Question about Dishwashers
Dishwasher for 32 inch cabinets
I know most dishwashers are 24 inches...but that isn't "tall"...the standard dishwasher fits under 34 inch cabinets and our cabinets are 2 inches shorter than stock cabinets. They were built that way for my 5 ft. tall grandmother...all the dishwashers we have looked at are too tall to fit under the cabinets...we need one that will fit under the 32 inch cabinets
  • 128 Answers
Miele makes a G600 series that are 32 1/4 " tall - that would probably be your best bet.
Posted on Jan 05, 2009
Which dishwashers are less than 830mm high, to fit under my work surface?
Peter,
830mm equals 32.68 inches. You will just have to look at the specs of any dishwasher that you are interested in and see if they will fit in less than that height. Most dishwashers that I have installed would fit between 32 and 34 inches in height. Hope this helps!
May 15, 2015 | Dishwashers
Avanti calls for a cabinet height of 34 1/2". However, the dishwasher is only 32 1/4" tall. What do you do to fill the gap of 2 inches at the top?
you don't fill the gap. There needs to be some clearance for the door to be able to swing open without contacting the underside of the counters. You can always decrease the gap a little by using the adjustable stands on the bottom of the unit. The unit will come with a kickplate that can adjust to multiple heights.
Apr 27, 2015 | Avanti Dishwashers
What are the dimensions on a Kenmore 363.14192992 dishwasher?
Dishwashers that are installed into standard kitchen cabinets have a standard width and depth of 60 cm (Europe) or 24 inches (US), and most dishwashers must be installed into a hole a minimum of 86 cm (Europe) or 34 inches (US) tall. Portable dishwashers exist in 45 and 60 cm (Europe) 18 and 24 inch (US) widths, with casters and attached countertops. Dishwashers may come in standard or tall tub designs; standard tub dishwashers have a service kickplate beneath the dishwasher door that allows for simpler maintenance and installation, but tall tub dishwashers have approximately 20% more capacity and better sound dampening from having a continuous front door.
Feb 06, 2015 | Kenmore Dishwashers
Which is the exactly dishwasher dimensions
Hello giov..... the dimensions of the whirlpool DU930 require an opening that is 24 inches wide x 24 inches deep by 34 inches high.
Here is the manual showing these and many other measurements for this machine
http://www.managemylife.com/mmh/installation_guides/3874/WHIRLPOOL-Dishwasher-L0409637?brand_name_search=DU930PWWQ0+WHIRLPOOL
Joe
Thanks for choosing Fixya!
Mar 09, 2011 | Whirlpool DU930 Built-in Dishwasher
What are the product dimensions
Hi and welcome to FixYa, I am Kelly. The installation guide with the dimensions can be found here:
http://www.managemylife.com/mmh/installation_guides/3932/KENMORE-Dishwasher-L0504234?brand_name_search=665.15952 (7.87 mb file)
The top of the cut out is 33 & 7/8" Min. to 34 & 7/8" Max (adjustable legs for height)
Minimum space to counter top parent material 1/4" (Top of dishwasher cabinet is screwed in at the top)
Depth 24 & 1/4 inch minimum
Width 24 & 1/4 inch minimum (Allows for 1/8" clearance on both sides)
Thanks for choosing FixYa,
Kelly
Feb 22, 2011 | Kenmore 15952 Dishwasher
Dishwashwer wont fit under counter
it depends on how much tallerit is . you can adjust the legs but you have to know how much. if this helps let me know.
Dec 27, 2009 | Whirlpool 24 in. DU1100XTP Built-in...
Height for dishwasher is only 33.5 inches
we found a fridgidare dishwasher the had a range of 32.5-34 model number FDB2410HIC1 try it, it saved us from having to do alot of tile cutting
Jan 05, 2009 | Dishwashers
I need a 32 inch dishwasher to fit under existing cabinets
32 inch is bigger than I have ever seen - the standard is 24" - but apartment models can be 18"
Jan 04, 2009 | Dishwashers
32 inch dishwasher...
hello Welcome
I believe Ge makes one to go under a sink!
And that's the only one! that low.
Thank you Huum
please leave a solved rating before you sign off
Dec 07, 2008 | Equator Dishwashers
Dishwasher
Hello Booklice,
Normally a standard base cabinet is 24 inches deep with a 25 inch countertop ( meaning the top extends over the front of the cabinet by 1 inch) That is a typical installtion however there is no right or wrong way to set the dishwasher into cavity between two cabinets. In most installations though the front door of the dishwasher when closed is close to flush with the vertical stiles of the cabinet and does not extend beyond the overhang of the counter. The manufactures method for securing it to the surrounding cabinets will dictate the extent that it can project out. Hope that helps...
Regards
Oct 05, 2008 | LG 24 in. LDF 7811 Stainless Steel...
Dishwashers Logo
243 people viewed this question
Top Dishwashers Experts
