Question about Alesis DM6 Electronic Drum Set
Alesis dm6 module not working
The dm6 module is not working even with a new power supply! Occasionally it turns on but then automatically turns off after around 15 seconds! What is causing this and what is the solution?
  • 1138 Answers
SOURCE: i own an Alesis dm6 mod. how to add cymbals.
I think your best solution is this> You can add 10 more triggers with it:http://www.alesis.com/triggerio
Posted on May 18, 2010
  • 5603 Answers
SOURCE: My Alesis D4 Drum Module shows squares in the
Open the unit and see if it has a battery that holds the settings. Check the voltage... it should be around 3 volts. If less than 2.5 volts replace it.
Verify the INTERNAL regulated power supply as the external you verified with new unit. The external is likely regulated within the D4 and either due to an overload or bad regulator may be below the voltage to run the processor. It is likely 5 volts and anything over 4.85 would be acceptable.
Posted on Jul 28, 2010
  • 5603 Answers
SOURCE: have the alesis dm6
Two things:
Check that cables are seated, especially the one at the main module.
Second, look for a setting for "Local Control" in your user's manual; That setting should be "On" to accept the triggers from the pads.
Posted on Jan 12, 2011
  • 5603 Answers
SOURCE: Alesis DM6 electronic drum kit module sound
It appears that you have to select a "Kit" of drums when using the external triggers. It appears that the volume level for the kit and that for each voice MAY all have to be set, especially after new firmware download. Read manual about KIT volume level and selecting voice and volume level for those. Manual is NOT very clear about these things and you have to try them as this is where the probllem is.
Posted on May 08, 2011
  • 5603 Answers
SOURCE: my alesis sr-16 won't power
Likely the input rectifier and filter in the SR16 has shorted diodes or caps. Should be easy fix for a competent electronics tech.
Posted on Jul 07, 2011
How fix the firmware problems with alesis dm6?
Have you updated the firmware recently? If not, do so.
If you are having volume issues, you can adjust them with the following:
Adjusting the volume of individual pads:
-Press Voice.
-Then press Volume.
-Strike the pad you would like to adjust.
-Then use the + and - buttons to adjust the volume of the individual pad.
-To adjust another pad, strike that pad, and repeat step 4 above.
Aug 04, 2014 | Alesis DM6 Electronic Drum Set
I own an alesis dm6 mod. how upgrated firmware?
Click this to unload the latest firmware from the manufacturer!
DM6 Module - Firmware Update [v06]
DM6 Firmware Update Installer for Windows. Updated 04.26.2012
Fix'dYa
Can I use a 12V adapter to power the 9V output for my Alesis DM6?
No, it will work for some time, but will eventually overheat and cause damage. Spend the $10-20 and have piece of mind.
Jul 25, 2014 | Alesis DM6 Electronic Drum Set
Problem with dm6 and hiss problem
The amplifier may be turned up too high!
Jan 12, 2013 | Alesis DM6 USB EXpress Kit Compact...
Alesis DM6 kick/bass has a really low volume-any way to make it louder?
MAKE SURE WHEN YOU ADJUST THE VOLUME YOU PRESS
SAVE , GO BACK IN A CHECK VOLUME LEVEL TO A MAX OF 16
Jan 09, 2013 | Alesis DM6 Electronic Drum Set
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Alesis DM6 electronic drum kit module sound problems: The mix in, display and sensors are working on the module but no drum sound is produced through the monitor or through headphones (but an ipod can be...
May 08, 2011 | Alesis DM6 Electronic Drum Set
Have the alesis dm6 there is no out put sound. monitor appears to be working. hooked to small amp or headphones. just fuzz. please help. little guys christmas present!!!
Two things:
Dec 25, 2010 | Alesis DM6 Electronic Drum Set
I own an Alesis dm6 mod. how to add cymbals.
May 09, 2010 | Alesis Sr 16 Stereo Drum Machine
Alesis DM6 Electronic Drum Set Logo
26 people viewed this question
Top Alesis Music Experts
Michial Gueffroy
Bernie Scott
Level 1 Expert
Robert Graf
Are you an Alesis Music Expert? Answer questions, earn points and help others
