Connection of Panasonic DVD Burner to San Sui Surround Amp.
The cable has 6 outputs and 6 inputs (Sub, C, FR, FL, RR, RL).
The San Sui Amp has 6 outputs but the Panasonic DVD burner only has 3 inputs.
At the moment I have only 2 inputs into the DVD from the San Sui 6 outputs (white, red) therefore only the FR and FL are working.
I know that all 6 speakers are functional as the radio in the amp successfully feeds all 6 speakers.
How/ what do I need to do to feed all 6 outputs into the DVD?
    Scholar:
  • 73 Answers
Cant be done, the dvd wont record in surround. you could try a digital TOS, optical audio path and that may do what you need, usually the digital is an orange single input. TOS is the square one that looks like a little bulb on the end.
Charles
Posted on Jan 05, 2009
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
Tip
DVD PLAYER to TV HOOKUP
Basic DVD player hookup to TV cable diagram. RCA cable (yellow) video and RCA cables (white and red) audio. This is all you need for picture and sound. If your TV only has a single RF input, then you need a RF modulator. RF modulators accept the yellow, white and red cables and output a coaxial cable to the TV single input jack. Usually the TV is tuned to channel 3 or 4 to pickup the RF modulators output.
Alternative connection options are many and include HDMI for HDTVs, component video and for sound, surround sound digital audio connection using optical or coaxial digital audio cable.
Surround sound requires a decoder such as a A/V receiver with Dolby Digital 5.1 or DTS 5.1 or more. 6 speakers connected to the A/V receiver surrounds the listener.
Bluray players will play DVDs and Bluray discs. Bluray gives you High Definition video and typically connects to a HDTV using a HDMI cable.
dvd_howtoconnect.htm
for more information and pictures on DVD player hookups.
on Aug 17, 2010 | Audio Players & Recorders
Can you please tell me how to connect my kef psw
If your amp has a "sub out" jack, that's the best way to hook up this sub. You'll just need a single RCA (also called "phono") cable. Connect it to the Left input on the sub, which should also be marked as "mono"
If your amp just has speaker-level outputs, then connect the left and right main speakers from your amp to the sub's high-level inputs, and then run wires from the sub's high-level outputs to your speakers.
If you're running a surround-sound setup, use the front-left and front-right speakers for this hookup.
If this helps, be sure to hit the "thumbs-up" button for me!
If not, post back with the "Add comment" and I'll do my best to answer any questions you've got.
Jan 23, 2010 | Panasonic Audio Players & Recorders
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
No 5.1 surround when adding a Philips upconvert player to the San
Sounds like you are getting analog signals from your componet cables and a true digital input from your HDMI into your tv.
However that unit is Analog audio input x 1 only.
So i dont think your going to get true digital surround sound.
The problem being
Sanyo =
Inputs: Analog Audio x 1 Outputs: Composite x 1 · S-Video x 1 · Component x 1 · Digital Audio Coaxial x
Feb 03, 2009 | Sanyo DWM-2500 System
Bose Lifestyle 50 - connection to a non-bose amplifier
The 2 system are completely different your is low level input and its is having only 2 input L and R when those signal they get inside your sub it process through an DSP ( Digital Signal Processor ) and become 5 output to yours satellite cube speakers
The AM6 or 10 are high level input connected direct to any output of any AMP from those signal they convert down to low frequency for sub woofer
Nov 26, 2008 | Bose Lifestyle 38 System
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
Connecting my Medion surround sound to my Sony dvd recorder
u need an amplifier (5.1), u put the two outputs in, and then theres loads of outputs coming out of yer amp. hey presto, im doing the same thing at my uni flat, but i need the amp. peace out x
Oct 30, 2007 | RCA RTD155 System
Surround sound help
A few questions... What components are involved? How are they connected? Can you hear sound from the speakers for any other input device i.e. radio, cd, vhs, etc.? I suspect that there is an issue with the way the system is connected. I have the Surround sound output from my DVD player connected to the digital surround sound input on my reciever. I'm using digital coax cable (looks like a "normal" RCA cable), not the optical fiber connection. I had to buy a special cable for the digital surround sound. A normal RCA cable would not work. I don't know why. If you're using a similar connection, that could be your issue. make sure that the output and inputs you're using are compatible. A digital surround sound connection (in or out) can't be connected to an analog connector (in or out). Remember, Digital to Digital with a Digital capable cable; Analog to Analog with an Analog capable cable. If this is not your issue, post back here with more info and we'll see what we can figure out.
Sep 05, 2007 | Zenith XBS344 System
57 people viewed this question
 Grubhead
Grubhead
