Question about Whirlpool 24 in. DU1148XTP Built-in Dishwasher
Our dishwasher came without a manual . It runs FOREVER. Normal?
We bought a floor model Whirlpool DU1148XTPB dishwasher at Best Buy. Our dishwasher came without a manual or a hook-up kit (or anything else that might have come with it). Best Buy is doing nothing about that. On normal cycle, our dishwasher has been running for nearly 2 hours and it doesn't seem to be letting up. Is this normal? We were told to run it through a cycle before we put dishes in it but at this rate it may take several days! Also, the hoses leak like sieves. We took several trips to the hardware store today to try to find anything that would work to connect your dishwasher to our plumbing. None of it worked with the hoses that worked with our old dishwasher. Should it have come with some hoses that would have been compatible? We bought an attachment kit at Best Buy when we bought the machine but it didn't have anything that would work with the drain hose.
I've never had a Whirlpool but I've always heard good things about your company. Sadly, this has not been our experience. We have already put 2 days into trying to install it and it still doesn't work properly. The last time we replaced a dishwasher, it took about an hour.
Help!!!!!!!!
  • 640 Answers
Ok ...you have a wee bit of a problem...a new dishwasher even a floor model has a warranty..just call for service...best buy will send someone,,,now all units come with everthing accept electrical cord,,,i could only find drain hose part number 8269144,,but for owners manual go to servicematters.com..last just go back to best buy and find your model and see if you can get part number off installation kit..inside new unit.../
Posted on Jan 05, 2009
Brand new whirlpool dishwasher starts on own
Because you cheated and filled it manually, it may be that the second running was actually resetting the programme. Do a normal wash, and if it does it again, contact the maker for advice.
May 10, 2017 | Whirlpool WDF750SAYB Gold Series...
I just bought a Whirlpool Gold Dishwasher Model #GU2275XTVY1. Is there a different handle to buy because it is to wide and now I can not open my draws. Any ideas?
Contact the store for the manual or way out in other to avoid damage on your newly washer.
Please rate four tom if it help.
Good luck
Dec 13, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Dishwasher is not cleaning dishes
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
k
Apr 14, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Purchasing this Whirlpool dishwasher
probably a new one. lifespan is 10 years average
Apr 05, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
My dishwasher just runs forever - washes and doesn't stop - what is the normal wash time?
Check the manual to see if the machine has a "Delime Mode".
What you described is exactly what delime mode does, If that is the case simply deactivate delime mode as decribed in the manual.
If this is not the case your machine's timer is stuck in wash mode.
On many commercial models the timers have microswitches that go bad and can be replaced however on a household unit you will probably have to replace the timer.
Dec 10, 2009 | Whirlpool Dishwashers
The cycle timer gets stuck
The timer probably will have to be replaced.
Oct 29, 2017 | Kenmore 24 in. 15149 Built-in Dishwasher
Replace dishwasher / counter tops are not standard
i have had that problem before and used a saws-al and cut the legs and what ever else i needed to get that puppy out.the question is will your new one fit?in my case most all i ever tried to install i got them in.and i have done a hundred or so
Feb 03, 2009 | Whirlpool Dishwashers
Our dishwasher has been running for over 2 hours.
Make sure the machine is in the normal cycle and the sani cycle is not selected. If the sanitize cycle is selected the machine will run for a long time while the water heats up . Go back to Best Buy and demand an owners manuel, don't let them get away with this. Also the machine is waranteed through Whirlpool and you should not have to pay for a service call if anything is wrong.
Jan 05, 2009 | Whirlpool 24 in. DU1148XTP Built-in...
Whirlpool DU1055xtss doesn't fit cavity where old Whirlpool dishwasher exists
best bet go see your local KNOWLABLE sales rep. generally the mom and pop better then the big chains for knowing what will and wont fit your height requirements
Feb 29, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool 24 in. DU1148XTP Built-in Dishwasher Logo
207 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
