Question about Cameras
Canon np6030 blank shutter image photocopier - Cameras
2 Suggested Answers
pabloloco
  • 2335 Answers
SOURCE: Canon Rebel XS has stopped recording images...
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS .
Installation of this Canon EOS Rebel XS firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Posted on Apr 15, 2010
Canon ir 1024 photocopier photocopy but the paper is blank what can be the problem
if print from computer ok than problem on scanner or both blank problem on high voltage
Jul 20, 2016 | Canon IR1024 COPIER FOR 220 VOLTS
I want to download technical support manual for canon np 6030 what should i do?
you can do a search online to see if there is someplace that sells the service manual for the NP6030 and purchase it from them. other than that i don't know of any other way to get a copy of it of if there is even a pdf file for the service manual for that machine. It is a analog copier and has been out of service for a long time
Jun 18, 2010 | Canon NP 6035 Copier
I have a canon xerox machine model 3020 copy is not comming,blank white paper is comming
Canon 3020 is a scanner, not a copier. It can scan a document & store. If you print the image, you will get a 'photocopy'.
S. Mohan
Sep 18, 2009 | Canon DR 3020 Path-Through Scanner
LCD screen is blank and pictures are also blank
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 24, 2009 | Canon PowerShot A620 Digital Camera
TRYING TO PHOTOCOPY AND PAGES ARE COMING OUT BLANK
this is a problem with the laser shutter. The shutter needs replaced with the new style. The shutter could also be just ripped out and left out but that would be unlawful to do around lasers. hope its still under warranty
Jun 24, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
Copies are blank pages and doesn't indicate toner problem.
Bad lasrer shutter. There is a redesigned one going in warranty claim machines. the shutter can be removed but it breaks safty laws.
Apr 22, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
How to change the drum
On this machine it is beter to get a technition out to replace the drum.It is not as easy as the NP6030.
Oct 31, 2008 | Office Equipment & Supplies
Canon NP 6030 photocopier is printing all black. Cannot rectify by altering shading setting. Appreciate any help to fix ASAP. warrengevans@tadaust.org.au
Hi
If it is solid black with no hint of an image in the backround, its an exposure lamp or exposure lamp fuse. Both are not user replaceable. To check, open the copyboard(lid over the glass) and push the print button. If you dont see the lamp come on under the glass it is most likely one of the 2 things mentionerd above.
Oct 30, 2008 | Canon Office Equipment & Supplies
Imagerunner 1310 does not photocopy
Do you have toner/drum cartridge in machine installed?
May 14, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
