Question about Toshiba Satellite Pro A210-EZ2202X Notebook
Toshiba Satellite a210 keeps freezing up.
I have tried upgrading to 2G of memory, but it hasn't helped.l I have also tried the high performance power option, and running programs as Windows 2000. Still, things will work ok at first, and then it freezes up. any suggestions? It even happens during solitaire games, so it's not any particular program. Our computer also freezes for no apparent reason. To get it to work again we have to unplug the power cord and remove the battery for a few minutes. Once reconnected it works again. I am looking for a more long term solution as today the computer froze 3 times.
  • Anonymous Feb 10, 2009
    I have the same problem, the only way I can do anything without it freezing up the whole time is by running it in power saver mode, which is very slow (of course). I don't think it has anything to do with overheating, I have a laptop cooler on and it still freezes up. I used to get a blue screen but usually the computer shut down before I could read what it said.
    Sergeant:
  • 366 Answers
Check temp of your CPU and fan operation
Posted on Jan 05, 2009
Iv got a toshiba satellite A300 and i was wondering how can i speed my my graphics card ( in any way ) whenever i try to install games and play they there is always a fault of some sort one fault that...
When you will increase the ram your laptop will be fast soon.
You can increase 4 GB maximum.
For dissemble follow bellow the link
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-A355-A355D/laptop-disassembly-1.htm
Maximize your Toshiba Satellite A300-ST6511 mobile computing power and add more memory. Trust PRO Memory Upgrade to provide dependable expansion options for your laptop or notebook with a Toshiba Satellite Small Outline DIMM RAM upgrade.
  • Your Toshiba Satellite maximum RAM capacity: 4GB
  • The Satellite A300-ST6511 has 2 memory slots or sockets
  • This Satellite module upgrade PIN count is: 200-PIN
  • The memory speed is: DDR2 800MHz, PC2-6400
  • The DIMM type for your Satellite A300-ST6511 is: SODIMM, SO-DIMM, Small Outline DIMM
  • For4 diassamble the
Hope it help you.
Jan 08, 2011 | Toshiba Satellite A300-ST6511 Notebook
D Drive not opening light on can't find in computer
Have you tried taking the drive out looking at the model number on the label and contacting Toshiba support for a firmware upgrade for that model as well as an upgraded driver. Sometimes just taking the drive out and re-seating it helps.
Aug 26, 2009 | Toshiba Satellite Pro A210-EZ2203X...
My display screen keeps going upside down
in the VGA options make rotations to normal
i hoe it will work
mvmanish
Jun 14, 2009 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba P200-199 Laptop Model PSPBOE-03P00LZA This laptop has 2gig of ram/memory, i would like to upgrade this to 3 or 4 gig as i require the performance due to the use of high performance graphic...
DDR2 RAM (667 MHz) you can try 2gig sticks and they should work specially if you arerunning newr operating system.
if helpful please rate this fixya.
Thanks
May 05, 2009 | Toshiba Satellite A135-S4527 Notebook
Toshiba satellite a205 s5825 memory upgrade
what my audio setting suppose to set to step by step on my Toshiba satellite A205-S5880
Jan 29, 2009 | Toshiba Satellite A205-S4617 Notebook
barb, I have an A75 satellite and have similar problems. I have upgraded ram (corsair 2G) and also new hard drive now running XP pro. From what I have observed, the computer runs without problems anytime I use an external keyboard & mouse and freezes if I do not. While it doesn't freeze every time, it does it regularly, somewhere around 10% of the time. I have done the following; used it while wearing different footwear, shoes, tennis shoes, socks etc and noticed it freezes when I wear either tennis shoes or acrylic / nylon socks, it does NOT freeze when I am barefoot or have good shoes on, or when I use it on hard floors off of carpeted areas. I am certain my problem is related to static discharge and a poorly grounded front cover as the unit locks up the instant I rest my wrist on the front to start typing etc. This is a fairly well known problem with the satellite series and there are a number of fixes ranging from having the inside of the cover modified to be better grounded all the way up to replacing the cover with a newer type which apparently addresses the issue. Good luck.
Nov 19, 2008 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba laptop problem
The right memory for your laptop is
256MB Memory (PC2-4200) KTT533D2/256, PA3389U-2M25 KTOS534
512MB Memory (PC2-4200) KTT533D2/512, PA3412U-1M51, PA3412U-2M51 KTOS535
1GB Memory (PC2-4200) KTT533D2/1G, PA3411U-2M1G KTOS536
Using the wrong memory can caused motherboard failure.
Try reinserting the old one memory module.
Be sure that the memory is placed in the right way
Nov 06, 2008 | Toshiba Satellite A135-S2386 Notebook
Toshiba satellite A210-19T
hi my name is gary and i will try to help you with your problem
first of all have you recently added any new hardware to your pc i.e graphics card ..sound card if so start up in safe mode then remove the driver using the add and remove feature in the control panel......if this was the cause of the problem it should now ok
Sep 21, 2008 | Toshiba Satellite Pro A210-EZ2202X...
Toshiba A135 S 4527 ......some times freezes
Virus information and help Below is a listing of some of the different properties a computer virus is ... Alter the system time / date. Cause system to hang or freeze randomly.
Computer questions and answers listing 700 - 800 CH000700, What should I do when a computer freezes?
Good Luck, Please dont for get to Vote, Thank You
Nov 28, 2007 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite Pro A210-EZ2202X Notebook Logo
254 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
