Instructions how to change toyostove laser 73 igniter
Buffalo12980
  • 625 Answers
SOURCE: Toyostove Laser 30 has error code EE 22
EE-22 means that the unit has tried three times to ignite. after this it goes into a "lockout" condition. remove the power and the computer will reset itself. it will then try to re-ignite. check for a fuel blockage, dirty filter etc. if there's water in your kerosene it will not fire! kerosene floats on top of water. bleed your system until you get kero and no water. use a gas additive to remove water. dry-gas will work. just empty the bottle's contents into your tank. on your computer type in toyostove error codes. this will take you to toyo's site and explains the error codes.
Posted on Nov 10, 2007
  • 3 Answers
SOURCE: toyostove laser 30 has error code EE22
EE22 is a lock out code that keeps you from continuing to try to start the heater. This code usually pops up as the result of a problem with the fuel supply (i.e. no fuel, fuel sys obstruction, clogged filter, water frozen in line, faulty igniter), but could be more serious. To clear the code the easy way, unplug heater for at least 30 minutes. While you are waiting, check your fuel tank to see if you have fuel. Then check filter to make sure the element is not clogged and that there is no air or water (or ice) in the fuel line. If you find a problem with any of these things, correct it before trying to start heater again.
For the rest email me at toyofreehelp@yahoo.com
Posted on Nov 21, 2007
Buffalo12980
  • 625 Answers
SOURCE: Toyostove laser 73 heater with a EE 2 error
replace the flame rod. or it could be the computer board for the flame rod. flame rod detects the presence of a flame.
Posted on Dec 02, 2007
Pnutgllry
  • 57 Answers
A manual can be found online by googling Toyostove 73 and owners manual or manual. I use it often. It is at on the rural energy website.
Posted on Jan 26, 2008
BudinAk
SOURCE: toyostove laser 73
My Laser 73 does the same thing at least once, and sometimes twice, a year. The EE6 code is what the onboard computer1.gif gives when it THINKS the flame has gone out. Now, it COULD be that all that is wrong is you are out of fuel, OR you have water in the fuel. But....the more likely scenerio, (and what has always gone wrong with mine) is a common problem in the flame pot:
There is a stainless steel baffle near the bottom of the flame pot. (about 2 inches off the bottem). This baffle is used to "form the flame", cause it to curl up around the inside edges of the pot, where the air intake holes are, to create a clean-burning, high-efficiency blue flame. Over time, this baffle becomes horribly warped and distorted from the intense heat. (an engineering design screwup, IMO) (but you'll never get them to admit it) This warping of the baffle, in turn, causes the flame itself to become uneven, and to also begin burning poorly, with soot deposits. One of the first hints this is happening is lots of YELLOW flame, instead of the usual blue. When this happens, the flame SENSOR becomes sooted and dirty, and no longer is able to sense the flame. It tells the computer to shut down, because it thinks there is no flame, hence the "EE6" code. This sensor is simply a stainless steel rod poking into the flame pot. It's on the front of the pot, two screw fastening, and has a single wire attached to it, which runs to the computer. It is used to detect IONS (minute current) running from the flame front to the pot itself. (ground) And....(as if all this is not enough), the gaskets around the middle section of the flame pot, and at the top, usually develop cracks and leaks.
Cleaning the sensor (with steel wool) usually isn't enough to fix this problem. You will likely have to replace both of the fire-pot gaskets, the flame pot baffle, and also the burner "mat". (a round, flat, fiberglass mat glued to the bottem of the flame pot. Vacuum out all the dirt and soot. The baffle "unscrews" with about a quarter-twist CCW. (lift upwards on it, while turning CCW) Use fire-proof sealer on the new gaskets. Plan on all day taking it apart, and back together again. (a time consuming job...no fun) Good luck!
WHY WOULD THE BURNER GASKET AND IGNITER GASKET BE DRENCHED IN FEL ON TOYO 73, COULD THIS ALSO BE THE CAUSE F NO FLAME IN CHAMBER WINDOW WHEN I TRY TO FIRE IT UP?
If you have too much fuel in the burn pot then you are getting no ignition. Repeated tries to get it to start just dumps more fuel into the pot.
Feb 24, 2014 | Rinnai Toyostove Direct Vent Heater:...
My toyp laser 73 is displaying ee2. we have fuel, what should I look for.?
Check for flame / ignition... if no flame, check igniter: after unit is turned on, the igniter should get hot - CAREFULLY feel the area where igniter is mounted to burner. If it's not hot, your igniter is bad, needs replacement.
If you have ignition, the flame rod (sensor) may be defective or need cleaning.
This document might help...
http://www.rural-energy.com/publications/catalog/documents/document-334.pdf
Feb 15, 2011 | Rinnai Toyostove Direct Vent Heater:...
Laser 73 will not have ignition , it has fuel it start with a green light and in about 3 to 4 mintues the fan start to run then i get a error 2
ee 2 is the code for no ignition. This can be caused by a dirty fuel filter or dirty fuel strainer. The flame rod may need to be cleaned. The igniter may be burned out. Could also be a circuit board problem. If the fuel pump makes a loud ticking or thumping noise then it is a fuel flow problem and I would check the filter and strainer first. When checking the flame rod be sure to unplug the heater first.
Dec 12, 2010 | Rinnai Toyostove Direct Vent Heater:...
Yoyostove laser 73 ee-2 keeps coming up which i know is missed ignition,but after a few times of missing ignition the k-1 leaks from the bottom of the heater what needs to be done about this problem?
Sounds like your igniter may have burned out. You can test the igniter with an ohmmeter. You can also check for voltage on the circuit board where the igniter connects. Don't try to start it again until you check the igniter because unburnt kerosene will just keep building up in the burner. Let me know if you need more help.
Nov 18, 2010 | Rinnai Toyostove Direct Vent Heater:...
Ok we were given a laser 73 and we have checked and there is kerosene reaching the heater but it wont lite what could i do
Check to see if Igniter is working (Dont touch)
just feel close to it, should be warm and you should see a glow inside the peep window.
Ask about service history It may be time to get it fully serviced
Good luck
call me if you need more help
Total Toyo
(907) 488-9179
Dec 07, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyo Stove Laser 30 will not work
The EE-8 indication means there is insufficient air flow to the combustion pot to atomize and ignite the fuel. Check your air switch for a closed condition when the blower is operating.
Oct 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Toyostove laser 73
Jan 13, 2008 | Rinnai Toyostove Direct Vent Heater:...
Dec 01, 2007 | Rinnai Toyostove Direct Vent Heater:...
Heating & Cooling Logo
434 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
