Error ID 678 The remote computer did not respond.to make sure that the server can be reached,ping the remote computer.
3 Suggested Answers
APremkumar
  • 564 Answers
SOURCE: Error [678]
Hi, Step 1: Make sure the network cable is connectedMake sure that the network cable is connected to the computer and to the modem. If your computer connects to a hub or to a router, make sure the cable that connects the hub or the router to the modem is connected. Step 2: Make sure that the network adapter is enabled
  1. Click Start, click Run, type ncpa.cpl, and then click OK.
  2. Right-click the Local Area Connection icon. Click Enable if the option is available.
Step 3: Reset the modem
  1. Disconnect the cable that goes from the computer to the modem.
  2. Turn off the modem. If the modem does not have a power switch, disconnect the power supply from the modem.
  3. Wait two minutes.
  4. Turn on the modem, and then connect the cable that goes from the computer to the modem.
Step 4: Uninstall and then reinstall the modem and the drivers by using Device Manager
Before you follow these steps, you may have to download the latest driver for your network adapter from the hardware manufacturer.
  1. Click Start, click Run, type sysdm.cpl, and then click OK.
  2. Click the Hardware tab, click Device Manager, and then locate Network Adapters.
  3. Expand Network Adapters, and then right-click the icon for your network adapter.
  4. Click Uninstall, and then click OK. In the dialog box that prompts you to remove the files that are associated with this device, click Yes.
  5. Restart the computer. Or, click Action, and then click Scan for hardware changes.
  6. If Windows finds the device but does not recognize it, you must install the latest driver for your network adapter.
If you have a Realtek 8139 network adapter, updating the driver seems to resolve this issue. For more information, visit the following Realtek Web site: http://www.realtek.com.tw/downloads/Microsoft provides third-party contact information to help you find technical support. This contact information may change without notice. Microsoft does not guarantee the accuracy of this third-party contact information. Step 5: Create a new DSL or cable connection
  2. Click Create a new connection under Network Tasks. Click Next when the wizard starts.
  3. Click Connect to the Internet, and then click Next.
  4. Click Set up my connection manually, and then click Next.
  5. Select Connect using a broadband connection that requires a user name and password, and then click Next.
  6. Follow the remaining steps. Use the connection information from your Internet service provider (ISP) to complete the wizard.
Note You may have to use software that is supplied by your ISP to create the new connection.
Posted on Mar 02, 2009
VenkY3K
  • 118 Answers
SOURCE: Error 678
Error 678 is with if you had given wrong username & Password., pl verify correct UN & pswd it must be very case sensitive is there any special character included in the UN & pswd., verify then try again., it will works....
Posted on Mar 30, 2009
How to Make a Ping Utility on Windows NT Systems?
Helps in determining TCP/IP networks IP address as well as determine issues with the network and assists in resolving them. See the ping definition for a full description.
Pings the localhost. which helps determine if the computer can send information out and receive the information back from itself.
Note: The above command does not send information over network, but can indicate if the card can respond .
Ping supports the ability to ping an Internet address. In the above example, we pinged "computerhope.com" and as can be seen, received four responses back. If we couldn't reach the server or the server was blocking our request we would have lost all four packets .
Allows you to ping another computer where <69.72.169.241> can be the IP address of the computer you want to ping. If you do not get a reply or get lost packets you have a problem with your network, which can be a cable issues, network card issues, drivers. router. switch. or other network problem.
Oct 20, 2016 | Computers & Internet
VPN connection error
1) you are dialing the wrong number.
2) make sure you have good connection.
3) If using VPN, make sure the port 1723 and IP Protocol 47 (GRE) are opened.
Apr 04, 2008 | Televison & Video
What is error 678 in zte cdma device?
The error means:
see this answer:
https://uk.answers.yahoo.com/question/index?qid=20070527225936AARDAsv
Jun 11, 2014 | Toshiba Computers & Internet
I have dell studio 15 lap top with windows 7 operating system. yesterday i bought tata photon plus data card. when am try to connect i am getting 678 error: remote computer did not respond. I have...
This error is due to modem not responding problem, or signal strength is low.To cure this error, Follow the below steps :-
Goto start program - control panel - click on phone and modems options - A Window named as Location information opens
Select the country/region are you in now - then specify the area code (or city code) are you in now - then select tone dialing - click on ok button Phone and modem options window will open with the details you have entered in previous window...
Thanks & Regards
Anas K A
May 17, 2011 | Computers & Internet
Cant login to facebook
First, if you're ever unsure if a website is down or it's your computer, you might want to try using http://isitup.org/. Is it up basically allows you to figure out if "facebook.com" works for other people.
If it does, and you still cannot access it, you might want to try pinging facebook to see if their server can connect to your computer. When you ping another computer, you basically say "can you hear me?" and, if the other computer receives the request, it responds "yes I can." To ping facebook, click on start, then run and type "cmd" then hit enter. You should get a DOS prompt (a big black window). At the prompt, type 'ping www.facebook.com' without the single quotes. If your computer can connect to the facebook server, you will see a time response (usually milliseconds). If your computer cannot connect to the facebook server, you will see an error of "request timed out." This means it took too long for facebook to respond to your computer and something is blocking the connection, most likely a firewall.
If your computer responds to the ping request ok, then you most likely need to clear your cookies and cache in your internet browser. Click here to find instructions on how to clear cookies and cache for most major web browsers. http://www.ehow.com/how_6135104_clear-browser_s-cookies.html
If you find this to be helpful, please make sure to rate my response! Thanks !
Mar 22, 2011 | Facebook Social Network
I am not able to connect to a broadband connection via my Dell Latitude D620 laptop. the error that it shows is Error 678 : remote computer didnt respond.
make sure ethernet card is in slot tight screw down go to computer ,system propertys, go to device manager, trouble shoot it.
Feb 17, 2011 | Dell Ethernet Card Network Adapter
Hi am getting error pop server3 not responding
simply you are not connected to the server. check IP address of the server and ping it. go to run type cmd and type ping space server ip and click enter. if you have four replies check your computer settings. if not try to connect to different server if still have same problem configured lan settings of the computer make sure its obtain and dns as well.
Jan 20, 2011 | Computers & Internet
I wasnt able to connect using my modem, then this appears error 679. What does 679 error means?
Error 678 and Error 679 Connection Errors
Error 678 The remote computer did not respond (No dial tone)
Error 679 The Specified destination is not reachable
Both errors are very closely related as they both suffer from the same causes
Causes
ISP (internet service provider) problem.
You have a phone line problem.
Router / Modem is disabled, this can be due to.
The LAN or Phone cable is disconnected.
Your firewall is blocking the connection.
The Winsock file needs to be repaired.
A phone line does not have a line filter installed.
The modem drivers are corrupt.
Spyware.
Your modem is faulty.
Your username, password is wrong.
Incorrect ISP or Router / Modem Configuration
Hope it helps.
Oct 09, 2010 | Computers & Internet
I have two different domains that are connected via VPN connection through two routers. I can ping from domain to domain via IP address on clients and servers. However I can only do a net view command on...
This is an excerpt from a MS Technet page for error 53:
Resolutions: 1) if it is domain environment, check your WINS; 2) if it is peer-to-peer workgroup, enable NetBIOS over TCP/IP; 3) make sure the machine is running; 4) make sure file and Printer Share enabled on remote computer; 5) make sure client for ms networks is enabled on local computer; 6) make sure you type the correct name. 7) Make sure no firewall running or any security setting.
Pay close attention to #s 4 and 5 - I suspect XP pro might not be open enough.
Sep 28, 2009 | D-Link NetDefend DFL-700 Firewall
Error 678: The remote computer did not respond.for further assistance click more info or search help and support center for this error number.
Mar 01, 2009 | Microsoft Windows Vista Ultimate Edition
Computers & Internet Logo
655 people viewed this question
David Payne
David Payne
