Question about Kenmore 35912 / 35913 Progressive Upright Vacuum
Kenmore 35923 beltless brush not working after rolling up shlace.
Kenmore Progressive with beltless drive, Handi-Mate Jr, model: 116 35923500. The lace was on a shoe so it stopped the brush. I have pressed the reset, and taken the brush out and used a volt/ohm meter to see continuity through the reset switch and brush motor terminals. The brush make a "jump" as a disconnected lead was reconnected to it's terminal on the brush motor (this was done when the power cord was unplugged). Made me think the component mounted in the brush motor rubber end casing could be a capacitor. I'm not sure what that component is or if it is working properly. With everything reassembled, the vac motor runs, the brush can be turned by hand, but it is not being turned by it's motor. Please, what is the fix for the brush?
  • Jo W Jan 10, 2009
    The air flow filter had nothing to do with the brush not turning, There was no "clog", just a shoe lace on a shoe that had stopped the brush when it wrapped around it. I blow off my ten bucks because the li'l woman just showed me that the brush does not turn when the vac is in a upright position, but does when the handle is lowered for use. Machine83 keep this in mind in case you should come across another idiot who thinks he can figure out a machine or his wife.
  • Ross Mar 26, 2012
    Just worked for me!! Thanks!!
    Sergeant:
    Novelist:
  • 326 Answers
Its due to the grip of the brush and the motor not getting fit its became little bit like streched so this happens and in this case replacing the brushes and checking any other component broken near to it is necessary.
Posted on Jan 05, 2009
    Sergeant:
  • 378 Answers
 take out the air flow filter at the back of the vacuum and turned it on, somehow the clog cleared will get cleared . Then  put the filter back in and it will work  perfectly.
    Brigadier General:
  • 5,158 Answers
On the side of the brush itself should be a rubber belt to drive the brush itself.. it is broken
Robert
  • Roberta Smith
    Roberta Smith Jan 05, 2009
    I stand corrected..there is no actual belt... is there any resistance to turning the brush by hand when the vacuum is off ?
    Robert
Why did the brush roller stop spinning?
With the cleaner unplugged, turn the unit over and look inside the opening where the brush is located. Do you see the clogging of the brush with lots of hair? If so, you will need to disassemble it to remove the hair. In any case, you will probably need to take off the cover to see if there is an obstruction jamming the brush. Also, check to make sure that motor for the brush is getting power. If there is an electrical cable on the outside connecting the brush housing to the rest of the vacuum cleaner, check if it is disconnected. When you have the cleaner on, do the lights glow? Do you hear the motor running? Try the above and report back.
Jul 21, 2015 | Kenmore 31913 Progressive Direct Drive...
BELTLESS BRUSH WILL NOT REVOLVE
I bought my parents the exact same model. Do you have the floor select switch "ON" for the brush? Did the overload protector switch trip? There is a little red button sticking out from the right hand side of the head. Check to see if it is pertruding past the cover. If so, push button in and it should reset.
Feb 05, 2010 | Kenmore 31912 Progressive Direct Drive...
Belt is broken
there is no belt on your model there is a reset button on the side by the brush
Dec 13, 2009 | Kenmore 31913 Progressive Direct Drive...
Kenmore vacuum model 25614 power mate will not reset
What you see from the outside is usually a pop up button which sits on top of the actual internal switch remove the lid of the power mate as though you are cleaning the brush roll or changing the belt. Then test the reset internally. Post back to advise .
Sep 19, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
Kenmore Beltless Vacuum brush will not spin. Everything else works.
there is a reset button on the side of the lower base of the machine, plug in the unit turn on the switch to the brush and vacuum are both engaged hit the reset button, remember the roller will not engage when the handle is in the upright position, release the handle and your ready to go.let me know if that helped you . thanks renevacdoc
Jul 23, 2009 | Vacuums
I have a kenmore progressive direct drive handi mate jr. upright vacuum. My daughter used it last night to vacuum up some cat litter that had spilled on the floor. I went to use it today and it turned on...
its probably clogged up with cat litter.might have gotten into the motor.your motor has a motor guard inside if it. when it overheats it will shut down till it cools off.you need to clean all th cat liter out of it.and clean the filters.with a direct drive you might want to take it in to a repairman to sevice. its not a shop vac i advise you not to pick up things like cat liter
Apr 28, 2009 | Kenmore Vacuums
My handi-mate Jr. is not spinning anymore. What should I do to fix it?
Assuming you don't have a broken belt, you can pretty much completely disassemble the Handimate and clean it out, which should fix "it won't spin any more." Part of the cleaning procedure is pretty obvious - there are tabs on the side that hold the top onto the bottom. Just lift the side flaps on the top section that surround the tabs to release the top section. Pay attention to how the thing is put together so you can reassemble it - there aren't many parts - it's not rocket science. Now the part that's not obvious: it's not too hard to pull the axle out of the cylinder to which the brushes are attached. Gunk, hair and fibers can get caught under the white end caps and around the axle.
Apr 09, 2009 | Kenmore Progressive Bagless Upright with...
Handi-mate jr. manual
I scanned my manual, but I can't fund any way to attach it here. I can send it to you if you provide your email address.
Mar 19, 2009 | Vacuums
Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
397 people viewed this question
Top Kenmore Vacuums Experts
Roger Potts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
