Question about LG Refrigerators
Fan is making a noise in my lg refrigerator
The noise is like a humming noise. does the fan motor need replacing
  • 833 Answers
SOURCE: LG refrigerator makes loud noise and then stops running.
You are seriously frozen up. Defrost the unit completely. Then, be aware that 'window shopping', leaving uncovered liquids in the box and poor door sealing (too heavy a load on the door ... too much on shelves) can cause condensation. Defrost with hot air or leave unplugged and open for about 2 days. You'll see alot of water come out.
Posted on Jan 10, 2008
jmeredith
  • 417 Answers
SOURCE: Evaporator Motor & Fan
hi,
you can try to completely defrost the fridge by unplugging it for a day and put you groceries in another fridge, sometime ice dams build up in those and freeze next to the fan blades and cause alot of noise, if its squealing, then its the motor for sure, evaporator motors are usually pretty easy to replace once you study where its at, usually the whole top or bottom and back of freezer has to come out then the motor and fan are right there, keep the fan blade assembly because you put that on the new motor, be extremely careful once you have the bottom and sides out because the coils will be vulnerable to anything if you hit them go to www.sears.com and go to parts area, theres a sears repair store in our town , hopefully in yours or just call around, dont forget to unplug it! hope that helps
J
Posted on Jul 10, 2008
SOURCE: whirpool Refrigerator Making Loud Noise
pull fridge out and listen if noise is comming from compressor or not. If not, then your evaporator fan is comming into contact with the ice from the evap.coil. Basically give unit a good overnight defrost with doors open as the insulation on this fridge is good
Posted on Aug 18, 2008
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
  • 219 Answers
SOURCE: Freezer Fan making humming noise until Turbo Cool is pushed - GE
yes need to replace
Posted on Mar 19, 2009
My GE side by side is making a terrible humming noise similar to some of the other posts I have seen. Are the fan motors easy to replace?
The fan motors are usually pretty eay to change. Need to know model number and which fan to help you change it. Please comment me back so I can assist further.
Jul 28, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer fan makes loud humming sound
sounds like the bearing in the fan motor is gone. need to replace it.. ok
Feb 12, 2011 | Hotpoint HSS25GFP Side by Side...
My LG refrigerator model # LFX25960ST/bottom freezer, is making a humming noise that stops when we open the door. What is it?
my refrigerator before making a loud noise when we open the door. i called mr.apliance he replace the evaporator fan.......
Sep 25, 2010 | LG Refrigerators
38CKC036 Air Conditioner: outside fan will not come on makes a humming noise...
If the humming is your compressor running (feel the large copper line going into the unit, it should feel cold aftter a few minutes of run time) then the fan motor or the capacitor or both need to be replaced, check for voltage to the fan motor when the unit is "humming" if it has voltage and will not start replace the fan motor and the capacitor. hope this helps.
May 18, 2010 | Carrier 38CKC036 Air Conditioner
Both fridge / freezer are not cooling down. It sounds like the motors are not working.But there is power going in. Also there is a small humming engine noise.
Are you sure the humming noise is from the compressor motor being locked up? It is normal for the compressor motor to make a humming noise when it runs. Make sure the fan in the freezer is also running while the compressor motor is running and replace it if necessary.
You need to defrost the coils in the back of your freezer. You can do this the slow, easy way by simply unplugging the refrigerator for 24 hours. Leave the doors open to ensure everything has the chance to melt.
The fast way to defrost the coils is to turn off the refrigerator and remove the rear panel from the freezer compartment. You will see the evaporator coil completely frozen with ice. Thaw the ice with a hair dryer and make sure you thaw the drain at the bottom of the back wall as well.
When you turn replace the freezer panel and turn the refrigerator back on, it will get cold again.
Mar 06, 2010 | Electrolux Refrigerators
Lg refrigerator LFC22740ST loud humming noise no
You have a bad fan motor ... replace motor.
Nov 11, 2009 | LG Refrigerators
Fan motor making noise
HI thanks for your question. the fan is located behind the freezer wall. 4or5 screws. remove panel. replace fan motor. thanks the appliance doc. please rate my answer. thanks
Oct 09, 2008 | Refrigerators
I own an LG up right refrigerator with the freezer on the bottom. The unit is about three years old and we have been very happy with the frig. Lately the unit has been making a loud fan winding noise....
  • i would just replace the fan motor $40
  • they have bushings in them that sometimes make noise when the motor shaft moves to a certain position. when you open the door it disrupts the airflow of the refrigerator and the motor shaft will go to a different position causing the noise to stop.
Jul 10, 2008 | LG Refrigerators
Refrigerators Logo
318 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
