I got a LG hb806 home theatre system every time I put my disc in the tray to watch a movie it just makes these weird noises than ejects by itself
donomite
  • 3 Answers
SOURCE: Not reading disc
the problem is not bad hard drive, the magnet inside spindle came out it it is not able to grasp disk right. had the same problem christmas day took it apart and glued the magnet back in place now it works fine. same problems brrrrrr sound then disk keeps ejecting and will not read disk cheack it out go to llama website http://www.llamma.com/xbox360/repair/Xbox-360-Disassembly.htm good luck
Posted on Dec 27, 2007
SOURCE: Unlock LG home theatre model LH-SW5100
at "no disc", press "pause" and enter "314159". when it shows CODE__, enter "0" for all code, press "pause" and the power button.
Posted on May 19, 2008
SOURCE: Stops Playing: screen freezes
My friend suggested I clean the dvd optical reader lens inside the player with a fine brush (like a camera brush with a blower bulb). This seemed to help immensely. I'm not certain if this is just a temporary fix, but it seems to be ok so far.
Posted on Jun 23, 2008
SOURCE: DVD load / eject problem
This is a solution to all those who have either a DVD which does not load and which cannot be ejected and also to those who have the system stuck in MP3 mode. The solution is the same for both problems. Unfortunately due to the design of the HTS6510 it’s not a simple job but if you are methodical and take your time then most people should be able to do it.
 I personally think the problem stems from dust building up on the laser. I noticed that the extraction fan at the back of the unit draws air, partly, in from the front slot and over the DVD and (Sony) laser.
Anyway I’ll talk you through what I did but please be aware that this is not a screw by screw, connector by connector account.
You’ll need a small torx screwdriver (the unit is put together almost exclusively with a single torx screw size),  a very small Phillips screwdriver and a pair of snipe nosed pliers. Also a couple of small bowls to hold the screws in will be a good idea.
Firstly make sure the unit is disconnected from the mains. Then begin by undoing  the four torx screws at the back of the unit which are holding the cover on. Then remove the silver plastic side sections by sliding them towards the back of the unit. Under these you’ll see two more torx screws to be removed on each side. Remove these and you can then remove the top cover.
Have a look at the first attached picture. You should see the same thing with the lid off the box. I’ve labelled all of the assemblies up. There are four circuit boards which are arranged two on the top and two underneath these. You will be removing the top two (Audio amplifier board and the power supply board).
The aim of the game is to move the front section (the bit with all the control buttons on) away from the main section so that you can get access the to the DVD housing (this is the player unit where your DVD is housed). The front section is attached to the main section by four plastic clips (the plastic barb to metal slot type). Two are accessed from the base of the unit and more on each side. Don’t unclip these yet because the circuit boards are attached by ribbon cables which attach to the front of the unit . It is these ribbon cables which must be disconnected before the front can be unclipped and access can be got to the DVD unit. There are also a couple of bonding leads which attach the front of the unit to the ain chassis. These have small spade (push on) connectors and are very simple to remove.
You don’t need to disconnect all of the ribbon cables – just enough for you to be able to swing the front of the player out of the way.  Make sure you mark any connectors which you disconnect in some way so you remember where they connect to when you re-assemble the unit. I used a permanent marker to put a series of dots on the ribbon end of the connector and board end of the connector. (i.e. one dot on each denotes a pair, the next pair has two dots etc etc.)
Some of the leads which you will need to disconnect are attached to the two processor  boards which sit below the two uppermost circuit boards. Gain access to these by removing the four screws (one on each corner) holding the power supply board onto its mounting (there is also a nylon support in the middle of the board – squeeze it with a small pair of pliers to release the board).
Next remove the black plastic insulator sheet below the board. With this board removed, the metal shelf which the Audio amplifier board is attached to can now be removed. Note that some of the screws on the external back of the unit will also need to be removed before you can do this. You don’t need to take the audio amplifier board off the shelf – just remove the shelf and audio  amplifier board together.
You should now have an assembly which looks like my second picture. As with the top two boards unplug the connectors on the boards to allow the front section of the dvd player to be moved away from the main part of the system. Again don’t forget to mark the connectors so you know how to re-connect them.
If you have got this far you are doing very well!  I then undid the four screws holding the dvd housing and unshipped the entire housing, but with hindsight this wasn’t necessary. There are four Phillips screws holding the top cover of the DVD housing on. Remove these with your Phillips screwdriver and lift off the lid.
You can now remove the DVD / CD. At the same time carefully remove any dust which has accumulated in the DVD housing. Take care not to damage the delicate lens or its assembly. I used a dry cotton bud but a blast of dry air or a lens cleaning brush would be an even better choice.
Once the dust is removed refit the cover the DVD housing and assembly is basically a reversal of the dismantling. Once its all back together switch on and they system will be back to normal. If it doesn’t switch on – open it up and recheck your connectors – most likely one of them isn’t properly engaged.
Posted on Nov 02, 2008
SOURCE: My LG blue ray player is locked in region one.
have you tried resetting the unit
hold the power button for at least 5 seconds, this will force the unit to turn off.
turn it back on
unplug the power cord
wait at least 5 seconds
plu it back in
Posted on Jan 20, 2010
My Sony Home thatre system DAV-DZ10 give a message : No Disk. How to solve that problem? Any help?
All DVD players will say no disc if there is no disc in the drive when closed. If however it does so when there is a disc in the drive, plus the disc is clean and undamaged, then you have a problem. It could be caused by dirt on the lens, but since it was doing funny things before there might be an electronics issue. I would still clean the lens first.
Jul 05, 2015 | Sony Dav-dz100 Home Theatre System
Problems streaming Netflix continuously from home theatre system
The problem can be the memory inside the player, but is more likely the internet download speed you've chosen for your service. It should be at least a 20 gig download speed. You'll also want to make sure your router/wi-fi hub is capable of the higher download speeds as well. I had 7 gig download initially and had the same problem. By upgrading the router and the download speed with my internet provider, it immediately fixed the problem. Try watching Netflix on your computer, and my guess is you'll have the same problem with buffering Netflix streaming on it as well. That will let you know it's the internet speed, not your blu-ray player.
Dec 03, 2013 | LG Audio Players & Recorders
Reset LG HB806 home theatre
You have to enter its service mode option, to do a factory reset. There are two methods to reset. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the device from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 16, 2012 | LG Bluray Home Theater with 3D Playback...
Panasonic DVD Home Theatre not reading
Make sure the tray is clean - no debris on tray If the disc is misaligned slightly it will spit it out
Make sure you are not putting them in upside down
and lastly find a new disk (not home made one) and see if this one works
Disks get damaged much easier than people realize\
If nothing works you have no choice but use a proffessional
Feb 06, 2012 | Audio Players & Recorders
I have an LG Home Theater Model HB806. It will play only DVDs for Region 4 (Australia and Pacific). Do you know the code sequence to unlock that restriction and play all Regions?
Your home theatre, because it's a BR player, has been made specifically for that region - the region for both the DVD and the BR is hard coded in the processor chip. Because of that there is no other region to switch to so you would need to replace the processor to change the region without making it region free.
Sorry, there is no way of making it region free.
Jun 07, 2011 | LG Televison & Video
DVD's won't play
I have a somewhat similar problem, but wasn't after a cleaning disk use. Most of the time when I try to use this system now, after I put a DVD in, I start getting a loud buzzing noise (almost as if gears are meshing)
Nov 17, 2008 | LGDVT418 System
Jun 06, 2008 | LG DP781 Portable DVD Player
Not closing
Hello, with mechanical problems with sophisticated systems of gears etc, the only way thate one can fix it is if you send me a digital picture yourself. To access the inside of the DVD player, you will have to get a handyman to open the DVD player up with a screwdriver, by undoing some screws which hold the cover to the player itself. Then, with the player's circuit boards (The Green/brown Boards with weird components on it) showing, take around 5-6 photo's of the loading tray and the playing tray.(Where the disc is when watching a movie)In the time being, open the layer's cover as instructed before, and look at the inside of the tray for any broken plastic, debris or anything stopping the tray from opening. Good luck!
Oct 05, 2007 | Sony DVP-NS305 DVD Player
DVD movie won't eject
unplug for 5 minutes then plug back in and try again. should reset itself and work.
Sep 10, 2007 | Philips DVP642 DVD Player
Showing "Disc Error" While playing DVD's
the disc tray is not leveled properly, i had the same problem too and samsung repair centre just adjusted the tray.
Apr 29, 2007 | Samsung HT-DS100 System
80 people viewed this question
 Grubhead
Grubhead
