12vdc from the logic board or the fuse on T-CON board is blown or bad T-CON board, it can also be due to bad 5VDC power supply caps in the power supply and in the logic board.
Please read my guide and look at the pictures at my photobucket.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Posted on Nov 04, 2010
budmrtn
  • 11361 Answers
SOURCE: Monitor green "on" light comes on...Screen stays
Here are the service manuals: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1916W&kategoria=monitor&kat2=all
Here are the pcitures:
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1916W%20Abd/
Here is the troubleshooting guide:
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Learn about bad caps: Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Nov 11, 2010
Why does my iMac stay on a white screen when started?
Here's a video Charles East suggested as a solution to your problem from YouTube:
How To Fix White Screen On Your Mac
Mar 24, 2013 | Apple 24" iMac Desktop
NO picture
Try attaching an external monitor to the notebook & see if you will get display on it or not. If this works, then you most probably have a defective or loose LCD screen cable, that need to either be replaced or properly connected.
Jun 17, 2010 | Apple PowerBook G4 Mac Notebook
When I turn on my mac g3 works but the screen stays
Some models of G3 iMac have an external display connector under the rear belly plate. Connect a monitor to this connector. If that monitor shows your desktop, your main CRT is blown. The cost of replacing a CRT in this model is almost certainly more than the residual value of the machine.
May 29, 2010 | Apple iMac G3 Desktop
Turned on monitor and screen stays white no icons..etc
May 15, 2010 | Acer AL1716B 17" LCD Monitor
Mar 28, 2010 | Acer AL1716B 17" LCD Monitor
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Screen stays white and it has a flashing file with a ? in folder
what this means is that the computer can't find the system. the repair could be a simple system reinstall or you may need a new harddrive in the computer.
Hope its the reinstall
Cheers
Jun 27, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Dark Screen
Try connecting to an external monitor. If the monitor displays correctly, then the problem is with either the inverter or the screen.
Jan 04, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Moniter stay white when turn of computer
If you turn off the computer you should be turning off the monitor as well.. is the monitor still white when your monitor is set off? if not, then its normal.
Aug 16, 2008 | Computers & Internet
Acer V173 b Monitor Logo
18 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
