Question about Frigidaire FWS833A Top Load Washer
Top loader Washer Model # GLWS1349AS1
My washer ( Model # GLWS1349AS1) is making a LOUD screeching noise when it gets to the spin cycle. It has never done that before and Im wondering if its a belt or what???
Any suggestions would be appreciated
Thank you
  • Anonymous Jan 08, 2009
    Same - when spin cycles starts it makes an awful screeching - is it a belt?
  • mau50 Jan 24, 2009
    I have the same problem the pump was replace to the machine. which I do not think it was the problem. It sounds like the belt or something? mau50@hotmail.com
  • 116 Answers
SOURCE: loud noise in spin cycle
Most leaks are associatd with your drain pumps although it can leak from the tub. If its the tube the seals in it are worn if it the drain pump - the first point to check is where the drain hose connecs to the pump otherwise you may need to replace the drain pump
The noise - if its what i am thinking of starts just as the spin cycle stsrts and just as it finishes - usually a clutch problem - worn - parts need to be changed.
Regards
Posted on Sep 20, 2008
philbran
  • 242 Answers
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
Posted on Dec 30, 2008
jsrock516
  • 5911 Answers
SOURCE: screeching noise in maytag topload washer
The following link explains the problem you are having with your Maytag:
http://www.fixya.com/support/r387833-maytag_washer_squeaking_problem
It is common for the brakes on Maytag top loaders to wear and make noise, as well, as the snubber. There is a helpful tip that you can try to quieten the noise if it is the snubber. DO NOT oil it, or lubricate with any petroleum based products! This will ruin the unit and actually make the problem worse. NOTE: If the snubber is excessively worn, it was also cause vibration on the spin cycle.
If the brakes are worn, however, you can put a light film of oil on the brake pad. It is common for the pad to collect moisture in humid and damp climates and start to squeak against the brake stator. The brake pad consists of a rotor with a leather edge (pad). The leather can absorb moisture and begin to squeak against the brake stator. Oiling it slightly will get rid of the noise.
Confused? If you have questions, please let me know. I hope you find this information useful.
NOTE: There is a follow-up comment at the bottom of the link I provided from another user. The method this person used to release the tension on the brake can save you from having to purchase the brake release tool.
Posted on Feb 28, 2009
SOURCE: loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Posted on Apr 21, 2009
  • 5 Answers
SOURCE: My model #gltr1670aso makes loud noises during spin cycle
Usually this is due to either the drum support breaking or the back bearing being bad-neither easy to fix- or worth it. Try lifting the drum up and down, if it moves up and down they are bad. I see this a lot, and the price of repair isn't worth it. Craig
Posted on Aug 02, 2009
Electrolux screaching noise on spin cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a loud screeching noise during the spin cycle on your Electrolux washer. You will hear a certain amount of motor whine during the spin cycle this is a normal operation of your appliance. -Matt
Aug 23, 2014 | Electrolux EWFLS70JRR Energy Star Front...
Washer making a loud noise on spin cycle..cabrio model top loader..
If you lift the outer cover you should see 4 supports at ech corner if one fell off it would spin un even and make a lot of noise
Sep 19, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer makes a loud, pulsing, screeching noise with no spinning
With a manufacturing date of 7/15/97, your washing machine is clearly worn out.
Nov 07, 2017 | Whirlpool Washing Machines
Loud screeching noise on spin cycle
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Dec 21, 2008 | Kenmore 24032\24036 Top Load Washer
NAV5800a top loader washer
The inside of your agitator became worn, and possible strip out the spline that allows the agitator to properly grip the shaft. The loud noise mustly occurs during the spin cycle. If you hear this loud noise your load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it.
Sep 02, 2008 | Amana NAV5800A Top Load Washer
Loud cliunking noise in beginning of spin then won't spin
get a flashlight and see if a foreign object has fallen down through one of the tub holes and is jamming the tub you have to look real close
Jan 11, 2008 | GE WJSE3110A Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
87 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
