Tv keeps going into stand by
My matsui 42" lcd tv model 42lw507 keeps switching to stand by mode
  • 15 Answers
SOURCE: 50 inch LCD rear projection Bravia TV
Could be faulty fan, check and see if it is spinning correctly
Posted on Dec 15, 2007
  • 15 Answers
SOURCE: tv stand screws
Check the kitchen drawer next to the fridge for the screws !!
When you get new screws, use lengths 1/2".. any longer and you might hit something inside.
Don't know why this is posted under IS-LCDTV26.. I would pull a screw from my 26" and measure it, but it's most likely different than your 42"
Posted on Sep 06, 2008
SOURCE: onida stand by problem
sir my onida tv 21'' ineed un lock
Posted on Nov 20, 2008
SOURCE: Matsui tv assistance
Have just read up on this. It seems you have to hold the - volume on the front of the TV at the same time as the no 7 on the remote for 5 secs to reset the PIN number.
Posted on May 26, 2009
KhasKardash
  • 8 Answers
SOURCE: switches itself off
Maybe you have Ghosts...? :D
Posted on May 31, 2009
My 42 inch matsui tv will not come off of stand by mode. how can i fix this
It will need a PCB replaced and testing done by a skilled tech to determine which one failed.
Jan 23, 2017 | Televison & Video
Cost to replace plasma on Sansui 42 inch TV
Hi Richard,
An original Sansui stand could be expensive try to find a universal stand to suit your TV here are some that should accommodate your TV: MISC STAND 3755BB 37 55 Lcd led plasma Stand
Jan 24, 2016 | Sansui Televison & Video
My 42 in matsui tv wont come on at stand by you have to keep on turning it no for a bout 10 minits or moor
Sounds like main board fault. Power ON signal should come from the main board to power regulator board, to switch in ON from standby to power ON. Contact any service technician. The troubleshooting to this kind of fault is a skilled work. Not user repairable.
Gopakumar Gopalan Google
Apr 22, 2014 | Sony KV-32XBR85 TV
What should i do is my LG 42LC2RR's stand by light keeps blinking but it does turn on
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 04, 2012 | LG 42LC2RR 42 in. HD-Ready LCD TV
42 lg tv base stand 2007 42 lc2d-ec
TvPartsGuy.com carries lots of original pedestal stands for LCD & Plasma Tv's.
https://www.tvpartsguy.com . use coupon code: fixya10 for 10% off your stand.
Nov 24, 2011 | LG 42LC2D 42 in. LCD HDTV
Hi there. I have a 42" Matsui M42LW508 LCD TV.
probably there's a lose solder in the power supply board of your lcd,
and maybe from inverter board. these two parts of lcd consumes much power and heat.
so once you use it can produce heat that can affect the solders under the board.
the same with inverter board.
if you know how to disassemble or some technical knowledge you can re-solder it by using soldering iron and lead.
but if you not capable, go to repairman and let him do the work.
it has to be repair before it can affect other parts of lcd.
thanks.......
Sep 01, 2011 | Televison & Video
I can't turn off the tv it only goes into stand-by mode (both button on remote and on the tv)is there something i'm missing or do you have to turn it off at the wall?
There are no dedicated on/off switches on these TV's as in the older style televisions. It will remain will the stand-by condition unless it is physically turned off at the wall socket. This is becoming a standard set up on a lot of LCD televisions.
Apr 26, 2009 | LG 42LG30 42 in. LCD HDTV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
