Question about Logitech Harmony 520 LCD Remote Control
Initial Setup Stalls at 0%
When trying to setup the remote for the 1st time, the program stalls at 0%. LCD on remote indicates USB connected while the Logitech Harmony Remote Software window indicates 0%. Nothing is displayed when clicking the show details button.
I'm using software version 7.5.0 on Mac OS X 10.5.6
    Problem Solver:
  • 12 Answers
Reinstall your software and connect in the back of the computer to a usb port directly connected to the motherboard
Posted on Apr 15, 2009
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
Program a sharp remote to a orion tv
Setup codes for Orion Brand TVs are: 0121 0135 0035
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
IDENTIFYING CODES FOUND USING THE SEARCH PROCEDURE
  1. Press and hold the SETUP until the LED indicator lights steadily. Release Setup button.
  2. Press the mode button that matches the equipment you want to identify. The LED blinks once.
  3. Press and release SETUP. The LED blinks once.
  4. To find the first digit, press each number button from 0 to 9 until the LED blinks. The number you pressed is the first digit of the code.
  5. Press each number button from 0 to 9 again as above to find the second digit.
  6. Press each number button from 0 to 9 again as above to find the third digit.
  7. Press each number button in turn to find the fourth digit. When the fourth digit has been found, the LED goes out.
Jul 28, 2012 | Sharp GA219SA Remote Control
I need to program an emerson tv/dvd with a vibe 4-in-1 VA-405 remote
Setup code for Emerson TV/DVD combo is: 0456
Direct Code Entry
Jul 04, 2012 | Televison & Video
Trying to set vr1 vizio remote to vizio flatscreen
General setup proceedings to do with a universal remote control to tVs are.
Direct Code Entry [If the code to TV with remote control is known]
Code Search [If codes are not available]
General setup code for Vizio brand TVs are:[ 0081]
Jul 03, 2012 | Vizio VR1 Remote Control
25gt536
Here comes all the programming details to a universal remote control.
Direct Code Entry
Code Search
Jun 28, 2012 | GE Televison & Video
Hello..m fadhir i just bought samsung lcd tv 32" yesterday.. during initial setup/ plug & play, i suddently choose wrong language (taiwand/tahi) at the 1st step, then i cant understand anything...
hello,
To enter initial setup you can refer setup simbol with gear pict. On top menu of setup (gear) press enter again. Follow the instructions. Or you can read my post here. That the same way but for deferent problem. Good luck.
Mar 30, 2011 | Samsung LN-R408D 40 in. LCD HDTV
How can I change my Sony RDR-VX530 to a multi region DVD planer?
Follow the below instructions closely;
1. In order for this hack to work, you will have to send an infra-red code to your player with a OneForAll remote such as the OneForAll 6 (or URC7560) or OneForAll 4 (or URC7740) or OneForAll 4 Digital, or One For All 5 Digital (or URC 7555) with the following instructions:
* Press the DVD button
* Hold down the Magic button until the unit performs a double LED flash
* Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option
3. On your DVD recorder, using the official Sony remote, select the Setup option
4. On your DVD recorder, using the official Sony remote, select the Options option
5. On your DVD recorder, using the official Sony remote, select the Command-Mode option
6. On your DVD recorder, using the official Sony remote, select the DVD1 option
7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover
8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player
9. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
* Press the Magic button once
* Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
* Press the 1 button once, a double LED flash should occur
10. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
* Press the 2 button once, a double LED flash should occur
11. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
* Press the 3 button once, a double LED flash should occur
12. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
* Press the 4 button once, a double LED flash should occur
13. Program your OneForAll remote with the following instructions:
* Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
* Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode
15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
16. Your DVD player should show the words TIMER OK
17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time
18. Your DVD player should return itself to Standby mode
19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Good luck.
Jan 14, 2011 | Sony RDR-VX530 DVD Recorder/VCR
Need a code to set remote with apex tv
APEX ..........0214 0216 0215 1132 0401 for the remote that uses a 4 digit code. Check if the TV turns on and off and the remote controls other functions.
Alternatively, you can try searching through all the codes in the remote. Turn on the TV manually. press and hold Setup until the indicator comes on. Then release the Setup button. Press and quickly release the TV button. Press the On-Off button until the TV turns off. This could take 300 presses. Press Enter and check if the remote controls any function other than On/Off. If it doesn't repeat the above steps.
You can record this code. Press and hold Setup unitl the light comes on. Then press and release the TV button followed by pressing and releasing the Setup button. Type the digits 0-9 until the indicator light blinks. Repeat typing 0-9 for the other three digits in the code.
Manuals and code list are available here: http://www.jascoproducts.com/support/universal-remote-codes.asp .
Please note that if the remote was programmed less than 6 months after the TV was released or is older than the remote, the code you need may not be in the remote's programming.
I hope this helps.
Oct 03, 2010 | GE JASRM24912 Remote Control
I need the remote code for the Vizio HD VX32L so that it works with my AT&T Uverse remote control. Everything works but the "mute".
VIZIO HDTV 1004
  1. Power on the device the Member wants to program.
  2. Locate the four digit setup code for the device the Member wants to program from the Manufacturer Code List section.
  3. Press and hold the appropriate Mode key (TV, DVD or AUX) on the remote control.
  4. Without releasing the chosen Mode key, press and hold the OK key simultaneously.
  5. Release both the Mode key and the OK key at the same time.
    All the Mode keys should flash twice.
  6. Enter the four digit setup code by pressing the number keys (0-9) on the remote control.
    • The Mode key will flash three times indicating correct entry and return to normal operation.
    • When an invalid code is entered, the selected Mode key will give a long flash to indicate that the Member has not entered the setup code correctly. Start over beginning at step 3.
    • Should the remote control time out before the Member completes the code setup, they will need to start over.
  7. Point the remote control at the programmed device and press the Power key once.
    • The device should turn off.
    • If it does not turn off, repeat steps 2 through 6 trying each code for the brand until the correct code is found.
  8. Repeat steps 1 through 7 to program other devices if needed.
  9. Press the appropriate Mode key on the remote control to work with the selected device. To use the remote control for the Member's U-verse TV Receiver again, have them press the AT&T Mode key.
Jun 28, 2009 | Olevia LT32HVM 32 in. LCD Television
Is it multiregional
Sony are probably the most protective manufacturer of this kind of information. All manufacturers carrying a DVD logo are obliged to say "no" but will normally intentionally leak this to boost sales, particularly in non-US areas.
But try this:
  • Press the DVD button
  • Hold down the Magic button until the unit performs a double LED flash
  • Configure your remote using the setup code 0 5 3 3
2. On your DVD recorder, using the official Sony remote, select the System-Menu option 3. On your DVD recorder, using the official Sony remote, select the Setup option 4. On your DVD recorder, using the official Sony remote, select the Options option 5. On your DVD recorder, using the official Sony remote, select the Command-Mode option 6. On your DVD recorder, using the official Sony remote, select the DVD1 option 7. On the official Sony remote, set the DVD1 option for the Command-Mode switch, under the sliding cover 8. Verify that both the official Sony remote control and your OneForAll remote control can power off and on your DVD player 9. Program your OneForAll remote with the following instructions:
  • Configure your remote using the setup code 9 9 4 or 0 0 9 9 4 if your remote only accepts 5 digit codes
  • Press the Magic button once
  • Configure your remote using the setup code 1 8 9 or 0 0 1 8 9 if your remote only accepts 5 digit codes
  • Press the 1 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 5 5 or 0 0 2 5 5 if your remote only accepts 5 digit codes
  • Press the 2 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 9 5 or 0 0 0 9 5 if your remote only accepts 5 digit codes
  • Press the 3 button once, a double LED flash should occur
  • Configure your remote using the setup code 2 2 1 or 0 0 2 2 1 if your remote only accepts 5 digit codes
  • Press the 4 button once, a double LED flash should occur
  • Configure your remote using the setup code 0 7 9 or 0 0 0 7 9 if your remote only accepts 5 digit codes
  • Press the 5 button once, a double LED flash should occur
14. Place your DVD player into Standby mode 15. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 16. Your DVD player should show the words TIMER OK 17. Press the buttons 1, 2, 3, 4 and 5 on your OneForAll remote control, in order, one at a time 18. Your DVD player should return itself to Standby mode 19. Remove the batteries for significant period of time to wipe the programmed codes on your OneForAll remote
Nov 27, 2007 | Sony DAV-S500 System
Logitech Harmony 520 LCD Remote Control Logo
271 people viewed this question
Top Logitech Televison & Video Experts
Greg Ulan
Jerry Umali
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
