12 gauge
This is the cars and trucks section, but I will try to help. Make sure your barrel is fully turned into the receiver. Check for cleaning pads jammed into a moving part. Make sure your shell length is correct for the gun.
Try different Factory ammo, reloads may be deformed. Bring some of its' used casings along to a Gunsmith, he/she may be able to look at them and see machine marks from how the firing chamber is operating.
I hope my solution is helpful, please rate.
Fuel pump not running?
http://schematicsdiagram.blogspot.in/2012/02/fuel-pump-not-running.html
Fuel pump not working on 1991 Ford Ranger?
http://technoanswers.blogspot.in/2012/01/fuel-pump-not-working-on-1991-ford.html
Fuel pump has no power on 2002 ford 350 7.3 diesel?
http://technoanswers.blogspot.in/2012/01/fuel-pump-has-no-power-on-2002-ford-350.html
Emergency fuel shut switch on Ford car?
http://schematicsdiagram.blogspot.com/2011/12/emergency-fuel-shut-switch-on-ford-car.html
How to jump fuel pump On Chevrolet Silverado 1500?
http://schematicsdiagram.blogspot.com/2011/12/how-to-jump-fuel-pump-on-chevrolet.html
How to Increase gas mileage on 2011 2500HD Duramax 6.6?
http://schematicsdiagram.blogspot.com/2011/12/how-to-increase-gas-mileage-on-2011.html
How to test Fuel Pressure and replace Fuel Pump?
http://repairhelpcenter.blogspot.com/2011/11/how-to-test-fuel-pressure-and-replace.html
Fuel Running Lean
http://technoanswers.blogspot.com/2012/10/fuel-running-lean.html
How to relieve fuel pressure?
http://technoanswers.blogspot.com/2012/01/how-to-relieve-fuel-pressure.html
Refueling problem?
http://repairhelpcenter.blogspot.com/2012/01/refueling-problem.html
Toyota Tercel consuming more fuel?
http://repairhelpcenter.blogspot.com/2012/01/toyota-tercel-consuming-more-fuel.html
How to maximize fuel economy on your vehicle?
http://schematicsdiagram.blogspot.com/2011/11/how-to-maximize-fuel-economy-on-your.html
Fuel gauge jumps from empty to full?
http://schematicsdiagram.blogspot.com/2011/12/fuel-gauge-jumps-from-empty-to-full.html
Gas gauge stuck on empty on 2002 Mercedes Benz 240c?
http://repairhelpcenter.blogspot.in/2012/02/gas-gauge-stuck-on-empty-on-2002.html
No power to the control side of the fuel pump relay?
http://schematicsdiagram.blogspot.com/2011/12/no-power-to-control-side-of-fuel-pump.html
These will help.
Thanks.
