Question about Refrigerators
Logik fridge freezer leaking
Water appearing under unit
22yooper
  • 828 Answers
SOURCE: Water leaking from freezer down back wall inside fridge
Defrost water from a top freezer models exits the cabinet in the rear. This drain line may be plugged.
Posted on May 27, 2008
Bgillespie
  • 89 Answers
SOURCE: water leak from under fridge when water dispenser is used
The water line is broken somewhere from the water dispencer all the way down to the water valve. I usually find that it is broken next to the water valve. Hint: Water valve is blue and located behind the fridge in the compressor department. Water line is 1/4inch clear tube that is probaly now a "yellowish" color. Easy to spot, easy to fix, especially if located next to water valve...
Posted on Dec 02, 2008
  • 583 Answers
SOURCE: leaking freezer
Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction. Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says ?energy saver? or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved. please do not forget to rate the solution.thanks.
Posted on Jun 12, 2009
  • 111 Answers
SOURCE: water pooling on bottom of freezer and leaking into fridgerator
in the back of the fridge you have a hose going to the bottom , take everything from inside of the fresh food compartment and blow in the hose and after voila problem solved
Posted on Jun 18, 2009
SOURCE: leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Posted on Jul 03, 2009
The freezer compartment of my F & P Model E522B Fridge/freezer leaks water but the seal appears OK. Why?
draining tube plugged which normally would drain defrost water to a evaporating pan under fridge
Jan 18, 2016 | Fisher and Paykel Active Smart E522B...
We keep getting lots of ice accumulating at the bottom of our freezer. Any ideas?
Probably a plugged drain line or plugged drain pan opening. This drain pan is located under the cooling coil (evaporator). When the unit defrost itself, the water is carried away via this pan and drain line.
Mar 02, 2015 | Logik LFC55W13 White 200 l Fridge Freezer...
Kenmore bottom freezer only 2 days old is leaking water into the fridge it appears to be coming from a small vent on the ceiling of the unit
You need to call sears as the fridge is still under warranty and if you touch it you will void the warranty.
Oct 14, 2014 | Refrigerators
Hear liquid leaking in freezer
NO LEAKS showing water outside of unit ?? When a refrigerator goes into auto-defrost the unit shuts down the air-flow and coolant systems..in turn it turns on a heating element located in the freezer where the coils are..the heater melts frost build-up and the water drips onto the heater causing a slight popping or sizzling sound..MAYBE ?
Jan 04, 2018 | Kenmore Refrigerators
Kfcs22evms ice under freezer door and water leaks out onto floor
Check for a clogged drain line at he bottom rear.
Oct 30, 2017 | Refrigerators
Kitchen Aid KTRC22EK leak inside refridgerator
It sounds like the drain for the defrost water is pluged. You can remove the back panel inside the freezer(ice maker will have to coe out first) and access the drain in the rear center of the freezer. Check the drain. It can be defrsted with a hair dryer(shut off the referigerator first) good luck, snugglepants
Nov 03, 2009 | KitchenAid KTRS22EL Top Freezer...
Every day, some water appears on the kitchen floor. It appears to be leaking from somewhere in the freezer side of our side by side frig and freezer. Latter has automatic icemaker and water server in...
Your evaporator drain pan under the fridge may be misplaced. If so, simply pull out the unit and place the pan back where it goes under your box. Hope this helps!
Aug 16, 2009 | Refrigerators
Zanussi frost free fridge freezer leaking
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help. Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Jul 01, 2009 | Refrigerators
Freezer works, fridge not cooling but water was leaking from under fridge a few weeks ago, could not find source . Small compact frigidaire unit for dorm room.
Most if not all fridges under $2000 only use a single compressor meaning the refrigeration is provided by venting the freezer air into the compartment. Water under the unit likely indicates the fridge is not properly sealing and moisture is condensing on the cold coils and dripping.
Jun 24, 2009 | Refrigerators
Water leaks inside fridge from top freezer
check your gasket on the refridge door see if it has any rips or you have a blocked drain in freezer
May 02, 2009 | Refrigerators
Refrigerators Logo
248 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
