Question about Canon Office Equipment & Supplies
Canon irc1021i Error code= e000003
It there any way of clearing this error
I can't see addition function button on my computer
Posted on Feb 26, 2014
spinal
  • 287 Answers
SOURCE: E000003-0000
Hello 1999.We can reset the code together. And for many errors the copier can be reset,and then recover, then move on like normal. However the code you have (E000003-0000) means that an extremely temperature sensitive area of the machine misbehaved.And the copier gets really anal about monitoring this temp so the code may return as soon as the copier runs a diagnostic, but I can assure you we can reset the code so lets give a whirl and hope for the best.Ok, on your operator control panel, next to the nine key pad,is a button that says "additional functions".Locate it and we will perform a 3 step function that will allow you to enter "service mode" which will let you clear the code. Press "additional function", release it and then immediately press the 2 and 8 buttons simultaneously, release them and then press additional functions again. As I said this is a 3 step process that should be done in a smooth but timely fashion. If done properly this will summon a new screen that will show you a few "blocks" and the top block will say COPIER. Press it and a new screen will appearwhich will have several blocks across the top of the screen. One will say FUNCTION and you need to press it. Again a new screen. Look at the menu in the body of the screen and you will see CLEAR. Press clear. New screen again and look for ERR. Press ERR. After you have touched ERR notice the "OK" button in the lower right corner of the screen. Touch "ok". Now unplug the copier and wait a few seconds.Now plug that baby back in. The copier will attempt to return to a ready condition by "warming up". This is where the copier may notice a problem with the temp. Then make a copy. This will force the copier to run a brief diagnostic(which you wont see). If the copy successfully exits the copier then you should be ok. But the fact that the code occurred at all Means that at a minimum the copier had previously seen a problem and so the code may return. Hopefully, we just saved you the expense of a service call and all remains well. I hope I have helped you and I will keep my fingers crossed hoping it was merely a momentary problem. Good luck and take care. SPINAL
Posted on Jan 20, 2008
  • 18 Answers
SOURCE: Canon Imagerunner 5000 error E000001-0000
Sort of, since both are fuser temperature related. First, the error needs to be cleared. Turning off/on won't do that.
You could go into service mode and clear the error (*28* > copier> function > clear > err > ok. Then turn the copier off, then on again and watch it heat up. I always monitor the temperature to make sure it's in the acceptable range (190 C or around that range).
If it happens often I'd have the thermistors changed. If it still happens, check the connectors in back of the fuser. They may need to be shimmed.
Posted on May 26, 2008
SOURCE: canon ir6000 error codes E000061-0001..
error E061 poblem
Posted on Dec 02, 2008
  • 109 Answers
SOURCE: I have an error E000003-0002
enter service mode
steps:
* - 2+8 - *
copier
function
clear
err
ok
turn the copier off then on
end
Posted on Apr 04, 2010
  • 122 Answers
SOURCE: The copier stopped working and Error code
switch on the machine, press *(additional function) 2and8 together and again *, on screen select copier>function>clear>error>ok. switch off the machine and restart.still problem appears then check fuser unit.
Posted on Jan 27, 2011
Testimonial: "Thanks a lot you really helped out our office. That saved us the time it would've taken to get to the other machine upstairs "
Error e000003-0002 on canon ir 2880i what could be the possible problem
Dear
the temp. reading from the fixing unit is faulty, In most of the cases the error clear process solve the problem.
You may clear the error code using COPIER>FUNCTION>CLEAR>ERR in service mode. then turn OFF and ON the machine.
If problem not solved check the thermistor at fixing assembly, Check the electrical contact points of the heater unit,check the SMPS and DC_CON card. (very rare)
Thanks.
Feb 21, 2015 | Canon Office Equipment & Supplies
Code Error on Ir 2420 l display **E000003-0000 what can i do please solve this...
dear
pl. do check the fixing film assy. heater strip contact points. if corrosion clean/replace it.
Check the DC card.
Also check the supply voltage at the machine input.
Thanks.
Dec 04, 2014 | Canon Office Equipment & Supplies
E000003-0000
good morning sir, my ir machine is 3300 the problem is showing to my machine is E000003-0000 please suggest me answer
Thanks
Apr 21, 2014 | Canon imageRUNNER 3300 All-In-One Laser...
Our Canon ImageRunner 5000S shows the Error Code E000003-0000
this error is related to fixing unit,to reset error:* with head 2&8 together* with head LCD display change press COPIER> Function>Clear>Err>OK switch off/on the machine,if the error return check the AC supply unit or you have to call your service provider
Jul 22, 2009 | Canon imageRUNNER 5000 Copier
I have a Canon Image Runner 33001. I am getting error code E000003-000. Can you help me?
Try to clear error ( * 2 8 * ) under service mode, copier, function, clear, err.
Restart.
If doesnt help:
You need to change the fixing film assy.
Mar 18, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
E000003-0000
Hello sir; Here have few steps you have to follow;
1, press "*"key,
2, press "2"&"8" at the same time .
3, press"*.".
4, click on COPIER then FUNCTION then CLEAR then ERR.
5, press OK, thenturn power off and back on.
Jan 09, 2009 | Canon imageRUNNER 5000 Copier
My canon iR3300 is displaying error code E000002-0000. Please help.
My canon iR3300 is displaying error code E000003-0000. Please help
Jul 30, 2008 | Office Equipment & Supplies
E000003-0000
Hello bungo. This code means that an area of the machine called the fixing/fusing unit which always runs at an extemely high temperature( and therefore is closely monitored) sensed a temperature error. I will gladly tell you how reset the error code which will allow the copier start fresh. As the copier starts up it will look again and the temperature and if there is a something wrong it will shut down again. This code can be caused by wierd things like electrical noise so its worth a try.Let me know if you wish to proceed as it is quite easy to reset. :->
Jan 08, 2008 | Canon imageRUNNER 5000 Copier
901 people viewed this question
old marine
old marine
