Question about Whirlpool Washing Machines
Have a Whirlpool 600 AWM 6600 and lost the use manual - don't know which cycle to choose for my washing
  • 87 Answers
SOURCE: Whirlpool AWM 8023 -error F06
This erroe code means drive motor tackometer error Probably a bad motor or motor drive pc board or cable problems
Posted on Jun 08, 2007
kakee
  • 1269 Answers
SOURCE: Whirlpool AWM 6145/3 gets stuck
That's a timer problem. Check on the user's manual on how to reset the timer settings. The timer can be replace if found defective but you need a pro technician to do it.
Posted on Aug 29, 2008
  • 3 Answers
SOURCE: I have a whirlpool front
Probably needs a new "mother board." I've had to replace mine 3 times. It's expensive too.
Posted on Dec 28, 2008
richardsimpl
  • 230 Answers
SOURCE: Getting faulf code F06 on Whirlpool 6th Sense AWM 8143
Hi There
I have found what you looking for and i hope this help's yo. let me know.
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Thank you for writing to fix ya.
Best regards Richard
Posted on Dec 12, 2009
Hit it again
  • 13 Answers
SOURCE: Whirlpool AWM 6100/s - stopping
Yeah. This is a pump problem. Our machine first did this about 3 months ago. I took the filter plug out and removed about 10 coins from around the pump impeller area! I removed the pump and dismantled it. Unfortunately water was getting in past the seal on the pump spindle. I cleaned it all out and reassembled it. Worked fine till a couple of weeks ago. It has worn out the spindle "bearings" and because of the loose play it gets stuck, intermittently. If you are by the machine when the drain cycle starts , you can give the filter housing a few bangs(take off the circular cover) . The pump will start up .It makes a grumbly sound, as it is knackered. But once started will generally keep going.The answer however is a new pump. And probably a pact with everyone in your household to be more careful not to leave stuff in the clothes you put in the machine. Our washer has got through 2 mobile phones. a packet of bradding nails, a lot of cash, both coins and notes.Various other stuff that i wont mention! The pump gets very hot when it is trying to turn but cant because of debris on the impeller. This will lead to the pump failing after a time.
Posted on Jan 27, 2010
I require an operation manual for a Whirlpool AWM302
The Whirlpool UK site has support for the AWM 302. The direct link to the manual is http://docs.whirlpool.eu/_doc/501910006566GB.pdf . If this isn't your model, start at http://www.whirlpool.co.uk/support/instructions-for-use/instructions-for-use.content.html and click on Search. Then search using the Commercial code box. (There are also washers with the commercial code AWM 302/3 and AWM 302/4.)
I hope this helps.
Jun 03, 2012 | Whirlpool Washing Machines
I need a short program for washing and i lost the manual. i don t know how to program it
I have an AWM 5100 and the programs are printed on the outside of the detergent drawer, 1,2,3 prewash cotton, synthetic, delicates, 4 full wash,5 short wash cotton etc..this is not on your machine? Check the Whirlpool site, if no luck, reply here and I will see if I can help more..perhaps I can scan and email to you? but might not be same control options.. my machine also has a rapid wash button, which speeds any cycle.
Good luck
Jun 21, 2010 | Whirlpool AWM5125/1 Front Load Washer
Help! im looking for a manual for a whirlpool awm 293-600 and also maybe a close up picture of the cycle dial as some of the settings have rubbed off?
I am not sure about the awm 293-600 number, but under the ghw 9150p (under your picture) I found one here..
There is a nice picture of the dial settings too.. I hope this helps you. Let me know...
Sep 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool AWM312/3 Front Loader Washing Machine - not spinning
I would recommend getting the service manual for your model as some models have clutches that control spin and others have belts. The service manual would be the best route if you are planning on repairing this yourself. If you would like the service manual let me know and I will post a link to where you can get one emailed to you.
Mar 27, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer will not complete a cycle
hi,
i have a whirlpool 6th sense washing machine, it has come up with clean pump, does anyone know where the pump is on the machine, as i have lost my instruction manual.
regards
jackie
Nov 08, 2006 | Whirlpool AWM8143 Front Load Washer
Washing Machines Logo
47 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
