Question about Astatic CTM-44MC Professional Microphone
Astatic MOD.611 hoow to connect wires in part that plugs in. Red, Black,Green, white and a bare copper
4 Suggested Answers
  • 6 Answers
SOURCE: wiring/ i am lost
http://homepage.ntlworld.com/rg4wpw/astaticbook.pdf
Posted on Jun 16, 2008
SOURCE: Astatic 636l microphone Cobra 29ltd classic
pin 1= sh & bl
pin 2= wh
pin 3= red
pin 4= blk
yellow = not used or put on pin 4
Posted on Dec 18, 2008
SOURCE: Astatic 636L Wiring
how do I wire a d 104 to a keen wood tm 221a radio
Posted on Jan 25, 2009
HOW DO I CONNECT A JENN AIR MODELE C 202 C COOKTOP HAS 5 WIRES
Hello Ken,
What color are the wires i suspect they are red,black white,green or bare copper??
connect all the reds to the reds from the house wiring same for the black and white and connect the either green or bare to the green or bare wires
Nov 05, 2011 | Jenn-Air Cooktops
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
Nov 16, 2010 | GE 60minute Automatic ShutOff Timer Switch...
GE digital timer. Instructions say to: 1) connect Hot/live wire of main to black wire of timer, 2) connect neutral (White) wires together, 3) connect Hot/live wire of load to red from timer. 4) green to...
Find the Hot wire:
Your switch has 2 wires. One of these wires is Hot, and one goes to load. Disconnect wires from switch. Turn on power. Do not stand on wet surface. Test each wire to bare copper wire. When tester lights up, that is Hot wire. The other wire goes to load.
Connect wires:
Hot wire goes to Black timer wire
Wire to load goes to Red timer wire
White wire connects to white wires that are twisted together
Bare copper wire connects to Green wire from timer
How to connect white wire to white wires that are twisted together.
a) Strip white timer wire so you have 1-1/2 " of bare wire. Stranded wire will wrap around other wires easily.
b) Remove wire nut. DO NOT UNTWIST wires.
c) Hold all whites together so bare copper lines up. Wrap stranded copper around the twisted wire.
d) Replace wire nut, or use larger wire nut. Twist real tight. Do not use tape. You can solder the connection.
e) When done, pull on white time wire to make sure it is held tight. Push whites back into box.
Sep 25, 2010 | UPM Programmable Wall Switch Timer
I have a 240v plug in with 4 wires ( red and black-hot, white-common, and copper-ground) and on my campbell hausfeld air compressor i have only three wires ( white and black- hot and green-ground) how do i...
First are you sure your compressor is wired for 220. If so \,use the white and black for the hots connected to the black and red in your recptacle. Connect the green to green or bare conductor. The compressor most likely has no 120V devices on it so the neutral is not requied.
Jul 13, 2010 | Campbell Hausfeld Air Tools & Compressors
I wired up the the Fridgedaire wall oven and it worked for two days and then just shut off. It has a green, white, black and red. The white and green are taped together coming out of the oven. The...
the unit is 240 volts not 120 volts/its ok to have the wht and green tied together so long as it comes directly from the house main panel/new law in some places require them to be separate/wht=Neutral/Green=safety grd to case...now how many watts does this unit draw? 2/12 wires sound awful small for the input current/sounds like you need to upgrade to atleast 2#6 wires for power/1#8 for neutral and atleast a #10 for safety ground
Sep 30, 2009 | Frigidaire FEB24S2AS / FEB24S2AB Electric...
Have a Leviton dimmer with red, black and green wire. House wiring is black and white wire and copper wire. I assume that copper wire is ground and connects to green wire but I am not sure where the white...
You are correct in assuming green is the ground and connects to bare copper wire. Black is always the HOT wire and should be attached to the black wire. Red wire connects to white wire.
Sep 13, 2009 | Leviton Toggle Touch Dimmer - TGI06-1LB -...
Wiring problem
yes that is right, color to color turn of breaker before touching wires. green and bare copper go together.
Nov 01, 2008 | Jenn-Air JED8430 Electric Cooktop
Running 10/3 wire and wiring clothes dryer directly. The dryer does not have a ground connect for the bare copper ground. Can it be connected to the white neutral at the dryer?
NO!! use the green screw on back where cabinet ground goes red to red white to white black to black remove cabinet ground wire and connect it up to white neutral on dryer connect bare ground to cabinet ground screw ..but wouldn't it be better to connect wall plug to house wiring and correct cord to dryer? always hate working on hard wired equipment since a lot of breakers are never labeled or relabeled correctly
Jul 15, 2008 | Dryers
Electric Baseboard thermostat wiring
what is the make of the thermostat? are the heaters 240 volts?
Jan 27, 2008 | Heating & Cooling
Astatic CTM-44MC Professional Microphone Logo
152 people viewed this question
Top Astatic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Astatic Audio Player and Recorder Expert? Answer questions, earn points and help others
