Question about Bulova Watch
How do you set and deactivate the alarm function.
Hi, I bought a National Geographic Globetrotter watch at auction with out a manual.I can't figure out how to set and deactivate the alarm function.It's a 5130.D swiss quarts movement,it has three sub dials,the one above the six o'clock positionhas two hands and can be set.The bottom function pusher advances the hands and when you stop it beeps twice in about two seconds if you push it again it beeps once.If you leave the hands of the sub dial at a time and you make it beep once or twice the alarm still won't sound.I know the alarm works because it went off at 9'o'clock but I had both hands at midnight. Please help if you can.THANK YOU! Ryan
    Problem Solver:
  • 3 Answers
GO TO BULAVA look for Chronograph 561/598 will show diagram along with these instructions
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note:
The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
Watch Setting Guide
4/2007
Posted on Feb 13, 2009
  • 2,334 Answers
I did find two authorized dealers:
www.kenmarwatches.com
www.princetownwatches.com
Contact both and request users manual fur your specific model. They must be able to help.
Posted on Jan 05, 2009
Where can I get the instructions to set my National Geographic Dakota atomic watch?
Browse through my tips, please. There are plenty of watch manual links.
Aug 05, 2010 | Dakota 2786-6 Wristwatch
Need instructions for resetting atomic national geographic watch It is a clip on with leather strap
Click on my profile (escapement), then click on Tips and Tricks. There you will find linkS to all watch manuals. Rate me, please.
Mar 26, 2010 | Dakota Watch Company Radio Controlled...
Can't set time on aqualite watch-field ranger
I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
Aqualite has 4 buttons:
1) top right (we will call it S1 like this manual does)
2) bottom right (this will be S2)
3) bottom left (this will be S3)
As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
Setting the minutes, hour, date month and day:
Press S3 3 times, or until the following are flashing in the display : TU and seconds
Set the minute: press S2 once and advance by pressing S1
Set the hour: press S2 and advance by pressing S1
Choose from AM (A), PM (P) or military time (H)
Set the date: Press S2 and advance by pressing S1
Set the month: Press S2 and advance by pressing S1
Set the day Press S2 and advance by pressing S1
Press S3 to bring you to the time display
Setting the chronograph:
The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display.
1. Press S3 (flashing in the display: SU, FR, SA)
2. Press S1 to begin. Press S1 to stop.
3. press S3 to return to the time display.
Setting the lap time:
The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds.
In the time display.
1. Press S3 (flashing in the display: SU, FR. SA)
2. Press S2 to clear setting
3. Press S1 to begin. Press S2 to stop.
4. Press S1 once and S2 twice to reset.
5. Press S3 to return to the time display.
Setting the alarm and snooze:
The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display.
1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1
2. Press S2 once (minute will be flashing)
3. Press S3 to set alarm and return to time display
3. Press S1 to deactivate alarm
5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate.
6. Press S1 and S2 at the same time to deactivate the alarm at any time.
To test alarm
In the time display
1. press S1 and S2 simultaneously for alarm test.
Hourly chime
Your chrono alarm sport watch ha the option of an hourly chime in the time display.
1 Press S2 and then press S3 to activate hourly chime
2. Repeat process to deactivate
Jul 23, 2009 | Watches
How to set time on my National Geographic Dakota Atomic Watch?
For the national geographic radio controled watch.
The easiest way to rest this watch is to remove the battery.
Once replaced the watch will flash set to 12. Push and hold the upper button till the hands spin. Press this button again to stop the hands. Tapping the upper button will make the hands move forword 1 sec. Set all the hands to 12. becareful, if you pass 12 you will have to go around again. to start the hands spinning again press and hold the upper button untill the hands move. Once all the hands are at 12, press the lower button and the screen should flas LON for london. Set the city code using the upper button to your area. press the lower button hard to confirm the information. The watch should set itself to the correct time. If it starts running from 12, place it on the window sill for the night so that it can get a signal.
Mar 08, 2009 | Dakota Watch Company Radio Controlled...
Can't figure out how to deactivate the alarm on Umbro U564B watch
Start with watch in normal clock mode. press and hold bottom right "lap reset" - alarm time appears. Keeping "lap reset" held, I can then toggle the alarm on and off using top right "start/stop".
Qiu: Circle segment lights up (only a black point in the middle, NO ALARM)
Circle segment with a black section on the above middle point, ALARM ON.
Mar 03, 2009 | Bulova Watch
Need instructions to set time on National Geographic watch NG752G
please describe your watch........
jackiaria
Feb 21, 2009 | Bulova Watch
Instr. 4 Nat. Geo. wtch w/ Rhonda 5130.D mvemnt #NG761GSSK
http://www.ronda-startech.com/chrono/main.php?x=functions
Turns out Rhonda has a website with specs. and diagrams for all of their movements
guess I shoulda thought of that first. Anyone needing info for a Rhonda movement check
the above link.......
Feb 02, 2009 | Bulova Watch
Activate T Buton gose to Alarm function.
As with many watch manufacture houses novadays watch technology differs from house to house. Tissot is no difference as T-series watches was developed by Tissot itself.
You have to follow the steps one by one as instructed in your watch manual. Probably you will need reset your watch completely, depending what actions you've allready done.
In case if you lost your watch manual, go to www.tissot.ch and find out everything you need.
Regards
Arthur
Dec 16, 2008 | Tissot T-Touch T33159851 Wrist Watch
Bulova Watch Logo
711 people viewed this question
Top Bulova Watches Experts
Geoff
Ansel Alberto
Ansel Alberto
Are you a Bulova Watch Expert? Answer questions, earn points and help others
